01-10-2011, 12:08 AM | #1 |
Flipping trailing arm mounting brackets?
I've seen in several threads about guys flipping the trailing arm mounting brackets which raises the mounting point on the crossmember. The claim is that this improves the geometry on a lowered rear setup. Seems like a simple thing to do if there is a real gain.
Is there any real advantage to doing this? If so, what is the gain related to? Steve |
01-10-2011, 12:37 AM | #2 |
A guy with a truck
Re: Flipping trailing arm mounting brackets?
Changes pinion angle back to a more stock-like position. Maybe a few degrees difference... If you are planning on going extremely low, this is a bad idea, as the arms will hit the frame where they cross under sooner. Also, not quite as simple as it sounds, that crossmember is a BEAR to remove.
All that said, not a bad idea if you're already moving it and don't plan on going super-low.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-10-2011 at 12:38 AM. |
01-10-2011, 12:57 AM | #3 |
If you lower the truch (chassis) the mounts move down, and the pinion angle goes with it. This was the way chevy designed it, but the 'sweet' spot for the pinion angle was at stock hieght. Flipping or raising the front mount helps get it back. The other thing is the percentage of "anti-squat", or, how the truck loads the rear tire. Raising the mount helps to plant the tires. It's onlt 12 rivits, drill 4 holes, and put in 12 grade 8 bolts, and you know its better.
01-10-2011, 01:14 AM | #4 |
Grandpa in the rustmobile...
So with 4" drop it'd be a good idea?
Cut the rivits out, flip em upside down, then bolt back with grade 8 hardware, right?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-10-2011, 01:53 AM | #5 |
That's the way I understood the modification Oldblue, just pop em off an flip em.
Not sure why Gringoloco is saying you need to move the crossmember, maybe only in an extreme drop? GL, can you elaborate? |
01-10-2011, 02:21 AM | #6 |
A guy with a truck
Two ways to skin this cat: First, remove the crossmember and flip the entire thing; second, pull the mounts and flip them. You will, as Rob posted, have to drill two holes per side when swapping the brackets due to the middle rivets being off-center. Really not sure which method would be more work, honestly. Those rivets are a pain no matter what they're holding, especially when lying in your driveway, on your back, with an angle grinder and an air chisel (or BFH). Kind of a rite of passage of modifying these trucks though...
At 4", it sounds like it would be a good idea, but I would measure the pinion angle to be sure that a) you need to do it, and b) if you do need it, you are ending up with the correct angle when all is said and done. There are also shims available to more precisely correct pinion angle, but not quite as inexpensive as a handful of grade 8 hardware...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-10-2011, 02:29 AM | #7 |
Fun Stuff
Here is a link to a great thread hosted by Rob. Post 270 on page 11 shows how it is done. Good luck.
http://67-72chevytrucks.com/vboard/s...d.php?t=419251
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd Last edited by jayman68; 01-10-2011 at 02:30 AM. Reason: Forgot link |
01-10-2011, 02:42 AM | #8 |
I was thinking about modifying the crossmember for pass through exhaust anyway.... but if the only gain from flipping the arm mounts is improved pinion angle then it would seem to me that shims would be more precise. I thought maybe there was something more to it.
01-10-2011, 10:06 AM | #9 | ||
01-10-2011, 01:50 PM | #10 |
Has anyone swapped the mounts on an ECE crossmember? I'm assuming it will give the same benefit......
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-10-2011, 01:53 PM | #11 |
Correct. Mine are swapped.
01-10-2011, 01:57 PM | #12 |
Cool. Looks like I'll have to drill a couple extra holes. Do you have any pics?
01-10-2011, 02:02 PM | #13 |
Page 21 of my build thread in the 60-66 section. Posts 506 & 508 have some closer shots of the brackets flipped.
01-10-2011, 08:03 PM | #14 | |
Anti-squat is good........... FREE IS ALSO GOOD!!! |
01-10-2011, 08:37 PM | #15 | |
01-10-2011, 09:08 PM | #16 | |
I was working my way backward from the arm mount page so I wondered what the heck the plate was behind the mounts... until I saw you were relocating the axle position. So much to think about, am I glad I found this site?!! With a little luck maybe I'll build this thing right this time. Is there a build thread on your 68? I'd like to see that raised x-member as well. Steve |
01-10-2011, 09:24 PM | #17 | |
Basically, I cut the rivets out of the 'upper' portion on the OE shock x-member so it could be removed. The upper portion of the shock x-member is riveted just under the top lip of the frame rail. It is also riveted to two lower flanges (one on each side L&R) that are riveted to the bottom lip of the frame rail. I then bolted it back into place & marked the edge of the bolts where the upper & lower flanges come together. I cut the upper flange pieces off where I scribed the lines (cut straight across scribe mark to scribe mark; L & R sides). I then welded a piece of 3" angle to the upper piece on each side (L&R) & in turn welded the two flange pieces to that. This effectively raised the upper shock mounting position 3". Once it was fully welded, I was able to bolt it right back in like it originally was installed.
01-10-2011, 09:56 PM | #18 | |
That entire area was rotted on my 69' including the spring perches so I cut everything out, repaired the C channel, plated it on all three sides and boxed everything in. To replace the OE shock X-member I fabed an "H" member from square tubing, fully welded it into the C channel boxing plates, and hung the stock upper shock brackets from that. My mistake was locating the H-member so that the upper shock mounts were in the OE location. So I'll either relocate the H-member, or work some trick brackets off of it depending on how things line up. I like the idea of raising the mounts to get longer shocks on it. |
01-10-2011, 11:22 PM | #19 |
You could basically cut & raise it just like I did the OE x-member.
It looks like you have 2 pieces of tubing running across the frame from side to side w/2 shorter pieces running front to rear to tie them together. Cut the longer pieces just outside of where the shorter pieces attach. Use some angle steel & weld it to the center section after raising it the desired amount. Keep in mind the bed floor will need to be raised or a notch made to clear the x-member (I planned to raise the entire floor).
01-11-2011, 11:17 AM | #20 | |
Bed clearance issue: Right now I have tons of room because I have an 89’ step side bed on it. With these beds, in order to get the reveal with the cab correct you raise the entire bed up on brackets. I do plan on swapping out to a stock stepside bed however. Sounds like I won’t have the clearance with the stock bed to raise the x-member? It’s been so long since I had a stock bed on it that I don’t remember the relationship between the top of the rail and the bed floor, pretty tight huh? Didn’t really want to get into raising the bed floor. |
01-11-2011, 11:31 AM | #21 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-11-2011 at 11:31 AM. |
01-11-2011, 12:15 PM | #22 | |
I suppose you just weld or bolt a piece of angle to the front panel to support the wood? Smooth panel would end up looking nicer as on a stocker you'd mess up the reveal. Only thing I can't picture is what you do with the rear cross sill? Section it? |
01-11-2011, 12:45 PM | #23 | |
01-11-2011, 01:04 PM | #24 | |
The only pieces I saved from the OE bed were the rear cross sill, fenders and steps. Been watching the parts board but I think I'm just going to bite the bullet and buy new from Mar-K. I'll have enough to do with the chassis work and reworking the cab sheet metal. My OE steps and rear fenders need a lot of work as well. |
01-11-2011, 03:31 PM | #25 | |
