05-31-2011, 10:39 AM | #26 |
But Found Her 25yrs Later!
Re: 82 front suspension on a 66 questions
I used the original brackets and mounts.
If I remember correctly, the newer mounts got in the way of the down dump ramshorn exhaust manifold. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
05-31-2011, 02:04 PM | #27 | |
05-31-2011, 06:51 PM | #28 |
what i did i have not replaced the crossmember yet , but di replace the towers and they are from a 78 c10 . was notch the fram rails and let the engine wigh the towers down and those top bolts went right in this is with a 454 thought . and on the bottom holes of the towers i belive we just redrilled them . and all lines up perfect and square . may have lowered the motor hight just a tad thought . i can get pics if need .
64 chevy c10 swb fleet small back window , in progress 454/400 swap , disc front disc rear , and just geting it on the road . 09 ford f350 cc swb 4x4 6.4l , to haul the others home . 2011 chevy hhr not mine but love the milage .. |
05-31-2011, 07:23 PM | #29 |
I think I may just go with the tublar towers with clam shell motor mounts. I know that will bolt into the top of frame. I may need to drill x member. I also heard the tublar ones move engine forward a bit to help the hei dist clear the firewall. Drawback, $$$$$ money tight around here!
06-01-2011, 01:03 AM | #30 |
60-66 Nut
I went back and looked again and I see that they are very close to the right height for the frame. I think you could just trim the frame back about 1/2-3/4", drill new holes and you're done. You should probably check the center to center distance of the motor mounts, before you drill those holes. According to protrash64's build thread, that measurement should be aprox 16-3/4"
http://www.67-72chevytrucks.com/vboa...=272654&page=9
06-08-2011, 03:40 PM | #31 |
If you dont wont to remove your old X member your newer arms should bolt to it little easier that way
