Old 01-22-2011, 10:41 PM   #1
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
2wd lift and new 18's w/ 33x10.5 Nittos
This post is now in the forum FAQ- "73-87 2wd lift with 33x10.5x 18 Nittos"
18x8" Chevy 6 lugs wheels off a new Z71, Nitto Terragrappler 33x10.5. Rear 2.5" Rancho lift blocks with Bilstein 5100 extended shocks. The front has 88-98 Rough Country lift spindles. I'm using the Moog 6454 HD springs. I will have to see if I can get it aligned with them, but the tops of the tires are angled out some. May have to put in shorter springs to get the correct camber. Here's how it looks so far.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 01-22-2011, 10:52 PM   #2
rixjohnson
Re: 2wd lift and new 18's w/ 33x10.5 Nittos
Lookin good
rixjohnson is offline   Reply With Quote
Old 01-22-2011, 11:20 PM   #3
Dalaigh
Canadian Trucker
Dalaigh's Avatar
That 4" lift kit for the 88-98 looks way more impressive on the 73-87! Looking good
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 01-22-2011, 11:47 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Beefy! I like that a lot...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-23-2011, 02:13 AM   #5
packratcffc
packratcffc's Avatar
Can you post some close up pics. of the suspenion front and rear I have been looking to do this for a long time to my 76 C-10?
Why the 6lug? Did the stock 5lug hubs not work with the lift?
Did the 88-98 spindles fit or did you have to make some mods. ie brakes,tie rods, or brake lines??
Why the new front sway bar? Did the stock one not work?
What is your final height to the top of you door handle?
Any extra details or part numbers would be great!!
THANK YOU!
1988 V-10 Sub
1976 C-10
1971 El Camino
1968 Chevy C-10
packratcffc is offline   Reply With Quote
Old 01-23-2011, 02:46 AM   #6
3r!c84
Badass
3r!c84's Avatar
looks good!!! wow. do some body work and do a quicky paint job. that truck will look killer!!
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-23-2011, 10:59 AM   #7
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
That looks great man... you may just have started a new trend for others.
CLASSIC87' is offline   Reply With Quote
Old 01-23-2011, 11:29 AM   #8
mooseknuckles
mooseknuckles's Avatar
looks great and I like the wheels.
mooseknuckles is offline   Reply With Quote
Old 01-23-2011, 11:38 AM   #9
doc70sub
doc70sub's Avatar
Looks great.....
1970 Sub C-10 - 350/TH-350/3.73 12-bolt
Came home from the hospital in it & mine ever since.
1966 Catalina Ventura 2-door fastback 389/TH400
doc70sub is offline   Reply With Quote
Old 01-23-2011, 06:26 PM   #10
dlhughes2005
awesome...............now you got me thinking of changing my own truck plans!
85 GMC SWB: Fuel Injected 454, TH400, soon to be laying frame on 22s
96 Trans-Am: Full bolt-ons, Weld Rodlite skinnies and fatties
95 GMC Yukon 4x4: 2door all stock with the exception of glasspacks and duals
dlhughes2005 is offline   Reply With Quote
Old 01-23-2011, 08:08 PM   #11
bitchin85
bitchin85's Avatar
that looks awesome man. its just wha i want to do to my 2wd. id lift the back just a tad more but deff looks sweet!
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 01-23-2011, 09:20 PM   #12
Aegeas
See, now this looks good. The low-rider isn't my bag. I need a truck to be functional in addition to looking good
Aegeas is offline   Reply With Quote
Old 01-23-2011, 09:27 PM   #13
SCOTI
SCOTI's Avatar
I like almost anything w/wheels. I like semi lifted trucks over the extreme sky-scaper rides that look like they'd tip over if taking a turn over 2mph. That being said, who says 'low-riders' aren't functional?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-23-2011, 09:34 PM   #14
BIG V
yes please more details i have been looking for spindles for a 2wd burb i have for a bit now
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 01-23-2011, 09:49 PM   #15
Aegeas
I stand corrected
My version of functional usually has 5000 lbs in the dump bed.
Old 01-23-2011, 09:55 PM   #16
SCOTI
SCOTI's Avatar
I stand corrected
It's all in how you build them .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-23-2011, 10:33 PM   #17
glhman222
please post on how to do this
ive done hours of research with nothing but dead ends
i have a 79 lwb im trying to lift and need to know how you did this
THANK YOU!!!!!!! ps someone should sticky this when he answers
1979 Chevy C10 Longbed
glhman222 is offline   Reply With Quote
Old 01-23-2011, 10:36 PM   #18
Justins76
Justins76's Avatar
THANK YOU!
You can use 5 lug discs. I used the C2500 LD 6 lugs because my wheels are 6.
The sway bar is a 1 3/8" belltech I've had for years. One problem I ran into was the 88-98 outer tie rods connect to the spindle from underneath and caused interference with the sway bar. I do not know if this would be a problem with the stock sway bar. Since the tie rod joint is smaller then a 73-87, what I did was get a taper reamer from summit and reamed it from above and used the stock tie rod.
The brake hoses are from a 88-98 and they connect to the frame differently. If you clock them just right, they will fit into the hole in the frame and use a horseshoe shaped clip to hold it in.
The spindle, rotors, bearings, calipers, pads, ball joints and hoses I used were from a 1994. The rest is stock 73-87 parts, with 1 ton lower control arms.
My cardomain page
Old 01-23-2011, 10:37 PM   #19
Justins76
Justins76's Avatar
For the rear I used block and longer shocks with 4wd axles since I'm using 6 lug wheels.
My cardomain page
Old 01-23-2011, 10:38 PM   #20
Justins76
Justins76's Avatar
Smile Re: 2wd lift and new 18's w/ 33x10.5 Nittos
Thanks everyone for the compliments.
My cardomain page
Old 01-23-2011, 10:59 PM   #21
packratcffc
Thank you for the pics. and info!!
Few more questions....
Do you think the 73-87 hubs and calipers will fit the lift spindels?
Why the 1ton lower arm? Is there a problem with the fit of the 1/2ton arms?
What ball joints did you end up using?
Sorry to ask so many question but Iam going to do this to my C-10.Iam on unemployment right now so Iam going to have to buy one thing at a time,but when Iget the build going I will post some pics.
THANK YOU AGAIN THIS HAS BENN A GREAT HELP!!!!!!!!!!
1988 V-10 Sub
1976 C-10
1971 El Camino
1968 Chevy C-10
Old 01-23-2011, 11:01 PM   #22
glhman222
im grinning as wide as i can and i also made a word document with all the pics and instructions
Old 01-23-2011, 11:38 PM   #23
78 Chevyrado
Looks Great man! Looks tough!
78 Chevyrado is offline   Reply With Quote
Old 01-24-2011, 10:08 PM   #24
Justins76
Justins76's Avatar
You have to use 88-98 rotors and calipers. Since the 88-98 ball joint is bigger, it wont fit 1/2 ton arms. I'm using 88-98 Raybestos PG (formerly Spicer) ball joints.
My cardomain page
Old 01-25-2011, 01:30 AM   #25
packratcffc
Thank you for all the info!!
Are the 1ton arm 73-87 or 88-98? Did you do uper and lower or just lower?
Lookin at your link to your pics. I see your tack/fuel gauge is that an OEM? Where did you fined it?
I think I have got all I need to do this,I may not get all the part until this summer I have been waiting for years to do this,you have been a great help!!!
THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1988 V-10 Sub
1976 C-10
1971 El Camino
1968 Chevy C-10
