Old 05-04-2011, 11:19 AM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Aftermarket Column install
I'm looking at picking up an aftermarket tilt column for my 66. Looking at the Ididit columns as well as the ebay ones. Whats needed to install one of these? Is it just a matter of taking out the old and bolting in the new, or do you need adapters or any other parts to get it to connect to the steering shaft.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-04-2011, 12:38 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Aftermarket Column install
if you have a stock column now, you will need the new column the DD shaft and a rag joint/coupling for the steering gearbox and also you will need a DD swivel connection at the end of the column. usually those things add about $200-250.00 onto the price.
Oh yea and also they do not come with the "dress up" kit, sold seperately, not sure how much those are, that includes shift lever, TS lever, Tilt lever and flasher nob, and also the indicator
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-04-2011, 03:15 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
ya thats whats killing me, I'm not sure what I need to for the shaft or joint, and none of the vendors seem to sell a "complete" setup (at least not that I've seen for a reasonably price)
Old 05-04-2011, 03:24 PM   #4
Clyde65
Clyde65's Avatar
None of it is reasonable to me. I would look at getting one of the tilt columns CPP has, they are remakes of the 71-72 columns, you can have the 4speed auto selector, they are made with all brand new parts. The only drawback is I think they are from overseas.
Clyde65
Rebuild of Clyde
support our troops!
Old 05-04-2011, 04:18 PM   #5
kieth
kieth's Avatar
I used one from a 91 burb, had to make some mods, am using the wiring harness also...
here is a link, I just took more pictures but have not uploaded them yet, Kieth
http://kieth.smugmug.com/Trucks/66-G...94_W6NaW-X2-LB
kieth is offline   Reply With Quote
Old 05-04-2011, 04:53 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
What about those tilt columns on ebay? I know ebay stuff isn't always the best.
I found a CPP universal 30" columns for $220. Could I get that and then just find the right DD joint to go from the column to the stock intermediate shaft? I'd rather not buy the "install kit" with a whole new intermediate shaft etc if i don't need it.
Old 05-04-2011, 05:08 PM   #7
Clyde65
Clyde65's Avatar
Ummm, you can use an intermediate shaft from a 67-72 IIRC with them, I dont know about the evilbay columns. the CPP tilts I was telling you were like $275.00, if your interested in them, email/PM CCPJeff.
I am rebuilding a stock 65 column ( I dont care about the tilt) and cut the shaft off, about 3" past the column stop and do the intermediate shaft from a 68 column I have.
Clyde65
Rebuild of Clyde
support our troops!
Old 05-04-2011, 06:08 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Heck you know what, I think my steering box and shaft may be from a 71. The p.o swapped the front suspension for 71 so those peices may also be.
Old 05-04-2011, 07:42 PM   #9
gimmy 64
i got the tilt column from p.o.l performance online. turns out to be ididit. you need the adapter for the electric hook up-30.00 double d shaft--20.00-you only need the 18 inch one.the shaft that bolts to the rag joint. and the dd shaft. and a joint that conects to the dd shaft and the splines on the column. everything comes with the column in the way of levers and flasher nob. i did this swap because i did not wantr to put a 40 year old steering column back in my truck
gimmy 64 is offline   Reply With Quote
Old 05-04-2011, 09:15 PM   #10
Indian113
Indian113's Avatar
I have one of the CPP tilt column's that are called economy column. I am going to install it as soon as I get my truck back from the tranny shop. We are putting in a 700r4 and going from a 350 trans w/gennie shifter to a column shifter. It was cheaper to buy column than a shifter and a column because our column is for a 3 on the tree.
Indian113 is offline   Reply With Quote
Old 05-06-2011, 12:11 AM   #11
willyp
willyp's Avatar
i installed the ididit column from summit, part number IDT-1120650010. it has self cancelling turn signals, 4 way flashers, 8 position tilt and comes wired with a 3 7/8 plug, all knobs and handles included. the plug was a little funky to mate up with the painless harness but i figured it out. i also used a steering coupler adapter from summit, part number IDT-3000313449.
i like pictures......
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 05-06-2011, 01:10 AM   #12
blackedoutharley
Can you elaborate on this more?
blackedoutharley is offline   Reply With Quote
Old 05-06-2011, 11:06 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Willyp, did you need an intermediate shaft also, or only the column? My truck was converted to power by the PO, so I'm not sure if i need the intermediate shaft like some say, or just the coupler for the 69+ style.
Old 05-06-2011, 11:50 AM   #14
Dunenutt
Newbee
Dunenutt's Avatar
I bought the econo column from Brothers, which is a CPP streetrod column. You can buy all of the shafting from CPP. It comes with all of the knobs and handles. You will not have a neutral safety switch, or reverse lights without some extra parts. For a couple hundred bones, it is what it is. I will be doing some fab to make the oem NS switch work.
Dunenutt is offline   Reply With Quote
Old 05-06-2011, 02:51 PM   #15
willyp
willyp's Avatar
ok, the ididit column uses a 3 7/8 inch male connector. the painless harness comes with 2 different female connectors that are both about 2 1/2 inches. i couldnt figure out which one to use or how they fit together. after a couple calls to both painless and ididit tech support i was more confused. i figured there had to be some kind of addapter. sometimes you just have to take a break and revisit the problem in onther day or two........or three. eventually i figured it out, all of connector positions dont get used, i ended up cutting off about 1 1/4 inches off the ididit connector so they could snap together. also 3 of the pins color wire didnt match up. it would be easy if black went to black, white to white.....not in this case, pin L,M,N colored wire dont match up. you can see the 2 connectors up under the dash. the right side is the ididit and the left side is the painless connector. i had to make a pin to pin/to wire color diagram to keep it all straight. clear as mud?
Old 05-06-2011, 02:56 PM   #16
willyp
willyp's Avatar
just the column and the coupler, used the stock shaft but had to cut it.
Old 05-06-2011, 03:53 PM   #17
wildearp
wildearp's Avatar
I used a GM column from an early 80's Suburban. I cut back the shift ring so that only about 3 inches remained and filled the shifter hole. I also welded it at the base to keep the shift ring from spinning. I then removed my stock column and kept the shaft. I installed the column to measure the shaft length. I used a CPP spline to DD U-joint. After cutting the stock column shaft, I cut it into a DD to fit tightly into the U-joint. The GM column bolted right up. I didn't use a wiring adapter, just terminals. Total project was about 4 hours.
The column from a local pick-a-part was under $70.
wildearp is offline   Reply With Quote
Old 05-06-2011, 05:44 PM   #18
blackedoutharley
Thank you... I have a Painless harness in my '65 and am still using the stock column. I thought the Ididit column was a plug and play with the gm connector but apparently not.
Old 05-06-2011, 05:49 PM   #19
willyp
willyp's Avatar
it was all there.......just took me a while to figure it all out.
Old 05-07-2011, 06:13 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I took a few shots of my ps pump and intermediate shaft, as well as the end of the column. Can you guys tell what year or years this stuff may be? The po did all the suspension and steering on the truck, and I know the front suspension stuff is from a 71 (metal bushings on the control arms). Ideas? If I can figure this out I'll know what i need for the column
Old 06-08-2011, 06:35 PM   #21
59Mutt
59Mutt's Avatar
hi, im helping a buddy install a tilt in his 65. it has a shifter on the column along with an indicator. im not sure sure what it came from but its rebuilt. im sorry i dont have the lenght. but my concern is how does it mount under the dash? the original has two little screws to hold the column to the mounting bracket. the new one has no holes. what did you folks do to secure it? thanks.
59Mutt is offline   Reply With Quote
Old 06-08-2011, 10:15 PM   #22
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've seen people used Tek screws or self tapping sheetmetal screws (just don't go too long). I also like the idea of welding 2 nuts onto the column and using bolts to hold it through the bracket.
Old 06-09-2011, 01:32 AM   #23
59Mutt
59Mutt's Avatar
seems practical enough. kinda what i thought, but its hard talking him into tapping new nice paint.
Old 06-09-2011, 09:58 AM   #24
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I guess you could also get a u bolt from a leaf spring or similar and drill new holes in the mounting bracket. You could effectively clamp the column into place.
Old 06-09-2011, 11:06 AM   #25
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Aftermarket Column install
Flaming River
http://www.flamingriver.com/
IDIDIT
http://www.ididitinc.com/universal_s...lumn_shift.htm
Eckler’s Classic Chevy Trucks
Chevy Truck Tilt Steering Column, Chrome Steel, ididit, Floor Shift, 1960-1966
http://www.ecklerstrucks.com/chevy-t...1960-1966.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
