01-11-2011, 09:22 AM | #26 | |
67-72 parts collector,…
Re: Bags in place of coils ? 68 Burban. What Bags
The SlamSpecialties SS-7 bag is a new version of the old RE-7. Suppose to get 1" more lift than the RE-7's. http://www.slamspecialties.com/home.html
01-11-2011, 10:16 AM | #27 |
are the air lift dominator 2500 or 2600 good do they last any problems? which would be better to get and install..
01-11-2011, 12:38 PM | #28 | |
I've been very diligent about pics this time around and will gladly put something together when it's all said and done. I am doing an interim bag setup to replace the coils for now just to get my truck to ride well since my shocks and coils are toast.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
01-11-2011, 02:29 PM | #29 | ||||
A guy with a truck
Lotsa guys run the 2500s, but I was already drilled for the 2600 spacing, which is slightly different. Using the smaller bag would allow more pressure at a given height, which means better ride (to a point).
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-11-2011, 04:58 PM | #30 |
So by going with a 1.5" block that will allow me to run more pressure. Which should give me a better ride ?
How will the pinon angel be affected ? Thanks for all the help.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
01-11-2011, 06:13 PM | #31 | |
A guy with a truck
Pinion angle will be less affected using the block, as you are not rotating the trailing arms 'up' as far. Guys have been flipping the brackets on the trailing arm crossmember to help correct this as well. Looking at the original question- I would stick to the 2600lb bags for a burb, especially if planning to tow.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-11-2011 at 06:15 PM. |
01-12-2011, 12:14 AM | #32 |
sorry to jump in here but when you say "blocks" do you mean lowering blocks between the trailing arm and the axle? Secondly, assuming i use shock relocators and adjustable trac bar, do i use stock height shocks or lowering shocks? When do you use a lowering shock versus OE height?
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 01-12-2011 at 12:18 AM. |
01-12-2011, 12:51 AM | #33 | |
A guy with a truck
A combo that I know for sure works with bags is 2" lowering blocks, relocation kit, and Monroe 32301s. Again, I trust me, but I don't trust everything I read on the internet, so I would double check your measurements before buying. Monroe has a catalog that breaks down every shock they make by part number, extended and compressed length, mounting style, and product line. The blue Monroes are what ships with many Air Ride Technologies and Porterbuilt Street Rods kits, so I figure they're good enough for my junk...
01-12-2011, 11:18 AM | #34 |
this might sound strange or a newb question but here goes, say i get dom 2600 bags front and rear, how much lower will they make the truck, i know it will depend on the pressure in the bag but at an average ride height how much lower would it be? and what would an average pressure be?
01-14-2011, 10:31 AM | #35 | |
01-14-2011, 11:08 AM | #36 |
3" drop average w/85psi front, 30psi rear.
01-14-2011, 11:26 AM | #37 |
ok thank you SCOTI, i have 2 inch blocks in the rear so basicly a 3/5 drop sweet
