10-20-2010, 02:44 PM | #26 | |
Re: what vehicles came with 200r4 from junk yard
but all v-8 f-bodies did not come with a 700r4 my 82 came with the 200 and my brothers 82 Z28 came with the 200 you could replace them using the same DS and mount with a t350 you just had to buy the tourqe arm adapter |
10-20-2010, 06:34 PM | #27 | |
10-20-2010, 06:38 PM | #28 | |
the 200c is a 3 speed no overdrive. only lock up converter clutch.. no f body came with a 200r4 all where 700r4 some 78-81 had th250 three speeds.. the thread was about overdrives so I didn't think I needed to include the 3 speed 1 to 1 high gear automatics |
10-20-2010, 07:25 PM | #29 |
I have had a few 2004r behind strong engines one 87 buick gn that I would guess around 375hp 12.70 at 118 [lots of tire spin] I had a manual lockup switch that turned it into feelng like a stick shift It locked the tqconv. at the 1-2 shift and stayed in under full throttle, it was an art carr convertor that could take it man I miss that car. I think they are better than a 700 any day
12-18-2010, 01:04 PM | #30 |
72 GMC
is there anything on the SPID or do i have to crawl under the vehicle ?
08-16-2013, 07:46 PM | #31 |
I have a 67 chevy shortbox with an 80s 350 and 3 speed manual. Would the 200-4r be a good/easy swap?
08-16-2013, 08:59 PM | #32 |
Should bolt right in place you might have to move the transmission crossmember but the drive shaft will bolt right in.
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
08-17-2013, 12:05 AM | #33 |
beeing a g body guru !!lo the used 200 trans in a lot of 79-87 cutlass,grand prix,monte carlo,and buick regals ,as well as 82-85 camaros and firebirds .most were bop which means buick olds pont and chev bolt patterns they were a very universal trans!!
08-17-2013, 07:23 AM | #34 |
Thanks for your help guys. I'm retired and not familiar with the new technology.
08-17-2013, 09:06 AM | #35 |
Will they bolt up to a 72-402?
08-17-2013, 01:15 PM | #36 |
born to lose
I've always heard bad things about the 2004r but this post shed some good light on the subject
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 Sold!! '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 stolen totalled gone.... Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
10-13-2013, 03:18 AM | #37 |
Hey guys...Whats the best way to identify the 2004r? Pan bolts, or is there an ID tag somewhere?
Why...Why...Why...Can't I leave anything alone??? |
10-13-2013, 06:04 AM | #38 |
Here's a handy guide
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
10-13-2013, 10:52 AM | #39 |
Thanks Pop's C-10 thats sweet!
10-13-2013, 11:37 AM | #40 |
The Older Generation
The easiest way I have found is that the 2004r doesn't have a removable tailstock like the 700r4 or the TH350, the case is cast in one piece. (see pictures)
Here is an article about the 2004r that was in Hemmings Motor News that I will add to this thread. http://www.hemmings.com/hmn/stories/...feature26.html LockDoc
10-13-2013, 12:33 PM | #41 |
Be aware the lowly TH200 and TH200C are also one piece cases.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
02-15-2014, 07:22 PM | #42 | |
But a crawl under wouldn't hurt. No telling what might have been swapped in.
Rich |
02-15-2014, 07:43 PM | #43 |
For those nit picking on people saying 200r4 (which seems natural since GM put the letter after the first three numbers on 700r4) saying it's 2004r,you are also wrong. GM calls them 200-4r. Just a little side note on this four year old thread.
02-15-2014, 09:10 PM | #44 | |
I do know the inner workings and why a 2004r does or doesnt work. And see there, I missed an apostrophy and a hyphen as that takes more keystrokes, too.
Rich |
02-15-2014, 11:31 PM | #45 |
I don't think those people I was referring to were posting from their phones in 2010. That's funny,extra keystroke. Don't wear yourself out for the sake of grammar
02-16-2014, 02:46 PM | #46 |
02-17-2014, 11:02 PM | #47 |
I installed a 2004r in my 69 CST short bed. The best part is, it was a powerglide truck to start with and the two trannys are the same length. All I had to do was move the cross member back to the already pre-drilled holes in the frame for the TH400. The drive shaft didn't need to be shortened and popped right back in. There is more to it than that, you do need to wire a way to unlock the torque converter & you need a bracket to attach the the TV cable to the carb (this is especially important to get correcct) I went the easy but pricey route of Purchasing everything from Bowtie Overdrives http://www.bowtieoverdrives.com/. They have everything included a wealth of information on their website and you can call their tech guys if you have questions. I bought a wiring kit from them that hooked up a switch to my brake light switch to unlock the torque converter when you hit the brakes. I also bought a TV cable setup made for a Edelbrock carb/manifold. Then don''t forget if you want your speedo to work properly you need to change out the speedo gears in the tranny. Now with a tonneau on the bed I get 19 MPG on the highway diving 70 MPH while the engine is turning just under 2000 RMP.
02-18-2014, 04:30 PM | #48 |
I was using my phone at the time...time goes fast, it seems it was last year when I started this post
02-19-2014, 11:17 AM | #49 |
It's all good. I was just giving the nit pickers a taste of their own medicine. Nothing was directed at you or that other feller who felt he needed to defend himself.
