what vehicles came with 200r4 from junk yard
im looking for 200r4 tranny for my 70 chevy I tried the search button to look from what cars a can get the tranny out and related parts.. does any body know what cars and years I'm looking for? my truck is 292engine 350automatic....thanks
Re: what vehicles came with 200r4 from junk yard
g body 84 up(monty/grand prix/cutlass/etc
some b bodys(caprice) think v6 ones not the v8 Last edited by stich626; 10-19-2010 at 04:40 PM. |
Its a Truck Thing......
Deep inside this site someone is twitching about seeing 200r4 and having a major seizure
![]() Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 10-19-2010 at 04:45 PM. |
sharp as a marble
![]() Join Date: Jan 2007
Caddys, Buicks, Olds and Pontiacs too. Mine was in a 84 Olds 88 originally.Some have the BOP bellhousing.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
I know I know,,,,evertime I see a post on this trans someone spazz's hard about callin it correctly, i dont care, i have better things to yell about
![]() Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
Lol...sorry my English is so limited.. still learning. Do all have to be v6 or do they came on v8? Thanks. Oh.. What more do I need while I'm there(fly wheel or flexplate not sure what is called, torque conv.starter) ?
Posted via Mobile Device |
I had a SS monte carlo bought new in 86 that had a 200r4. It had a l69 [ho] 305. You wolud think that would be an oxymoron to have a high output 305 but it did run quite well for what it was.Jim
its all about the +6 inches
get the mount, the dipstick tube and dipstick, the drive shaft yoke (unless you are replacing a TH350) the converter, the dust shield, the TV cable, and keep all the hardware since it'll most likely be metric.
I can't remember if a small block has a flat flexplate or if it has raised mounting points where the converter bolts up, but you'll want the donor car to be the same way. Some BOP engines have flat, some have the raised pads. If you try to run a converter from a flap on a raised pad flexplate, then you won't be pulling the converter out enough when you set it... and the otherr way around is true too. |
Cruzin
i love mine, the best motor/ trans i have ever owned
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
sharp as a marble
there is a 3 letter code stamped on a small plate that is riveted to the right side of the transmission body near the tailshaft. This 3 letter code is the valve body calibration. My transmission guy, who hates 200's tells me to find ones with the firmest code. If you look online you will find the codes, and what the trans might have come out of. BRF is like hens teeth. Buick Grand Nationals only, but the best for firm shifts. If I remember I will look for this site and share
#13 |
I picked up the info below from the internet and other forums so I offer no guarantee about its accuracy. I don't know that much about them.
"The 2004r core transmissions themselves are basically the same save for some very early ones. The valve body and governor are what makes the difference and should be considered a "match" item. What I mean is that the good valve body and governor codes to look for are: KZF Olds 442/Hurst CZF 85-88 Monte SS CRF 85-88 LG4 305 powered Monte Carlos/Pont Gr Prix BRF 86-87 GN/T-Type/Turbo Regals BQ 84-85 GN/T-Type/Turbo Regals BR 83 Model T-Types TAF 89 Turbo Trans Am OZ Hurst Olds OM Olds 350 Diesels OG lds 307 BY V-6 252 Cars AA and AP Cadillac's You can modify a non performance 2004r by swapping in a performance coded valve body and governor. Some can be modified with special shift improvers, but most 2004r experts will tell you to stay with the performance codes for better shift feel and shift points. The best are BRF, BQ, TAF, CZF, OZ, KZF. The Caddy and Diesel ones generally are the ones that shift very softly and at very low rpm and can be difficult to calibrate starting with their factory calibrations. Also note that the 86-87 Turbo Buicks and the 89 Turbo Trans Am have the largest factory servo. Its ok, but there are better aftermarket options available."
'67 GMC 2500, 292, 4spd, AC |
#14 |
Old Skool Club
![]() Join Date: Jun 2001
I bought an '81 Impala wagon with a 305 and a 200R4....in '82.
I've also read from some truck rags that a 200R4 can be made to live behind some strong engines. 200R4 is a TH350-based unit, compared to the 700R4 being a TH400-based gearbox. Supposedly, the gear ratios in the 200R4 are better in the same way that a TH350 is a bit better on the bottom end of the speed curve than a TH400.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#15 | |
the 700r4 has nothing to do with a th400 at all the new 4e80 in trucks is a th400 with an extra gear added the 4e60 is the electronic controlled 700r4 as far as the 200R4 goes. try to get a late 85 on up.. they have upgrades in them. unless your having it rebuilt, then it don't matter.. the 442/SS/gn/ and hurst have a better set up valvebody, but they are in hi demand and that= cost.. I'd get the converter with the tranny,BUT I'd use it for nothing more than a core.. get a new one or a rebuilt one, the weak link in this is the converter clutch.. and for a street truck you want the clutch lock up.. they can be built to take anything, (gn's running in 8's) the biggest thing is the tv cable, you must adjust it correctly, and spend the money on the correct bracket, if use'n a q jet, just get it off the car the trannys coming from. if running a holley , you'll have to buy the bracket.. this adjustment makes or breaks these.. good luck.. |
#16 |
they also came in the camaro`s with the 305 in them , my 82 camaro had one in it from the factory.
#17 |
Suburban Hick
![]() Join Date: Aug 2008
Didn"t those come in s10"s too?
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
#18 |
yes they do but unless the S-10 had a 4.3 in it , the bell housing is different
#19 |
If you are looking to add this trans, Ebfabman put a good post on resources needed.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 10-20-2010 at 12:38 PM. |
#20 |
#21 | |
to the thread starter, only g.m. g bodys and some b bodys have this tranny. nothing else all others used the 700r4 200r4 bolts in place of a th350 the 700r4 does not.. the 2004r has a better o/d gear the 700r4 has a 3to 1 first gear and big gear splits the 200r4 doesn't have this issue.. the 700r4 first gear will alow you to use better highway gears and still have nice take off.. most with this tranny got 3.23's or 342 trucks and wagons some as low as 308 293 but the 700r4 will require a shortened drive shaft and different yoke.. the 200r4 you can use your th350 one if not worn(yoke) and don't have to shorting driveshaft.. good luck Last edited by stich626; 10-20-2010 at 12:58 PM. |
#22 |
I have one in my 84 Caddi Fleetwood. It's behind an Olds 350 out of a 73 Cutlass. Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed ![]() ![]() 1966 C-10 lwb,factory A/C,Custom Cab ![]() 1954 Delray 2-door sedan [rat rod project]
#23 |
In 89 a lip/step was added between the pump body and front seal to keep the pump bushing out of the front seal.
Working on my first 1,000 post. I'm sure I'll get there before this project is over ![]() |
#24 |
that is not correct, on the earlier year camaro`s it had a 3 speed shifter it only had D-2-1 they where the 200 in them . the camaro`s with this shifter in them was the 200 , the f-body`s from 82 up did not come from the factory with a 3 speed tranny , the od kicked in on its own. |
#25 |
ok , i stand corrected, the tranny in the camaros was a th200c
