Cruzzzn' Vet
Re: 86 C-10 305 with new Edelbrock 1406
I know he bought it that way but in the long run he'll have a better running truck with a properly set up Qjet, wonder if the people he bought the truck from have the old Qjet?
The guy I got the C-10 from (Paw-in-law) said the mechanic that works on the truck told him the old carb was shot and he needed a new one. Paw-in-law does not have the old carb. He also was told that it would cost $200 to fix the problem with the gas gauge (cost me $9 for a used gauge). You guys helped with that one too.
Found a spark plug off the distributor, 7 out of 8 ain't bad. LOL Found the original oil fill cap between the alternator and engine. I went back to the old one and saved the new shiny one. Was hoping I would find some tools, too. No such luck, yet. Thanks for all the comments and suggestions. |
Chris
LOl might be but ours runs great with an edelbrock I don't see it getting much better then it is.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
![]() Join Date: Dec 2008
i dont think its the Edelbrock look at all the vacum lines need's to do some thing with that lol vacuum leaks then prolly just needs a tune up and timming adjustment as well
we also see in the original post that hes new to fixin trucks and eager to learn the edelbrock is user friendly than a q-jet yes in my opinion for a beginner q-jet are good Carbs but for beginner not as ez as far as tuning
gasket/pump kit from azone is like $45 here ![]() Last edited by nbpro; 08-25-2010 at 06:22 PM. |
![]() Join Date: Feb 2009
And OP, get the manual listed in post #4 of this thread. The jet/spring/rod kit is about $50 and you will probably need it. Checker/Kragen/Summit sells them.
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() |
that 77 Cheyenne K5 looks sweet i would love to have one of them
Well I just posted a thread thinking no one has this exact same issue, and yet someone does! Except my 1406 is used, not new. The previous owner thought it was a good idea to put a Holley DP on a stock 305! lol he had NASCAR fever tho.
Exactly my point.
I don't think anyone has said that putting an Edelbrock or a Holley on a stock engine is the best idea in the world. What most of us try to do, is give the gentleman some tips on what he could do to set his carburetor and maybe even straighten his vaccuum lines out. When I first started redoing my truck, there was no carb. The truck had been stripped down and the parts put on another truck. I got an Edelbrock for free. First thing I did was go look up the info on how to tune it and set it up correctly. This was on a stock 305. No headers, stock intake. Stock. It ran fine. I think in most cases what people do, they think bigger is better. The gentleman that gave me the carb had several of these, and asked me what size engine it was. I told him, and he gave me the carb that was compatible for my engine. So in some cases, it does work out, if you do your homework.
Ok, one more comment and i will stop/or start a new thread because i've sort of taken it off topic as well as offering no help concerning the original question.
IF someone puts a weber or multiple webers on a small block, then i won't complain. |
#12 | |
![]() Biggest problem IMHO, guys get these because they don't understand carbs, let alone doing a proper rebuild, so it seems like an easy no brain-er. Get a new carb that is factory set, plop in on some V8 and everything will be good. T'iant so. And unless you pony up the extra $50 for the tuning kit, you're probably never going to get it to work as it should. On the plus side, they are easy to open up swap tuning parts out. (setting the float level looks to be a bit of a PITA however) OP just go through the owners manual and follow the troubleshooting/tuning steps. Should point you down the path to get it running better, again assuming the rest of the engine is OK, including all vac lines.
#13 |
Just re-read the initial post, OP have you put new plugs/wires/rotor/cap in yet and set your timing? I'd start there and eliminated the ignition system from the equation. THEN you can start tuning that carb.
Pay close attention to the condidtion of the plugs. If some are fouled make a note, or label and keep them for reference. You could have an oil control problem too... (fouled plug under load = miss)
#14 |
Ok ONE more comment and then i'll stop----really.
i noticed that reman q-jets are available at summitt for $269, no core. It seems that if someone did not want to rebuild theirs (which is understandable if you've never done it) that this would be an easier cheaper way than getting a holley/carter clone. i understand that when you go holley or carterclone it's new vs. if you go q-jet it will most likely be used or remaned. But reman is just as good if not better than new. BTW i think when edelbrock was selling the q-jet (as RPM) it also said weber on it because i think weber was the one actually making it for them. Last edited by C-10 simplex; 08-26-2010 at 05:29 PM. |
#15 | |
One of the guys I work around suggested a better distributor for this particular truck. Along with the wires/plugs, do you guys have a suggestion for the distributor. My friend mentioned getting one that only had power hookup. In other words, not the plug for the "module" that is hid on the firewall or somewhere inside the truck. Have any of you ever heard of such a mod on a C-10 or 305? Does that mean I have to go back to points or is there something else I'm missing? Thanks |
#16 |
Weber is called Magneti Marelli. They have a plant down south where they make the Edelbrock carbs post #15 http://genuineweber.blogspot.com/
spark control module would need a look see at two ??? Last edited by nbpro; 08-26-2010 at 08:20 PM. |
#17 |
get a gm distributor
and read this mod http://www.chevytalk.org/fusionbb/sh...hp?tid/176666/ Last edited by nbpro; 08-31-2010 at 02:36 AM. |
#18 |
Chris
just bypass that big 4 prong plugin and run it that way, then it'll be a gm dist. and won't have the esc and all that junk. It works fine got it done that way on the 305 that came from dad's 84 that's now in the 85 mcss.
Tags |
edelbrock 1406 c10 c-10 |
