06-04-2011, 03:22 PM | #26 |
Re: suspension and brakes
As mentioned before, I am very interested in the weight of these items compared to what I have for stock. If you wouldn't mind weighing them, I would be indebted to you
If you also have a couple extra minutes to toss the stock stuff on to verify the weights I have come up with over the years, I would really appreciate that as well. Fot the UCA and LCA I have weights with out cross shafts, so with them would be even better. I am trying to gather this data to help put together another thread for everyone on weight savings ideas, and listing what things actually weigh to help them gain a better idea of what their trucks will weigh. I also want to use the weights to update my weight sheet spreadsheet again to help other with front spring selection. I want to see more of these old farmtrucks going fast!! Spindle 27lbs Upper Control Arm 5lbs (with out cross shaft) Lower Control Arm 22lbs (with out cross shaft) Caliper 9lbs Pads 1lb Rotor 26lbs Spring 15lbs Shock 10lbs Thanks in advance.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 06-04-2011 at 03:23 PM. |
06-04-2011, 04:05 PM | #27 |
Well I will have to go bye a scale we lost everthing to a tornado back in dec. and just haven't picked one up. I will weigh everthing before I put it back together and post or message them to you.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ Last edited by bigboybodry; 06-04-2011 at 04:06 PM. |
06-04-2011, 06:41 PM | #28 |
Thank you.. Very sorry for your losses. Glad you are ok though, material items can be replaced, lives can't.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
07-04-2011, 07:04 PM | #29 | |
cpps stock spindles 21 lbs 21 lbs lower arms w/shafts 21 lbs 23 lbs upper arms w/shafts 9 lbs 10 lbs calipers aluminum 5 lbs sold (sorry) my front springs morros trick 1/2 coil cut off. 12 lbs If there is any thing else just let me know.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ |
10-04-2011, 08:39 AM | #30 |
Well I finally got the time to work on the truck! Here are the front end pics.
10-04-2011, 09:30 AM | #31 |
Registered Truck Offender
I must say,, that looks VERY nice. I 'need' to do something with my front end,, just can't decide how much street time it will ever see again. If you don't mind... do you have a total $ for all of the suspension from frame out?
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
10-04-2011, 10:41 AM | #32 |
Yep, that looks very nice!! The truck has a nice stance with those parts in place. BTW, what's the story on your Camaro? Looks nice in the pics on the other thread.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
10-04-2011, 12:25 PM | #33 | |
A car I have been working on for a few years now getting real close to being finished.
10-04-2011, 03:55 PM | #34 |
Nice! I was going to ask if it was still ls-powered, but I see now! Between your truck and the Camaro, you've got enough nitrous to sponsor your own pro-mod event!! lol
10-04-2011, 04:19 PM | #35 |
I am in thought about a F3 for both of them and switch to pump gas when its time to freshen the motors but I will have to stick with the Nos for now.
10-10-2011, 10:36 AM | #36 |
I really don't have a clue I just picked the parts up here and there a little at a time.
10-10-2011, 05:30 PM | #37 |
looking for a rear coilover shock mount and anti-roll ideas any pics/suggestions out there?
