02-08-2011, 06:30 PM | #1 |
Whats this wire for?
I'm replacing my underhood wiring with a new wiring harness and don't recall where or what this brown wire plugs into? It's not the brake pressure plug, it's on the other side running out of the wires and has a different plug?
02-08-2011, 06:44 PM | #2 |
Re: Whats this wire for?
Not sure what it does but it pluge in to a wire that comes out of a gromet with 4 other wires that go uneder the dash i would like to know what it is for also
02-08-2011, 07:34 PM | #3 |
Old Duffer
If it's run the other way, will it reach the heater fan motor? (Just a SWAG)
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
02-08-2011, 07:37 PM | #4 |
Moderator
I was wondering what that wire is for too. power goes to it when the ignition is on...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-08-2011, 07:44 PM | #5 |
02-08-2011, 07:46 PM | #6 |
that wire isnt even on mine.. ran out and check.
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 |
02-08-2011, 07:49 PM | #7 |
It's for the brake light warning that comes on in the cluster. It plugs in by the master cylinder on the porportioning valve. If it's like mine then it's a little to short and I had to add some wire
Posted via Mobile Device |
02-08-2011, 07:57 PM | #8 |
It's not part of the 72? anti transmission knock down shift carb fouly thingee by any chance? (there's something in that area on 72s I think that gets "eliminated" by everyone.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
02-08-2011, 07:57 PM | #9 |
68custom396, I disagree. That wire that you describe has a round rubber shield around it. I think the one in the picture is for the "Transmission Spark control" that some of the trucks had. Some of the other holes in the picture may be concerned also.
02-08-2011, 07:59 PM | #10 |
Moderator
nope, that is a different wire
02-08-2011, 08:00 PM | #11 |
Nope, I have a plug for that one and it reaches the proportioning valve just fine. Still a mystery???
02-08-2011, 08:01 PM | #12 |
Moderator
I think we have a winner...
02-08-2011, 08:07 PM | #13 |
I've got the same wire and it's not attached to anything. I have a 72 GMC.
-Scott- |
02-08-2011, 08:08 PM | #14 |
That's right I do recall tucking that wire back into my rail now that I think about it. Thanks to all for being so quick to correct me lol
02-08-2011, 08:22 PM | #15 |
I went out and snapped this on my droid real quick. I think a lot of people disconnect this wire because it malfunctions and causes a light to stay on all of the time. Someone can clarify for me here? I can ask my dad when I get a chance, he's the one who disconnected it for that reason. This is on a 1972 Custom 10 3 speed on the tree 250 6 cylinder motor.
02-08-2011, 08:24 PM | #16 |
I have a new powerbooster/master cylinder from CPP and the porportioning valve is mounted a lil different than stock plus the connector is different. Just incase anybodys was wondering why I added wire
02-08-2011, 08:27 PM | #17 |
its all about the +6 inches
the spark control thing is a seperate add onharness (started in 69 or 70)... that's not part of it.
02-08-2011, 08:40 PM | #18 | |
-Scott- |
02-08-2011, 08:45 PM | #19 |
Moderator
x 2.
02-08-2011, 08:47 PM | #20 |
I know for a fact that it is not the wire that goes to the brakes. Here is a pic of both wires and plugs side by side.
02-08-2011, 08:58 PM | #21 |
would that wire be for a tranny kick down power for a turbo 400?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
02-08-2011, 09:04 PM | #22 |
Moderator
Nope. I have that too, it is separate.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 02-08-2011 at 09:04 PM. |
02-08-2011, 09:17 PM | #23 |
What?
Under hood light?
I seem to remember there was a little lamp that attached to the fender, and you would twist it apart from the mount on the fender. Then it had a long cord with a light at the end, and you could use it to look around the engine compartment. I actually have one of these, though it is not set up on my burb. It's probably in one of my bins of spare parts buried. What about cruise control? Just pulling guesses out my...
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 02-08-2011 at 09:18 PM. |
02-08-2011, 09:58 PM | #24 |
I think its for the TCS circuit
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544 |
02-08-2011, 11:43 PM | #25 |
Just Not Low Enough!
i dont see a white trace on it. (according to the diagram).
where does the wire go? stub at the bulkhead connector? in the cab somewhere? sorry if it was stated, my eyes are tired and i didnt want to read..
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
