Old 12-06-2010, 06:02 PM   #26
74chevy3/4
Re: I need help now !!!!!!!!!
The original problem occurred in a warm vehicle. Fifteen minute drive. Stopped for gas. Back in truck. No Start. No Sound i.e. clicks. Nothing. Vehicle was towed. Sat in 15 degree weather for the night. No miracle in the morning. Starter pulled and taken to auto parts store where it "passed". So initial failure was while truck was warm. Been below 20 degrees ever since.
74chevy3/4 is offline   Reply With Quote
Old 12-06-2010, 07:06 PM   #27
D-Day
Live fast, die young
D-Day's Avatar
I can't offer anything that hasn't already been said here (wiring, switches, battery, cables, etc.), but I wish you the best of luck. Maybe try the solenoid before replacing the starter or ignition switch. Cheap, somewhat easier alternative, and it might help the starter. Mine cost about $18.
D-Day is offline   Reply With Quote
Old 12-06-2010, 07:30 PM   #28
74chevy3/4
On the '74 the solenoid is attached to the starter. So without "finding" another suspect, a $40 starter/solenoid combo will be the first shot-in-the-dark.
Old 12-07-2010, 07:39 PM   #29
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Ok, it just so happens the last few days I've had a similar problem with my truck, after a few hours diagnosing today, I discovered it was my ignition switch, looks like this
It's on the steering column. I had the same issue you had, everything work but when I went to start it, nothing. Is you key harder to turn then normal? This could be your problem.
Dalaigh is offline   Reply With Quote
Old 12-07-2010, 11:20 PM   #30
74chevy3/4
yes the key is harder to turn then normal ... what dose it take to replace the ignition switch
Old 12-08-2010, 02:25 AM   #31
D-Day
D-Day's Avatar
Gotta remove the heating duct that runs under the column, take off the little upper and lower column panels (one plastic lower part of dash, one part metal under the column), take two bolts off that hold the column to the dash and reach up under and take it off. Some advise pulling the column, but I've done it upside-down with a flashlight, so meh.
Old 12-08-2010, 08:29 AM   #32
motornut
78K & 79C Jimmys
motornut's Avatar
Any chance you had the key cyclinder out?
i had to fix a friends car cause he turned the ignition with out a cylinder in it,
and it turned the gear on the top of the colum inside(can wear out too
this drives the switch lower down
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-08-2010, 10:24 PM   #33
74chevy3/4
GOT IT
the problem was the neutral safety switch and a fusible link blew
thats for the help all =D
