Old 09-24-2010, 11:32 AM   #26
Thealien
Thealien's Avatar
Re: My 6.0 LQ9 install!!!!!
Thanks for posting those. Do you mind if I copy those into mt LS swap thread and share them with others?
Old 09-24-2010, 12:20 PM   #27
drjeffdc
drjeffdc's Avatar
Really Cool. Whats involved as far as wiring the newer version stuff up?
drjeffdc is offline   Reply With Quote
Old 09-27-2010, 08:48 PM   #28
dentmaster
No sir. Not at all......Anything to help others
dentmaster is offline   Reply With Quote
Old 09-27-2010, 08:53 PM   #29
dentmaster
I just got rid of certain parts of the original harness...(dual point distributor, voltage regulator, parts of the alternator wire, different wires that I didn't need). The harness I had built was from pacific fab....It was awesome, just follow the directions, and plug and go....It was simple
Old 12-15-2010, 12:11 AM   #30
themb2g
I am looking to do a gen 3/4 install and have found a great LQ9 out of an escalade ext. I Was wondering 1. what transmission you used and 2. what you did to hook up the transfer case. it looked like you had the original transfer case, but maybe i was wrong. good to hear pacific fab has the wiring harness too.Thanks in advance.
themb2g is offline   Reply With Quote
Old 01-24-2011, 03:32 PM   #31
ASTAR
That thing is beautiful. I'm hoping to do the same swap. What year engine is that?
ASTAR is offline   Reply With Quote
Old 01-24-2011, 05:51 PM   #32
72k5zl1
72k5zl1's Avatar
looks great!
72k5zl1 is offline   Reply With Quote
Old 02-24-2011, 06:59 PM   #33
thor
thor's Avatar
kickdown linkage?
Beautiful blazer and fantastic swap! Did Pac Fab give you a manual transmission program in your ECM since you are using a TH-400 instead of a 4L65E? Also, what did you do about the kickdown linkage (looks like you are running the DBW)?
Thanks for your time!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 09-27-2015, 01:50 AM   #34
72LSK10
72LSK10's Avatar
Beautiful K5 Greg,
I have some questions, what headers are you running and how is the clearance? What fuel tank are you running, are you running an in tank pump? Thanks.
72LSK10 is offline   Reply With Quote
Old 07-12-2016, 06:23 PM   #35
Marshy
Originally Posted by dentmaster View Post
LOL...yea...I noticed I put the pic of the 4spd(sm465) in there a few times. I was trying to use it. It was in the blazer originally. I was not able to make it work, It was gonna cost me more to setup hydraulic clutch, then to use a turbo 400 I already had......Great job! on your install Marty.....the seats (I think) are out of a 01 yukon, or tahoe. I used the 3rd row out of a suburban that matched it......Thanks everyone for your compliments... I am sooo glad I went that direction on the install.
Nice build. Can you elaborate on the issues with swapping to a hydraulic clutched trans? What are the primary issue, why not install a T5?
Marshy is offline   Reply With Quote
