03-15-2011, 08:16 PM | #26 |
A320 Pilot/USAF Retired
Re: 57 Step Side
WOW! Frame looks great, should make for a very nice ride!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
03-19-2011, 04:05 PM | #27 |
Re: 57 Step Side
Fabricated trans mount brackets and tacked them in today,meassured for drive shaft and will get that next then i can tear down and paint the frame.
03-19-2011, 11:59 PM | #28 |
Re: 57 Step Side
I like the trans cross member.
Kim |
03-30-2011, 04:43 PM | #29 |
Re: 57 Step Side
driveline complete with new driveshaft looks like i can do the tear down and paint the frame now.
03-30-2011, 05:12 PM | #30 |
Certified Car Nut
Re: 57 Step Side
Looks great.
04-09-2011, 05:03 PM | #31 |
Re: 57 Step Side
Well it's off for a powder and should be back next week for final assembly.
04-20-2011, 08:22 PM | #32 |
Re: 57 Step Side
Got lucky ,slide the frame under the body for the first time and the cab bolts line up.Finally going to be bolting things on that i don't have to take off again !!!!
04-20-2011, 09:13 PM | #33 |
Re: 57 Step Side
Nice!
04-21-2011, 12:38 AM | #34 |
Re: 57 Step Side
X2.
Kim |
04-21-2011, 10:16 AM | #35 |
Certified Car Nut
Re: 57 Step Side
looks great.
04-21-2011, 09:29 PM | #36 |
Re: 57 Step Side
Thanks again for all the props.Had oringnally brought the 12" slotted rotor kit but the smoothie wheels didn't fit,so i had to buy another kit with smaller rotors.If you know anyone getting ready to buy a rear disc brake kit and looking for a buy send me a PM .
05-05-2011, 07:32 PM | #37 |
Re: 57 Step Side
Setting up new column and joints and it works,I turned the steering wheel and the front end actually turns
05-05-2011, 08:25 PM | #38 |
Re: 57 Step Side
Looking good candyx.
Kim |
05-05-2011, 08:35 PM | #39 |
56 - autocross
Re: 57 Step Side
How come you had to go with two joints? I am headed down the same road and was wondering.
05-05-2011, 08:48 PM | #40 |
Re: 57 Step Side
Thank You,progess has slowed up abit.I'm hoping to have the wheels on this weekend.Got to get the cab to my shop to weld up all the hole in the firewall and floor,its amazing how many drilled holes there are after 53 years of use.Plus i have to repair the bottom of the cowl vents inner and outer from all the dirt and leaves that were stuck in there.
05-05-2011, 09:00 PM | #41 |
Re: 57 Step Side
I needed a joint on the rack just to point it towards the steering wheel and keep it as tight as possilbe tight to the frame rail and close enough to tie it back to the frame for the shaft support.The second joint then made everything line up to the steering column,would of been nice if they would make a rack for this application so you could run a straight shaft up to the column.
05-21-2011, 10:07 PM | #42 |
Re: 57 Step Side
fixed first cowl panel one to go,still welding up holes which go on forever it seams
05-22-2011, 02:34 AM | #43 |
56 - autocross
Re: 57 Step Side
Looking Good! How did you mount your brake booster and what pedal set up are you going to use?
05-22-2011, 09:48 AM | #44 |
Re: 57 Step Side
Its from CCP had to remove the stock support under the dash which was very easy.Then you just drill 2.5" hole and the a flange fits on the firewall side with 4 small bolts.Comes with the drop pedal and new bracket to replace the one you had to remove.Very nice set up i'll have to say and took less then 30 minutes to install.I also installed a Lokar gas pedal and got the brake pedal to match.
05-22-2011, 12:21 PM | #45 |
56 - autocross
Re: 57 Step Side
any pics of the pedals and install?
05-23-2011, 07:17 PM | #46 |
Re: 57 Step Side
05-23-2011, 07:42 PM | #47 |
56 - autocross
Re: 57 Step Side
Very Nice. Thanks
05-30-2011, 07:53 PM | #48 |
Re: 57 Step Side
I think i have an acceptable amount of holes now,what all those holes were used foris puzzling.I can see if you were caught in a flood and wanted your truck to drain fast then yes all those holes would work well.
Holes 1.Steering Column 2.Brake Booster 3.Hood Hinges 4.Battery Bracket |
05-30-2011, 08:10 PM | #49 |
Re: 57 Step Side
Nice build!
Does anybody know what holes are factory and ones that may have been added later? |
05-30-2011, 08:42 PM | #50 |
Re: 57 Step Side
Some of the holes would have been there for the wiring to pass through.
Kim |
