#26 |
Re: Pics of duallies with 19" wheels
Oh yah, and apologies for the digression from the 19s to the 19.5s. Seems like people will casually refer to the 19.5s as "19s". Bad assumption on my part. I'm sure it will turn out sharp no matter which way you go based on the work you've done so far.
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
#27 |
Are those 245/70s? That sure is a sweet looking truck
.As said, I plan to run 245/70s on my K30. I only have the stock 3-leaf front pack though, plus a Rancho add-a-leaf (supposed to raise 1-1.5"). Hopefully they won't rub too bad. Thoughts? Thanks, Joe P.S. - As far as the confusion regarding the OP and his lowered dually, the fact that it is lowered was never mentioned anywhere in the original post. As said, many refer to 19.5s as 19s. Sorry for the confusion, was just trying to help... Posted via Mobile Device |
#28 |
What size on the tires?
#29 |
225/70 Continental HSRs.
#30 |
That's 31.9" of tire height & extremely tall for a lowered truck. How is your truck lowered?
#31 |
Getcha Pull
DANG!!!! That is it! The only way that'd be better is if it was a square body Topkick.
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
#32 |
2" Bell spindles and 2" lower springs up front, shackles and smaller pack in the rear. Truck rides fine. I've driven it every day since last July. Prior owner did the same for nearly a year before that. It was a street trucks magazine tech article project.
#33 |
it will take me better part of a day to find the info on tire size but I do know its on 19" brentz wheels
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
#34 |
anyone know the specs on the 245/70/19.5 vs 225/70? I seem to be able to find all the specs for the smaller size tires but not those. I need to know how tall they are. I talked to a gm guy who runs them on two of his 1 tons, he's got 8r19.5s, but they look like steer tires, not what I want. Real tall, but ultra skinny with no discernable tread. Wont work on a 4wd that I want to be able to hunt and plow with. I'll be looking for 6 drive tires.
Anyway, I am guessing the 245 will be at least 33". I've got room for 35-36 at least. Anything smaller than 33 is going to look too small imo.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
#35 | |
It followed me home?
http://www.1010tires.com/tiresizecalculator.asp- 245-70-19.5 = 33" 225-70-19.5 = 31.9"
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 04-04-2011 at 05:01 PM. |
#36 |
Thanks thats just what I was looking for. Def want to go with the 33s, I already have 31s and they're too small for a lifted truck. Plus the big wheel will make the smaller tire look even smaller. I know some (a lot!) of you guys like the look of a big rim and a tiny sidewall, but it's not for me.
#37 | |
Me personally.... I feel 4" minimum sidewall height is needed to survive our well kept roads.
#38 | |
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE |
#39 |
So I thought I had my mind made up with my wheel choice but now I am wondering if the classic hole pattern would be cool too!!
What do you guys think? ![]() ![]() Posted via Mobile Device
#40 |
I'm not a fan of the 'classics'. The holes are scaled too small for the wheel mass (it's also what I dislike about my 16" classics).
#41 |
Check out American Force Wheels. They make some of the sweetest dually wheels ive ever seen.
1972 Chevy 3/4 ton. Under construction ![]() I'm a Mason! Lodge #624 |
#42 |
First ones between the two.
1985 Chevy K-20 350ci (8.1L in the works!) NP203/TH400 (Soon to be 205/400) Dana 44 and 14 bolt FF 7.6' Western Plow 2001 Silverado LT HD 4x4 496ci (8.1L) Allison EFI Live And more..... |
#43 |
Is there such a thing as a 30" tall 19.5" tire? Just wondering??
#44 |
i thought about the classics but I was going to have trevor make the holes larger, just don't think its worth the extra $200 wheel. Why doesn't anyone make 20" dually wheels?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 04-04-2011 at 09:37 PM. |
#45 | |
OR how have the tire companies NOT caught onto the trend- and make better 19.5 and 22.5" tires???? But I agree- 20" dually rims would rock!
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project. 96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq 05 VW Passat TDI - 38mpg @75mph ![]() 07 Bandit 1250S - Two wheeled fun! Click here to see my FQuick Garage! |
#46 |
ya heres mine its a 76 454 truck with 64k original miles...it was a 16.5 wheeled truck and finally located some 19.5s turned out trick lookin
#47 |
I found some older 22.5's steelies and was wanting to put them on 84 reg can c30 but I ain't got a clue if they'll work Any thoughts?
| Bookmarks |
