Old 02-06-2011, 12:59 PM   #26
Hart_Rod
Hart_Rod's Avatar
Re: Flipping trailing arm mounting brackets?
Here's how I did mine, . The sawsall, air chisel and punch made this a pretty simple job. I also have some rear end pinion shims just in case this doesn't fix all the angle mismatch. After reading everything here, I "assume" I should put them in to help rotate the pinion up in the front???? Also, another advantage seems to be that it pushed my rear wheels back approximately an inch, which helps better center them in the wheel well.
Hart_Rod is offline   Reply With Quote
Old 02-06-2011, 02:27 PM   #27
gringoloco
A guy with a truck
gringoloco's Avatar
Looks good, Rob Any clearance issues, either at the floor cross-sills or where the arms pass under the frame? Also, have you re-installed the driveshaft? Since it moved you back an inch, any issues at the trans yoke?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-06-2011, 04:30 PM   #28
lolife99
67-72 parts collector,…
lolife99's Avatar
Rob,... just curious how this mod pushed the rearend back 1"?
Is the ECE crossmember located in a different set of frame holes?
Keith
Convert to disc brakes.
Old 02-06-2011, 06:26 PM   #29
SCOTI
SCOTI's Avatar
Rob,... just curious how this mod pushed the rearend back 1"?Is the ECE crossmember located in a different set of frame holes?
The ECE x-member mounts in the OE location unless it's modified/moved by the installer.
The rear end on a T/A set-up swings up & forward on its natural arc as it gets lower. By raising the pivot point in front, it's like you're not lowering it as much in the rear as it swings through the arc of travel.
As we know, the lower the truck, the farther forward in the wheel opening the axle C/L shifts. Not being as low in the arc should mean the rear end sits slightly farther back & yields positive pinion angles.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-06-2011, 06:45 PM   #30
lolife99
lolife99's Avatar
I see the 6" drop spring and a 2" block moving the rearend forward.
I just don't see the bracket flip moving it rearward as much as 1 inch.
(with the pivot point being the coil spring)
I do see the advantage of gaining a better pinion angle.
Keith
Old 02-06-2011, 07:12 PM   #31
Hart_Rod
Hart_Rod's Avatar
I don't know that it's exactly 1", I just kinda swagged it, . I do know visually it has moved back... When I get it back on the ground I'll see if I can get a before and after picture.
Old 02-07-2011, 12:29 AM   #32
SCOTI
SCOTI's Avatar
Which is why I stated this.....
I feel that 1" measurement is unlikely, but it will move it back.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-07-2011, 03:39 AM   #33
scrapmetalart
Junior Member
how low is too low to do this? I have 5" rear springs & am adding 2" blocks & might go to 6" springs...will this cause a clearance issue with the bed?
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 12-17-2011, 01:10 AM   #34
72gmcshorty
72gmcshorty's Avatar
Is this crossmember flip recommended for someone with a mild c-notch, airbags, shock relocators?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 12-17-2011, 09:11 AM   #35
WAAF
silly question, hope is doesn't highjack the o/p thread..
I understand the flip of factory bracket= cheap and easy
but,(always the but)
would making or useing mount like they use on a 4 link set up.. with 4 mounting points.. allow you to tune the rear set up more?
or is this overkill on this.
WAAF is offline   Reply With Quote
Old 12-17-2011, 12:47 PM   #36
SCOTI
SCOTI's Avatar
A spec built mount w/several mounting points for the front bolts would allow the end user to 'tune' the set-up per their application & be better vs a one size fits all approach.
Porterbuilt @ http://www.porterbuiltfabrication.com/ makes a T/A x-member like this. Hotchkis offers something similar too (I can't remember but I think it might be just the brackets as part of a rear kit).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2011, 12:49 PM   #37
chevyrestoguy
chevyrestoguy's Avatar
Actually not a silly question at all. If you made a mount like a 4 link set-up has, you have a few more options for setting the pinion angle where you want it. I considered this when I flipped my brackets. I was going to find a suitable-sized chunk of square tubing, whack off one of the sides, drill the 3 holes for adjustability, and then match-drill the mounting holes to the O.E. crossmember. I wound up just using the stock bracket because I was changing the rear end, and I was going to be setting the exact pinion angle I wanted when I welded the new perches on.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 12-18-2011, 07:19 PM   #38
edhtrd71
How do you know if this modification will be usefull? My rear has 3 inch drop springs. I dont really have any traction issues seems to have alot of forward bite. (Maybe not enough horsepower) thats another issue.
edhtrd71 is offline   Reply With Quote
Old 12-18-2011, 08:54 PM   #39
SCOTI
SCOTI's Avatar
Trial & error tuning.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-23-2011, 02:27 AM   #40
Captainfab
60-66 Nut
Not a silly question....it's been done before and with good results.
http://www.67-72chevytrucks.com/vboa...d.php?t=278864
Now Hotchkis includes a set in their performance suspension package for the '63-'72 trucks.
Old 12-23-2011, 08:49 PM   #41
oldno7
oldno7's Avatar
So let me ask this I'll be using a 6 inch drop spring, and ordering a new rearend since my truck has this drop moser has told me they can fix the axle saddles to fix the drop if a guy flipped these brackets do the axle saddles still need moved or not
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 12-23-2011, 09:35 PM   #42
Hart_Rod
Hart_Rod's Avatar
I would because it will help center the rear tires because of your drop.
Old 12-24-2011, 08:30 AM   #43
oldno7
oldno7's Avatar
If Moser adjust the axle saddles to fix the pinion angle, AND you flipped the trailing arm brackets that also helps with the pinion angle. Would this be overkill by doing both? I understand the centering of the wheel so flipping does make since. Just don't want two pos to make a neg
oldno7
Old 01-10-2012, 10:08 PM   #44
jmlcolorado
Can anyone tell me what the factory piñon angle is for these trucks with factory springs?
I cut mine out and modified the frame LONG before I thought of checking this.
jmlcolorado is offline   Reply With Quote
