Old 01-24-2011, 04:56 PM   #26
robnolimit
robnolimit's Avatar
Re: Drop member V3- Scotts bolt in front-
Originally Posted by porterbuilt View Post
Guess I better hold off on my square body and see if I can't get a 67-72 together by then. That's gonna be a tough time-line for me. But we will do our best. Can I bring a blazer?
Blazer is OK, we're just trying to keep the contenders as even as possible.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-24-2011, 05:04 PM   #27
PBFAB.COM
PBFAB.COM's Avatar
I think I misunderstood... maybe it's because I associate Rob with "performance"... It's to showcase all suspensions, right? I will have to confirm with the owner, but I will just bring Old Aux. It's not a hard-core performance suspension system... but it will give some variety to the event.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-24-2011, 05:20 PM   #28
tech@scottshotrods
Originally Posted by SCOTI View Post
Among the first meaning after Jim Meyers & PB's C4 Dropmember.
I bought a C4 DM in 2007 after looking into JM's x-member. I didn't buy the JM piece because like Scotts, it uses smaller 11" brakes as standard equipment.
correct standard equipment we do have 12", 13" and 14" plain or drilled and slotted 4 or 6 piston calipers available
tech@scottshotrods is offline   Reply With Quote
Old 01-24-2011, 05:42 PM   #29
tech@scottshotrods
Definitely don't want this thread to turn into something other than information and a comparison of facts between two similar products. As Jon mentioned, we are friendly... we have spoken on the phone at least a dozen times. He can buy me a pink lemonaide or a Mountain Dew whenever he wants!
Fact and opinion are two different things.
Fact: Porterbuilt and Scotts both make IFS kits for the C10.
Fact: There are numerous differences between the two kits.
Opinion: Nate is better looking than Jon
If you are researching a front kit for your C10... do your homework. Find the one that is best for you and what you want to accomplish. Call the various companies that make the product and discuss all your questions and concerns. It's an investment any way you go, so make sure it is one that you are comfortable making. Don't let somebody else make the decision for you.
this opinion may also be fact with your boyish good looks but I know some old school g funk pimps so its all about who you know....
pic of me and said pimp
As for Robs event get me dates as long as it doesn't interfere with our show schedule we should be able to get some thing together
Old 01-24-2011, 05:47 PM   #30
tech@scottshotrods
Originally Posted by crawdadfox View Post
After doing a TCI Mustang II setup on my 62 Nova i was wondering if strength would be an issue when using Mustang II parts on a fullsize 1/2 ton truck.
all we are using is the spindle, and it is more than durable enough to support the weight of any motor installed
Old 01-24-2011, 05:47 PM   #31
PBFAB.COM
PBFAB.COM's Avatar
Nice pic!
Were you seeing if he could set you up with a "date" for the night? Or was he just looking for some air ride to help him clear is 30's?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-24-2011, 06:13 PM   #32
tech@scottshotrods
Nice pic!
Were you seeing if he could set you up with a "date" for the night? Or was he just looking for some air ride to help him clear is 30's?:lol:
ding ding ding lmao you're good I was wearing one of my air ride hats and he asked me about air lifts for his caddy
Old 01-24-2011, 07:40 PM   #33
bigguy
Question to both.... For LSX equipped trucks running the stock truck oil pan, will there be any issues with the oil pan touching ground before the truck is laid out?
bigguy is offline   Reply With Quote
Old 01-24-2011, 07:50 PM   #34
Scottshotrods
With ours there is no problem.
Justin
Scottshotrods is offline   Reply With Quote
Old 01-24-2011, 08:10 PM   #35
PBFAB.COM
PBFAB.COM's Avatar
The factory truck pan does hang down quite a bit... I recommend switching over to an F-body oil pan and pick-up tube (camaro, firebird, trans am 1998-2002) to eliminate ground clearance issues. You can run the windage tray from the truck pan with a slight modification... but the oil pan and pick-up are a must change.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-24-2011, 08:18 PM   #36
Scottshotrods
You can also get the corvette pan as well it is the lowest profile pan for the ls motors.
Old 01-24-2011, 08:30 PM   #37
PBFAB.COM
PBFAB.COM's Avatar
The Corvette pan may work on the Scott's kit, but I want to clarify that it is NOT compatible with a Dropmember. It has "batwings" that stick out on each side of the pan that cause other clearance issues/concerns.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-24-2011, 09:42 PM   #38
bigguy
Awesome! Thanks for the info. Time to decide......
Old 01-24-2011, 09:53 PM   #39
jmedero
jmedero's Avatar
Heck yea Nate... Square body... First I'm hearing of that. Lol. Blazer... Tour holding out on us master yoda. Clyde65 no conflict, just LOTS of information from two very talented company's.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-24-2011, 10:08 PM   #40
jmedero
jmedero's Avatar
"Clear his 30's" now that's funny, cause you know it's true.
John let's see the sleeve! Nice tatts, I've been trying to contain myself... I have a few but want so many more.
Guys just let me say thank you for all the information. I know you both are very busy and I appreciate all your time and info on your products.
Old 01-25-2011, 12:51 AM   #41
c10seconds
c10seconds's Avatar
Sweet thread
c10seconds is offline   Reply With Quote
Old 01-25-2011, 01:38 AM   #42
SCOTI
SCOTI's Avatar
I'm curious.... I've installed more than one Dropmember so I'm slightly familiar w/that but what is it going to take to connect the end of that rack on the Scott's x-member in the pic to a column?
That angle looks pretty severe from my monitor??? 2 joints & the shaft or what?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-25-2011, 02:22 AM   #43
jmedero
jmedero's Avatar
I agree c10seconds. So much info in one thread.
Old 01-25-2011, 02:26 AM   #44
Scottshotrods
Scott,
In my personal 65 burb I am building I have a big block in the truck and I am running a power rack.The column is a ididit column and I have 3 steering u-joints installed.
rack is a 3/4 36 /3/4 d/d
frame mid mount is a 3/4 x 3/4 d/d
Then I have a 3/4 hime to keep the d/d shaft stable.
End of the column I am running a 1 inch x 3/4 d/d u-joint.I am ruuning 3 u-joints to keep it away from the headers I am installing.It will work with
two u-joints if you wanted to run exhaust manifolds only.
Justin
Old 01-25-2011, 02:42 AM   #45
SCOTI
SCOTI's Avatar
Ahh.... I didn't notice it earlier. But when I looked @ the pic again, I was thinking it looked like the R&P shaft exited below the lower plain of the frame rail & would need a 3-joint set-up. What do you supply w/the kit to mount the 3/4 stabilizing heim to (hard to tell in the pics from that angle) or is that a 'per application' deal?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-25-2011, 02:55 AM   #46
Scottshotrods
Ahh.... I didn't notice it earlier. But when I looked @ the pic again, I was thinking it looked like the R&P shaft exited below the lower plain of the frame rail & would need a 3-joint set-up. What do you supply w/the kit to mount the 3/4 stabilizing heim to (hard to tell in the pics) or is that a per application deal?
We can offer it with all parts needed to hook up the stock column to our rack.
We can set them up with a complete bolt on 3/4 hime and bracket that will bolt in place and we have a weld in bung as well.If the customer wants to weld it in place.We really try to listen to our customers to see what there
abilities are as most people probally know some people have more skills than others.
Today was a perfect example sold two bolt in ifs for c-10 trucks.Then one of
our old customers called us up and wanted our weld in ifs for the c-10 truck.
We have been making that version for several years now as well.Like I said
go figure we are here to service all people and shops out there.I will say myself Porter built has a nice product by all means and Jim meyers does to.
There is room for all of us out here and I will say I am very proud to say that all of our products we make and machine we do in house.I am not saying we are better by no means at all.I am saying we have a good product and a fair price for the general public out there for the people who want to buy a complete hub to hub kit with tubular a-arms.For the guys who want to run the stock gm arms Porter built is the way to go.
Justin
Old 01-25-2011, 01:07 PM   #47
robnolimit
robnolimit's Avatar
I have to agree with Justin that there is room for all of us. Different people want different things. Smooth ride, lay frame, killer handling, pricing, ease of installation, what is most important to you? For comparison, can you guys post some specs? Track width, roll center, ground clearance gain, drop from stock, or spindle pin height in relation to the frame rail, total suspension stroke..... I think it help people choose the best IFS kit for them. Thanks for the input.
Old 01-25-2011, 02:24 PM   #48
PBFAB.COM
PBFAB.COM's Avatar
I am currently putting together a document that includes this information to be published on my new website I am building. I will have all the information published here shortly and will post a link.
Rob... I think you are making it a little crowded over here, might want to go somewhere else. I heard the import scene could use a guy like you!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-25-2011, 02:28 PM   #49
jmedero
jmedero's Avatar
My little sisters hyundai accent needs some new a arms and drop kit. Get to it Guys!! Lol
Old 01-25-2011, 02:56 PM   #50
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Nothing like a good handling Accent!
JNJchev77 is offline   Reply With Quote
