#26 |
Re: I am a bout to give up on finding my ps brackets!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
You guys are the best, thanks. I didn't find it yet but have one last place to look and then I will repost.
The van has the long wp so thanks for the tip on not mixing up the components. I don't know how long it has been since the van has run, just stored it for a relative who needed a place and he said to use what I want but I am going to go for the drivers side version since I have so much stuff on the passenger side I would have to deal with. |
#27 |
Justtime520 - did you use that bracket from Jegs and that alone? Looking at it I thought the brackets get the pump out away from the block a little so that the pulleys line up?
#28 |
Thanks Bigsnookmaster and stitch22 and 406 Q-ship mightymose and BoundStaffPress and 71swb4x4 and all those those offerring advice and parts, I cannot believe how generous all of you are. Talk about coming together. I should know if I won't be able to find one locally by tomorrow. You guys are good people.
#29 |
don't forget vettes used a short water pump till 82
#30 |
Does anybody happen to have a picture of an engine that uses the style of ps pump I have mounted on the drivers side? So I can get an idea of clearances and stuff?
My pump has more bolt holes on the front than on the back, I guess so that it can accommodate different mounting styles. |
#31 |
member #16
![]() Join Date: Dec 1999
heres a pic.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#32 |
Try Desert Valley Auto Parts...the same guys who have the T.V. show on the Discovery channel...they ship...and I'd be surprised if they don't have what you are looking for...I've used them in the past and they have always come through.
http://www.dvap.com |
#33 |
thanks to both of you and that pic helps a ton
#34 |
My ps pump looks different than the one s I have seen pictured. In the pictures the originals have a rounder bottom. Will mine pictured in the thread still work?
#35 |
Yes yours will still work it is just the later reservior type. Pump is the same. The only hiccup you might run into is the exit of the return line but it is no big deal to route an alternative way (may have to go down instead of up).
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#36 |
hey ubtripn are the brkts. i posted not the right ones ?
#37 |
Mightymouse, I think they are, I just can't figure out how to see them again. Still learning the forum tricks.
#38 |
![]() Join Date: Jul 2007
I have a set but one needs a repair. Anyway you'll need the add on pulley for ps. I had one in this thread but it sold but you can see what it looks like.
http://67-72chevytrucks.com/vboard/s...d.php?t=455662
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#39 |
Thank you and one other question - why do the holes on the back of my pump have plugs? especially when all of the front ones don't. (I'm not talking about the hose connections but the smaller bolt holes, it looks like fluid could come out of them?)
#40 |
I think i got it!!!!!!!!!!!!!! I modified the van brackets with my grinder and I think I got it!!! My only question left is about the threaded bolt holes on the back of my pump having threads, do I just put the bolts in and not worry? Should I use the high temp black stuff like on my intake bolts? I am afraid they will leak.
#41 |
Ubtripn - I don't want to hijack so if I do just shut me dowm....
Can anyone tell me if I can use a two groove waterpump pulley to power my PS pump or will it hit. From the pics above it looks like it wont clear. Anyone ran this set up? Having a hell of a time finding a 3 groove crank pulley thats not chrome. Thsnks, Slider
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#42 |
Your fine, no worries. I am also still interested in the holes in the back of my pump ith thereads and if I just puts bolts in and that's all.
#43 |
I also want to thank everybody for all fo the help and offers, this is one heck of a group of good people.
#44 |
Try looking in the "Truck Shop" parts catalog. They sell most all of the stock brackets including the ones for the power steering pump. That is where I will get mine because no one on here will sell me a bracket without selling me the whole set up. The brackets are reproductions, but look exactly like originals and they are reasonably priced. Good luck!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
#45 |
Spanked once
![]() Join Date: Oct 2006
They are just bolt holes ,the plugs are to protect them from dirt if not used. Won't leak.
The ole 350 budget build. |
#46 |
awesome, thanks.
#47 |
Dont feel bad ubtripn I am going through the problem. I checked out the jegs site and it appears that bracket might work. I dont know for sure but seems like last resort. Please post how you fixed your problem. I am very interested
#48 | |
Florida Edition
![]() ![]() Join Date: Oct 2010
I just posted this info on another thread...pulley part numbers and combos If your talking 350 I have the a/c p/s crank pulley setup I won't be using, also the w/p and p/s pulleys.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#49 | |
I sent you a PM. Slider
#50 | |
