#26 |
Re: Camaro IFS problem
Used 5/16 heavy angle to tie in the bumper horns, also have ended up making gussets & plates to fill in the gap below the horns not shown in this or the previous pictures.
#27 | |
ps: if anyone else knows what I'm doing wrong with the picture upload please let me know? |
#28 |
You likely have to resize them to under 100kb each (or what ever the max size is) and save them in a separate folder so you can find them easy. I do it that way but re-sizeing each pic individually is a pain.
#29 |
yeah its sounds like the photos are too large. like you said, I re size my photos just because it doesn't fill the whole page 400X600 is a good size it seems to accept that size.
-Larry |
#30 |
wilberweb here is something to keep in mind, after your clip is tacked in place and your doors and front sheetmetal is fitted just bridge the "gap" from frame to core support then take your bumper, position it where it looks good and fabricate your brackets. i have seen this done dozens of different ways and "safety and common sense" are the rules to go by. having been under trucks that had killer finishes on them only to be shocked at the poor fab work underneath. just don't make it to complicated or you won't ever get it finished, been buying those "stalled projects" for years now as "support vehicles" for finishing my projects.
#31 |
Hi, Guys I have some progress pictures of my camaro install hope this is done right
it would be a lot of work to re-cut and fix if its not what do you guys think I have noticed on some of the frame grafts that it does seem they didn't spread the frame as much as I did. I leveled my clip and measured for square.so if any one has some information on different ways they installed there camaro clips that would be interesting to see the many ways it can be done, I have a question on the clips that are mounted under the frame and why its done that way. When I was finished with the clip and I could let the truck off of the jack stands it let the truck sit 2" lower than stock. So my question is why its done both ways under the stock frame and grafted in line with the frame. |
#32 |
looking good
#33 |
Your doing a great job, looks good. When I did my 56 it was 20 yrs ago and sites like this or the internet for that matter was not around. I layed my sub under the frame thinking that after welding and boxing it would be stronger than to cut and graft, no sheer point. Plus I used the stock trans mount and didn't need to worry about the angle of the a-arms and bumpsteer. It also gives you a slight Z in the frame giving about 1" more drop. I have done two more like this and can finish it over a weekend.
#34 |
Thanks for the reply. guys
I was surprised it dropped the front so much I thought that the reason they went under the frame was so it didn't ride so high, not too lower it another inch it seems that you would modify the springs or spindles for that. I am glad I did it this way,It's good too know that I am on the right track. -Larry |
#35 |
If you look at indians picture you can see that the sub frame sits higher than the stock frame. Both are good ways to do it your doing fine.
#36 |
I see Indians is Higher off of the stock frame I guess it would make the tires lower.
so if I would want it lower still I would install spindles or air bags in the front. Right now it sits 10" off the floor that's without the Engine, with the engine installed it would bring it lower still by at lest 1" maybe 2". that's perfect height. -Larry |
