Old 01-26-2011, 03:28 AM   #26
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Re: 2wd lift and new 18's w/ 33x10.5 Nittos
Originally Posted by packratcffc View Post
Thank you for all the info!!
Are the 1ton arm 73-87 or 88-98? Did you do uper and lower or just lower?
Lookin at your link to your pics. I see your tack/fuel gauge is that an OEM? Where did you fined it?
I think I have got all I need to do this,I may not get all the part until this summer I have been waiting for years to do this,you have been a great help!!!
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
73-87 1 ton lower arms, 1/2t upper arms.
The tach came from ebay.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 02-07-2011, 11:15 PM   #27
Justins76
Justins76's Avatar
Got it aligned. They used almost no shims but got it in spec. I had to change how the brake hose attached to the control arm because it was pulling tight on turns. Also had to trim the fender at the front because of the tread rubbing going over bumps with the wheels turned. With my digital level, I get about .1-.2° angle down in the front. Ride is smooth on the freeway and curbs are easier to hop
My cardomain page
Old 02-07-2011, 11:15 PM   #28
Justins76
Justins76's Avatar
18x8" Chevy 6 lugs wheels off a new Z71
Nitto Terragrappler 33x10.50
Rear 2.5" Rancho lift blocks
Bilstein 5100 extended shocks
Front-
88-98 Rough Country lift spindles
88-98 Raybestos PG ball joints
88-98 C2500 LD 6 lugs rotors and calipers
Moog 6454 HD springs.
Belltech 1 3/8" sway bar
73-87 C30 lower A-arm
73-87 C10 upper A-arm
One problem I ran into was the 88-98 outer tie rods connect to the spindle from underneath and caused interference with the sway bar. I do not know if this would be a problem with the stock sway bar. Since the tie rod joint is smaller then a 73-87, what I did was get a taper reamer from summit and reamed it from above and used the stock tie rod.
The brake hoses are from a 88-98 and they connect to the frame differently. If you clock them just right, they will fit into the hole in the frame and use a horseshoe shaped clip to hold it in.
The spindle, rotors, bearings, calipers, pads, ball joints and hoses I used were from a 1994. The rest is stock 73-87 parts, with 1 ton lower control arms.
You have to use 88-98 rotors and calipers. Since the 88-98 ball joint is bigger, it wont fit 1/2 ton arms. I'm using 88-98 Raybestos PG (formerly Spicer) ball joints.
My cardomain page
Old 02-07-2011, 11:15 PM   #29
Justins76
Justins76's Avatar
For the rear I used blocks and longer shocks with 4wd axles since I'm using 6 lug wheels.
Rear
Rancho 2.5"lift blocks
My cardomain page
Old 02-07-2011, 11:30 PM   #30
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Justins76 View Post
18x8" Chevy 6 lugs wheels off a new Z71, Nitto Terragrappler 33x10.5. Rear 2.5" Rancho lift blocks with Bilstein 5100 extended shocks.
Front-
Trying to format this for an FAQ
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-07-2011, 11:36 PM   #31
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
AWESOME!
Could this be done on a 67 72?...
John
1999 Toyota Tacoma 4x4
Old 02-07-2011, 11:50 PM   #32
Justins76
Justins76's Avatar
Originally Posted by oldblue1968chevy View Post
AWESOME!
Dont see why not. Its just like converting to a 73-87 front suspension except you use 88-98 spindles and brakes. Plus side is you can pick either 5 or 6 lug rotors from any parts store.
My cardomain page
Old 02-08-2011, 12:04 AM   #33
N2TRUX
Happy to be here
N2TRUX's Avatar
Now I want to go buy a LWB truck just to do this to.
Articles-
"Refining Sierra"
Old 02-08-2011, 12:05 AM   #34
doc70sub
doc70sub's Avatar
I want to do this to my Suburban!!
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 02-08-2011, 12:29 AM   #35
3r!c84
Badass
3r!c84's Avatar
what brand headers are you running bud?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-08-2011, 12:55 AM   #36
Dads79GMC
Dads79GMC's Avatar
This thread has me spinning. I don't know what to do; the possibilities are endless.
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 02-08-2011, 10:38 AM   #37
Prerunner1982
Prerunner1982's Avatar
Justin.... THANK YOU for posting this information. This has come up a time or two and nobody here had done it so a write up wasn't available. Someone was in the process but either hasn't finished or hasn't come back to the forum. You have helped quite a few people and you will probably get quite a few questions in the future so I hope you will stick around.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-08-2011, 11:28 AM   #38
SCOTI
SCOTI's Avatar
The previous attempt I remember was using FabTech stuff. Since those parts are hard to come by w/the company no longer in existence, this is a great (better) alternative. I'm thinking pre-runner looking 68 short fleet w/truck arms .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-08-2011, 09:15 PM   #39
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Every once in a while I eye up the CrewCab and think about this. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 02-08-2011, 10:17 PM   #40
N2TRUX
Happy to be here
N2TRUX's Avatar
Now that would rock.
Articles-
"Refining Sierra"
Old 02-08-2011, 10:22 PM   #41
SBTork
Garage wrench
SBTork's Avatar
im thinking the same. I really considered it for my '86 C-10 before I got rid of it. Really good job, I think you've nailed the stance.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-09-2011, 01:35 AM   #42
Justins76
Justins76's Avatar
Hedman elites.
My cardomain page
Old 02-09-2011, 01:37 AM   #43
Justins76
Justins76's Avatar
I am currently working on a spreadsheet with all the part numbers. I will also be posting pics with height dimensions.
Click image for full size view(last update 2/14/11)
My cardomain page
Old 02-09-2011, 02:13 AM   #44
69C20CUSTOM
69C20CUSTOM's Avatar
This is way to cool. I really want my C10 back now LOL.
And like doc70sub said it would be to cool on a old burb.
2003 Nissan Frontier Crewcab 4x4-Daily
1982 Chevy Suburban 3/4ton 4x4, Mud Toy
Lookin for a C10
69C20CUSTOM is offline   Reply With Quote
Old 02-09-2011, 02:28 PM   #45
packratcffc
packratcffc's Avatar
That spreadsheet helps alot!!
Thank You!
1988 V-10 Sub
1976 C-10
1971 El Camino
1968 Chevy C-10
packratcffc is offline   Reply With Quote
Old 02-15-2011, 12:11 AM   #46
Justins76
Justins76's Avatar
Some dimensions with a tape measure.
My cardomain page
Old 02-15-2011, 01:15 AM   #47
packratcffc
Very cool thanks for the numbers!!!!!
1988 V-10 Sub
1976 C-10
1971 El Camino
1968 Chevy C-10
Old 02-15-2011, 11:34 AM   #48
N2TRUX
Happy to be here
N2TRUX's Avatar
This post is now in the forum FAQ- "73-87 2wd lift with 33x10.5x 18 Nittos"
Articles-
"Refining Sierra"
Old 02-15-2011, 03:45 PM   #49
Prerunner1982
Did hell freeze over? You mean lifted 2wds are getting some respect?
@N2Trux: Thank you sir.
Jon
Oklahoma Roll Call
Old 02-15-2011, 03:51 PM   #50
85gmc2tone
props man that looks cool and its functional
85gmc2tone is offline   Reply With Quote
