Bags, 2.5 Z, 2.5 spindles
Finished one side. Doing the other side tonight. Disc brake upgrade. Brake booster/ master cylinder should be here this week from CPP.
Get Low |
![]() Join Date: Apr 2004
Re: Bags, 2.5 Z, 2.5 spindles
looks good. How about some more pics?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
I will have some more this weekend. I need to finish the left side so i can move it out.
Get Low |
needs more $$$
Sweet! Those 22's?
Hold the camera still when you take the next round of pics...haha. Just messing with ya.
1970 2wd Blazer |
Chevy Only Tx
Damn bro!! Gonna be sweet! Keeping it a stepside?
Chevy Only Tx......... |
look like Boss 338 wheels they dont make 22's in those so i'd say there 20's...however they do look big for 20's....
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
They are 20's. I would have used 22's in the back. I am keeping the stepside bed.
Get Low |
Get Low |
This is a few of some random pics I had of the truck. Some are old.
Get Low |
Sweet dude!
Get Low |
Get Low |
#13 |
great project. what are your plans for the bed floor?
#14 |
I am going to raise the bed floor to cover the notch, compressors, and tank. I am replacing the old wood with new wood. I should have that done with pics in about 2 weeks.
Get Low |
#15 |
Nothing to see here.....
![]() Join Date: Jun 2007
drrrrrop! sick!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
#16 |
Picked up the new tilt steering column and power steering gear box. Captainfabs gear box plate should be here this week. Can't wait its getting close to having this thing back on the road.
Get Low |
#17 |
One day.....
Man that looks SICK!!
DZL1. |
#18 |
The power steering gear box plate just got here, thanks Captainfab. Drilled out the plastic pins in the steering shaft to shorten. I plan on putting the column and gear box in Saturday. I will post pics once its in.
Get Low |
#19 |
sweet build.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
#20 |
Question, If you have done a 2.5" Z i the frame will you need to make the transmission tunnel up the same ammount,
#21 |
I have the trans tunnel cut out now, once I put the engine and transmission back in I will make a tunnel for it.
Get Low |
#22 |
I got the power steering gear box on last night with the column. I used a 1984 chevy truck column with tilt. A little mods got the column to fit right and its not to long. The shaft colapsed enough to make it work, even with the 2.5z the steering shft does not touch the upper control arm. will post pics later.
Get Low |
#23 |
are you laying frame on that truck . if not how far are you from laying it out on the ground .looks sick for sure
#24 |
The frame is not laying out. It's about 1/2 in from being on the ground. Should have went 3in on the Z, but everyone said 2.5in max due to other issues with going that low.
Get Low |
#25 |
so if i did a 2.5 z an 3 inch spindles it should lay out.correct what if i chop the crossmemeber down 1.5 inches. also how tall are the tires on your 20s.
