#26 |
Re: Whats this wire for?
this is cool!!, bruce88 i think your spot on! i went out eariler and saw the same wire on my 72 donor truck, but didnt on my 69, bad thing on mine it was cut at the engine near the dist L-6 eng, so i didnt know where it went myself,,,it is the brown/wire wire.it splices at the connector and goes to a relay mounted on the firewall above the bulkhead connector..good job...bruce88 and the forum....don
#27 | |
![]() Join Date: Oct 2008
The 141 circuit is powered thru the TCS/radio fuse on the fuse block when the key is on. This is based on a 1972 Chevy truck wiring diagram.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
#28 |
Moderator
![]() Join Date: May 2007
This was one of my guesses as well. I pulled my truck apart, put it all back together...and have this same wire that is "left over". I don't remember it attaching to anything prior to disassembly...it may have been tucked into the harness. It is not for the brakes. The trans kick down switch is on the gas pedal and the harness it attaches to is separate and goes directly to the TH400. My truck runs fine, no electrical problems, so it doesn't go to anything "important" as far as I can tell. 12 volts flow through it when the ignition is on, so it is a keyed source. The wire is very thin gauge, so I suspect it doesn't power anything that requires high amperage. It is solid brown also, but the TCS diagram makes sense to me. Where is the TCS located? I am currently using this wire for the electric choke on my Edelbrock...it plugged right in
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#29 |
what year is your truck in 1968 the kick down switch was at the carb linkage
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 02-09-2011 at 02:59 AM. |
#30 |
Moderator
72
