Old 06-09-2011, 12:12 PM   #26
kieth
kieth's Avatar
Re: 63 GMC Short Fleet
both.........
kieth is offline   Reply With Quote
Old 06-11-2011, 08:53 PM   #27
LakeShow24
good work. those valve covers were NICE!!
LakeShow24 is offline   Reply With Quote
Old 06-27-2011, 02:33 PM   #28
63gmcguy
63gmcguy's Avatar
OK I finaly got to work a little on my pickem up, got the c notches welded and bolted in I got my rear flip kit installed gonna put the rear back under the frame and see how much it lowered it I'm hopping for 6-7"
63gmcguy is offline   Reply With Quote
Old 06-27-2011, 02:48 PM   #29
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 63 GMC Short Fleet
Welcome from North Cackalacky !
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-30-2011, 11:36 AM   #30
63gmcguy
63gmcguy's Avatar
ok got the rearend flipped and back under the truck, set the bed on it to see, it dropped it about 7" now on to the front
Old 07-18-2011, 03:27 PM   #31
63gmcguy
63gmcguy's Avatar
ok got a little more work done this is the 84 heavy half cross member, I only have to drill out 3 holes on each side all the rest line up perfect
Old 07-18-2011, 06:23 PM   #32
Doug19
Hey i'm planning on flipping my rearend on my 66 GMC. Have any pictures of the rear with the bed off? Also what did you end up having to buy to flip the rearend?
Doug19 is offline   Reply With Quote
Old 07-22-2011, 12:42 PM   #33
63gmcguy
63gmcguy's Avatar
I found these U shaped peices on ebay they fit under the perches of the rearend no welding. I had to use different U bolts and the peices that where on the 84 doner truck where the U bolts bolt to I dont know what ya call them, I used cpp frame notches that bolt in, I bolted and welded them if I wanna go lower I can do a lowering shackle for another inch, or blocks, but I pleased with the results. I will get a couple pics for ya
Old 07-22-2011, 12:48 PM   #34
63gmcguy
63gmcguy's Avatar
heres a pic of the flip kit simple bolt in
Old 08-10-2011, 11:17 AM   #35
63gmcguy
63gmcguy's Avatar
Well finally got a break from the heat started on the 84 crossmember and frontend. I got the pass side mioked up so far went together pretty easy
Old 08-23-2011, 09:48 AM   #36
63gmcguy
63gmcguy's Avatar
Hey has anybody tried to put a 69 camaro tank in? if so how did you do it
Old 01-30-2012, 08:02 PM   #37
63gmcguy
63gmcguy's Avatar
Well change of plans. Im not going with the SB350 and 700r setup. Im going with a 5.3ls fuel inj. with the 4l60e trans
Old 01-31-2012, 01:55 AM   #38
Captainfab
60-66 Nut
That's a wise decision IMO.
