Old 06-09-2011, 11:57 AM   #26
59Mutt
59Mutt's Avatar
Re: Aftermarket Column install
Originally Posted by BR3W CITY View Post
I guess you could also get a u bolt from a leaf spring or similar and drill new holes in the mounting bracket. You could effectively clamp the column into place.
the stock bracket clamps it in there but i may just use a piece of rubber to hold it in better. everything else ive seen acts like a clamp as well.
59Mutt is offline   Reply With Quote
Old 06-10-2011, 12:01 PM   #27
kieth
kieth's Avatar
We used the old steering column mounting bracket, modified it and added the newer clamp from a 91 suburban. This allowed us to still maintain the stock mounting for the brake pedal, we cut the old bracket to make room for the wiring, this then allowed us to use the stock emergency brake lever as well. The only mods we did to the steering column itself was to change the length of the shaft 1.25" shorter (we used the tilt wheel, the column, the wiring harness, the power steering gearbox, the engine, the power steering pump, engine, 700r4 etc..all from a wrecked 91 burb that we paid $500.00 for. here is al ink to pictures of the bracket mods, steering column install, etc.
You will have to scroll through the pictures to see all the detail of the steering mod. Kieth
http://kieth.smugmug.com/Trucks/66-G...49353720_dNwFi
kieth is offline   Reply With Quote
