Old 03-09-2011, 06:16 PM   #26
SCOTI
SCOTI's Avatar
Re: Wanting to bag truck but not lay frame questions
Originally Posted by Clyde65 View Post
Coils will be around $125.00/pr
Bags with cups and valves will be a little more, around $200.00 or so.
Check with the board vendors here, they will get you a great deal.
the thing that has held me back so far is I want to replace all the bushings and such at the same time. So getting all my $ upfront.
Scotti, would I need an adj panhard bar?
3 approaches possible: 1) modify the orignal bar to be adjustable; 2) modify the original bar only to re-center; 3) use an aftermarket adjustable bar.
I feel it is worth-while to do whatever it takes to ensure the Panhard bar goes from the frame all the way across to the pass side T/A (or pass side of the rear end housing). That can be accomplished by buying a new aftermarket adj bar, or by modifying your exiting bar. If you go through the effort to make the factory bar longer, you might as well make it adj too.... It REALLY helps installation & set-up ease.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-09-2011, 07:12 PM   #27
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
cool, thanks bro!
Hey you coming to the meet and greet in Ft Worth Saturday?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-09-2011, 09:07 PM   #28
SCOTI
SCOTI's Avatar
cool, thanks bro!
Didn't know about any such thing....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-10-2011, 11:10 AM   #29
Clyde65
Clyde65's Avatar
Ill PM you the info.
Clyde65
Rebuild of Clyde
support our troops!
