08-22-2010, 07:00 PM | #1 |
86 C-10 305 with new Edelbrock 1406
Just got this truck a few months ago. It does run but bucks and jumps when underload or even going up a steep hill. It has a new eddy1406 carb and I checked the fuel pressure and it jumps around while at idle and goes to about 5 psig when I rev it up. It has electric choke.
If I floor the gas while at idle the engine bucks and chokes completely. I pulled the carb fuel inlet line and checked the screen, it is clean. Is 5 psi enough for the 1406 carb? I am new to fixin trucks and eager to learn so that I can get this baby up and running like it should. Thx |
08-22-2010, 07:21 PM | #2 |
Chris
Re: 86 C-10 305 with new Edelbrock 1406
you checked the plugs? could be running lean, we had a quadrajet do that.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
08-22-2010, 08:03 PM | #3 |
BAD BOW-Silverado XST
Yea, the problem is the air filter. Your are choking the engine! I had a 305 with the same carb. I used a 4.5" K&N filter. It would scream all the way to floating valves.
I see the fusible link is bypassed. Does it have a fuse somewhere else? You are also running ported vaccum on it. Last edited by gchemist; 08-22-2010 at 10:10 PM. |
08-22-2010, 09:00 PM | #4 |
These carbs trys to flood at more than 5.5 psi. I use an adjustable reg and keep mine at 5.25 psi
check your pump shot, for your 305 you may need to put the linkage in the bottom hole or middle hole These carbs DO NOThave "fixed" jets . They have removeable and changeble jets They do use metering rods and step up springs and you do use those for most mild tuning though. The vac ports on carb front pass side little = timed or ported vac (no vac at idle) center large = full intake vac (common PCV valve hook up) driver side little = full intake vac EPS Carburetor Owner's Manual http://www.edelbrock.com/automotive_...406_manual.pdf EPS Carburetors Installation Instructions http://www.edelbrock.com/automotive_.../1000/1406.pdf |
08-23-2010, 08:44 AM | #5 |
i continue to be perplexed as to why EVERYONE (and his brother) insist on switching carbs(usually holley or edlebrock) on a stock engine with stock manifold?
08-23-2010, 10:14 AM | #6 |
The cost for a rebuilt "Stock" quadrajet with the electronic feedback solenoid is ~$500. Grab a adapter plate and a NEW Edelbrock 1406 for ~$300
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
08-23-2010, 10:23 AM | #7 |
1406 is too big of a carb for that motor. anyway, have you had a carb backfire recently?
08-23-2010, 10:28 AM | #8 |
It doesnt have a power valve that blows out like a holley when it backfires. truck will run just fine with this carb.. Adjust and ride. his truck prolly just needs a tune up and timming adjustment/dist. rebuild.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
08-23-2010, 10:34 AM | #9 |
08-23-2010, 10:37 AM | #10 |
1406 is what a 600 CFM Carb thats to big for a 305 ?
08-23-2010, 08:50 PM | #11 |
Pulled the ported Vac line off and plugged the hose and capped the fitting on the carb. It runs LOTS better now. Will check timing and read the install/operation pages from eddy. Thx
08-23-2010, 09:16 PM | #12 |
Chris
a 600cfm is definately small enough for a 305, I got the sae one but manual choke on the 84 305 that dad had in his truck. I got a smaller air cleaner then that on it and it doesn't choke out at all. but ported vac plugged? where did it go? if it went to the dist. that aint too good of an idea to plug, but for me, running the dist. vac. adv. on ported worked best.
08-23-2010, 09:32 PM | #13 |
My old 305 would smoke a stock 350 with that carb. I would easily flood it going from idle to WOT. Mechanical secondaries are the downside. Tune it for ported vacuum. It will run great.
08-24-2010, 12:22 PM | #14 |
Chris
ok I gotcha and yea ours is the same way the 85 monte carlo with that 305 from the 84 c10 and that 600cfm man. choke vac. sec. carb will smoke the tires off of it but the 350 I had in it not so much lol and I had a stall convertor behind the 305 that was mildly built lol.
08-24-2010, 02:35 PM | #15 |
My 500 CFM Carb is actually a old remanufactured Carter.
with the Edelbrock logo tag over the Carter tag But it's actually bigger than what Edelbrock rates it.500 CFM its more like 625cfm Weber is called Magneti Marelli. They have a plant down south where they make the Edelbrock carbs Last edited by nbpro; 08-24-2010 at 02:38 PM. |
08-24-2010, 10:11 PM | #16 |
Grandpa in the rustmobile...
so is a 500 eddy enough for a 355 vtec headed motor? or should i step upto 600cfm?
dude you need to find out where all those vacum lines go to! you have tees etc everywhere
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-24-2010, 10:34 PM | #17 |
step upto 600cfm i would say but I may be wrong. A lot of it has to do with cam, emissions systems. In some states you have to leave that on to pass emission standards. But that carb should run fine on your motor in my opinion, but I'm no expert, and I haven't stayed at a Holiday Inn recently either. i would ask in the engine and drivetrain forums for a better answer.
08-24-2010, 10:55 PM | #18 |
Still plays with trucks
Have you checked the vacuum level? That stock 305 should be pulling close to 24 inches of vacuum at idle unless it has a larger cam.
I have seen many engines with carb adapter plates that did not fit right and leaked a bunch of vacuum. Check for vacuum leaks around the base of the carburetor. My 1406 came with a thin metal spacer that fixed some of the vacuum loss problems as it covered more area than the adapter plates did. Did yours have one?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
08-24-2010, 11:07 PM | #19 |
Ported vacuum with-holds vacuum advance at idle, no vacuum will be applied till the throttle blade moves past the port thus exposing it to the pressure inside the manifold. As the throttle moves toward WOT at some point the manifold pressure and atmospheric pressure become nearly the same, thus no vacuum is present with a normally aspirated engine. So the vacuum advance amount becomes less and less as the throttle is opened.
Un-ported vacuum shows the advance mechanism manifold pressure from the moment the engine fires. To that end vacuum advance is present at idle This can help a low compression engine or a long cammed engine to idle and transition to mid throttle more smoothly. There really isn't a right or wrong here, it's more studying what the engine as it's installed in the vehicle likes best. |
08-25-2010, 12:06 PM | #20 |
Chris
yea all of his vac. lines are smog junk, our 84 c10 w/ 305 had it all and I threw it away.
08-25-2010, 01:19 PM | #21 |
Cruzzzn' Vet
08-25-2010, 03:03 PM | #22 |
This may be true, but if you look, he Just got this truck . Also, just the fact of the cost involved of a Quadrajet, which has already been mentioned.
08-25-2010, 03:44 PM | #23 |
Chris
agreed not to mention how user friendly the edelbrock is and how easy/cheap it is to rebuild, like $40 for a kit and even somebody like myself who has/had never built one before can do so very easy. I did it and it was my first carb rebuild ever. Turned out great.
08-25-2010, 05:14 PM | #24 |
yes that to
08-25-2010, 05:26 PM | #25 |
Cruzzzn' Vet
I know he bought it that way but in the long run he'll have a better running truck with a properly set up Qjet, wonder if the people he bought the truck from have the old Qjet?
Tags |
edelbrock 1406 c10 c-10 |
