04-24-2011, 06:10 PM | #26 |
Re: Mid 13's?
Okay Guys, lets get serious now :P Im only 18, so if some of my suggestions questions are getting annoyin just let me know. I was just curious as to what kind of power id need to move it into mid 13's low 14's. Im thinking a semi mild 454 could be a solution to this. Lots of torque. My head seems to be running in a million different directions.
04-24-2011, 07:44 PM | #27 |
Truck and auto performance nut
Re: Mid 13's?
you could do it with less....and just spray it with another 150-200hp wet nos kit when you need the extra boost (like to take out a hot import).
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-24-2011, 07:48 PM | #28 |
Re: Mid 13's?
Thats basically all i want to do..go to the highway with a 160 hp civic and beat the snot out of them. I believe a Big Block 454, auto with a shift kit and the right gearing and walkin away
04-24-2011, 08:08 PM | #29 |
Re: Mid 13's?
still going with a bb is still going to cost big money, sometimes i wonder what i was thinking building my bb, if u dont have a bb but u can get a sb i would build the sb it would b cheaper to do what u want to do, thats just my 2 cents
04-24-2011, 08:25 PM | #30 |
Badass
Re: Mid 13's?
400sbc eldin /.503/510 lift. edle intake. flat top pistons. stock heads. rollor rockers th350with shift kit. stock stall from 305 motor.10bolt. 3:42 airborne race posi. 235/75/15 tires on that run. fist time out to the track. and best time that night with no tuning was a 13.90
oh btw thats a 70k + sl550 i pulled..
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
04-24-2011, 08:25 PM | #31 |
Re: Mid 13's?
Yea, ive got a little bit of time to figure it out. Im still just trying to get the truck all redone bodywise. Should be lookin good before this school years done, then the motors getting built. More than likely just be a 355 hopped up a bit.
04-24-2011, 08:26 PM | #32 |
Re: Mid 13's?
Thanks for that video! thats a ton of inspiration! i didnt think 13s would be that hard to come by. but anything over that should be huge money. Nice truck!
04-24-2011, 08:39 PM | #33 |
Re: Mid 13's?
I wasn't funning with ya, dude. To get a truck into the mid-13s just takes a lot of torque. Best way to get torque is with a big block (there's no replacement for displacement). And the second part of the discussion was, sometimes it's cheaper and easier to just buy an engne already done and have it sent to you. Lots of people (including me) will say, ahh I can build an engine cheaper than that. But it's not necessarily true.
04-24-2011, 09:24 PM | #34 |
Re: Mid 13's?
I have been there, my buddy had an eclipse turbo in high school. It was fast.
Budget will be your biggest problem. A lot of high schools down here have vo-tech programs where you can learn the automotive service trade. If you can get into one of those classes, you will have access to all the tools you need to hop up your motor. If you have access to a classroom like this, and your instructor isn't a total douche then you are made in the shade. Use your age as an advantage and get someone to help you learn the process of a build. Another option would be to get a job at a parts store with a machine shop and try to learn to build an engine through the machinist there. There is no easy answer to the question you are asking, with a 4500lb truck. weight and lack of weight transfer will hold you back almost as much as your budget. Last edited by gofastbobby; 04-24-2011 at 09:24 PM. |
04-24-2011, 09:46 PM | #35 |
Re: Mid 13's?
"Horsepower sells cars and torque wins races" especially in 4500 lb trucks. Find a peanut port 454, you can pick them up cheap from any mid '70's to mid 90's truck, 750 4 barrel of any kind you want, nice voodoo cam, highrise, headers and 4.10's should get you close. It will fry the tires all day long and maybe the ricer will get lost in the smoke behind ya.
04-24-2011, 10:38 PM | #36 |
Re: Mid 13's?
04-24-2011, 11:32 PM | #37 |
Re: Mid 13's?
67 camaro. Ran 13.60. (Altitude 1000 feet.) Had a 350, flat tops, MASSIVE home ported 2.02 steel heads, 750 DP holley, torker intake, powerglide, 3000 stall converter 10" slicks, 456 posi, 284/453 hydraulic cam. Weight 3150. So I'd say big block good heads big slicks solid cam and good luck.
04-24-2011, 11:56 PM | #38 |
Re: Mid 13's?
350 block, vortec heads, cam, intake, 650-750 carb, juice, stall, cal tracks, and slicks.
should get close to 400whp with that setup and its not too expensive.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
04-25-2011, 12:19 AM | #39 | |
NOT REALLY BANNED!
Re: Mid 13's?
My engine setup went 11.8 last year in a (CAR), put down 376rwhp. I'll probably see 380-390 this year with my setup due to a cam change and induction change. PS, those numbers were with world 'S/R' heads. S/R means STOCK REPLACEMENT. They don't even flow like the vortecs stock, but then again these aren't off the shelf heads.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. Last edited by 1BadSS; 04-25-2011 at 12:19 AM. |
04-25-2011, 08:47 AM | #40 |
Re: Mid 13's?
Is there a price difference when building small blocks? will a 400 cost more than a 350? not including the price of finding either one
04-25-2011, 10:07 AM | #41 |
Badass
Re: Mid 13's?
400 and 350 will cost the same to build. They share most of the same parts. But the finding and buying a 400 will cost you more.
04-25-2011, 10:33 AM | #42 |
Happy to be here
Re: Mid 13's?
Is this truck your daily driver? If so, something else to factor in here is gas mileage. Can you afford to feed a hungry big block on a daily basis. Nothing wrong with dreaming, but keep the dreams as close to reality as feasible.
04-25-2011, 10:45 AM | #43 |
Re: Mid 13's?
Well its not so much gonna be a daily driver but more of a toy, drive it in the summers and store it in the winter. So big block isnt a problem. But the only downfall to a big block is their scarce down here. 350s are everywhere as well as any other sbc. I can also get a 327 (1964) ''replacement engine'' that would need a rebuild. Ive heard stories of the 327s being fast little motors in there day, but doubht theyd do well in a 4500lbs truck
04-25-2011, 10:52 AM | #44 |
Happy to be here
Re: Mid 13's?
Nothing wrong with a 327, but a 350 is your best bet. Build a solid bottom end, a good set of heads, cam, and intake for a simple 350HP motor. Add a 100 shot kit and your good to go.
04-25-2011, 11:06 AM | #45 |
Badass
Re: Mid 13's?
Yea nothing wrong with getting 8-10 mpg as a daily driver at all..
04-25-2011, 11:08 AM | #46 |
Re: Mid 13's?
If it would get me beating rice burners then i wouldnt care about mileage! gas is my only bill, being 18 hahah
04-25-2011, 11:44 AM | #47 |
Re: Mid 13's?
04-25-2011, 11:55 AM | #48 |
Re: Mid 13's?
Well it would be a couple peices at a time..the trucks gonna have a 305 for the time being and stock running gear, so it would be spread out from the beginning of this summer to be beginning of next summer. id say maybe 5,000-6,000 throughtout the year maybe more
04-25-2011, 12:07 PM | #49 |
1962 C-10
Re: Mid 13's?
I don't know the exact 'specs' on this '66, but I do know its an all steel truck with a 400 sbc, tunnel ram with two Holleys, monster cam, cast Dart heads, racing th400, Ford 9" with 4.11's... It ran mid 12's at the Albuquerque dragway, over 5000' elevation... with a small block you can get big HP's without the big block weight...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 Last edited by jchav62; 04-25-2011 at 12:08 PM. |
04-25-2011, 12:39 PM | #50 | |
Re: Mid 13's?
Use one of those 350 blocks that you already have, and start by getting it machined. Have them clearance it for a 3.75 Crank, and buy a 383 rotating assy. Buy it balanced... and go from there. you will have a great Starting point to make an easy 400-450 HP and 475 ft lbs of torque, with the right Heads & Cam I have bought a couple of assy's from CNC-Motorsports... great Company http://www.cnc-motorsports.com/category.asp?CtgID=9001 Last edited by jrcaprai; 04-25-2011 at 12:41 PM. |
