#26 |
Re: Bags, 2.5 Z, 2.5 spindles
Do you have any pics of Z drop, ? was it difficult and was it worth it, truck looks cool,
? have you removed inner front arches, ? have you thought of a body drop. |
#27 |
your truck is looking bad ass. by doing the z notch did you have to also modify your firewall or just your transmission and drive shaft area?
#28 |
Hi Mikedub, when aired out how much clearance do you have between the outside edge of the wheel/tyre & the inside edge of the front inner fender,
? also have you done away with the inner wing/fender, ? could you post some pics Thanks Roofingbloke |
#29 |
Sorry guys its been a while since i have logged on. I have not inner fenders anymore. I just took them out and trimmed the fender to let the tires have clearance. It does lay frame. The truck was not on level ground after moving to to level ground i was pleased. The biggest problem with the "z" was the trans tunnel. Just a little cutting and welding and some time it was fixed.
Get Low |
