Old 02-25-2011, 12:51 PM   #1
63gmcguy
63gmcguy's Avatar
63 GMC Short Fleet
Hello my first post. I am building a 63 GMC I bought for 1400 bucks drove it for a year. so far I have tore it apart!. the fun part. I am adding a 84 GMC front beem susp. big disk brakes, power steering, 10 bolt rear, 5 lug, fliped rear, drop spidles, older camaro column,350/700r4 any help would be great due to this is my first build thanks
63gmcguy is offline   Reply With Quote
Old 02-25-2011, 01:08 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 63 GMC Short Fleet
Cool! nice VC's also!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-25-2011, 01:25 PM   #3
63gmcguy
63gmcguy's Avatar
yeah I liked the 305, but I have already sold it, just really couldn't get the performance out of it. Plus it sucked gas like crazy
Old 02-25-2011, 02:03 PM   #4
Clyde65
Clyde65's Avatar
Oh I understand, they will run forever but suck gas and like you said no performance at all.
so what are you got planned for the power plant?
Clyde65
Rebuild of Clyde
support our troops!
Old 02-25-2011, 03:30 PM   #5
63gmcguy
63gmcguy's Avatar
Here is a pic of the donar truck now stripped to nothing
Old 02-25-2011, 03:33 PM   #6
63gmcguy
63gmcguy's Avatar
some pics of my teardown progress
Old 02-25-2011, 03:35 PM   #7
63gmcguy
63gmcguy's Avatar
Talking Re: 63 GMC Short Fleet
More to come this weekend if weather permits
Old 02-26-2011, 04:26 AM   #8
Vics63Chevy
Vics63Chevy's Avatar
Nice! I'll be watching your build as I too want to do a 350/700r4 combo in a 63 although mine's a chevy should be pretty similar I think? and I'm currently in process of swapping out the entire front end of the suspension with disc brakes from an 80 c10 with power steering so I'll be tuned in!
1963 Destiny Build Log
Vics63Chevy is offline   Reply With Quote
Old 02-26-2011, 10:35 PM   #9
63gmcguy
63gmcguy's Avatar
Your right not much difference rear suspension is about all
Old 02-27-2011, 01:43 AM   #10
Captainfab
60-66 Nut
Welcome to the forum
You're going about this the right way with buying a donor truck. You chould have most everything you need to update your GMC
Old 02-27-2011, 01:48 AM   #11
65GMCFirstride
65GMCFirstride's Avatar
Sounds like the drive train is really good. My truck is the same way all that i need to do is the metal work from here on out. Is your front grill in good shape?
65GMCFirstride is offline   Reply With Quote
Old 02-27-2011, 01:58 AM   #12
Corts60
Just here to tinker
Corts60's Avatar
Boy there are a lot of GMC guys that would kill for those valve covers. Great to see your building it the way you want it though.
Old 02-27-2011, 08:47 AM   #13
erock805
erock805's Avatar
Good luck and have fun!
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 02-27-2011, 11:42 AM   #14
paul63c10
nice grab man, enjoy! IMO i hate those valve covers.
not to hijack, but can you fit a 700r4 under the low hump in the cab?
paul63c10 is offline   Reply With Quote
Old 02-28-2011, 10:14 AM   #15
63gmcguy
63gmcguy's Avatar
Thanks for all the replies, hey Captinfab do you have any of your power steering adapters if so send me some info I need one
Old 02-28-2011, 10:23 AM   #16
63gmcguy
63gmcguy's Avatar
my grill is in pretty good shape, it has a couple of dings above the pass side headlight, not bad though, it needs a rechrome too, but my hood is another story lol.
Old 02-28-2011, 10:26 AM   #17
63gmcguy
63gmcguy's Avatar
hey paul i think it will, if not I will just do alot of cutting, I plan on some interstate driving and I want that overdrive
Old 03-01-2011, 01:19 AM   #18
paul63c10
i sure hope so!! i want to do the same thing. my powerglyde isn't giving my 350 justice.
Old 03-08-2011, 10:51 PM   #19
63gmcguy
63gmcguy's Avatar
Cool Re: 63 GMC Short Fleet
hey guys sorry no progress weather has been awful! As soon as it breaks I will be getting the front beam off and start prepping for the 84 beam
Old 03-08-2011, 11:23 PM   #20
62GMC
Amen brother! I'd walk over hot coals for those.
Mine are crap dented black and look like a train hit them.
62GMC is offline   Reply With Quote
Old 04-10-2011, 10:44 AM   #21
63gmcguy
63gmcguy's Avatar
Hey guy sorry no progress, on my tear down, I've had health issuses and im back, I've been working on the front end got the suspention off, lol PO welded the dang springs in it was a nightmare! but with some cussing and a cutting tool I got them out, also got the cross member out so I can get ready to put in the 84 crossmember
Old 04-11-2011, 09:16 AM   #22
63sbssbbw
UCA63
63sbssbbw's Avatar
Coming along nicely 63
When I did mine it was a tight squeeze (3/4"narrower than the frame),but 2" ratchet straps (looped around and back into itself) fore and aft sucked the rails in just enough to slip the crossmember in.
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 05-11-2011, 09:49 AM   #23
63gmcguy
63gmcguy's Avatar
well I finally got to work a little on my pickumup, the parts fairy brought my c notches, got the rear off frame is stripped down ready to cut
Old 05-11-2011, 12:58 PM   #24
Slow Build
Slow Build's Avatar
It would probably be a good idea to support the frame from both sides of the cutting area. Less chance of it sagging before you get it all drilled and bolted up.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 06-09-2011, 09:11 AM   #25
63gmcguy
63gmcguy's Avatar
Finally got to work on the pickup got one side cut c-notch just sittin there but its a start should I bolt or weld them in?
