Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-31-2011, 09:27 AM   #1
bigboybodry
bigboybodry's Avatar
suspension and brakes
well I am starting on the front and rear brakes and was looking a cpp tubular control arms what you guys think. I was looking to drop some weight and gain some stopping power.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 05-31-2011, 10:58 AM   #2
ripdog28
ripdog28's Avatar
Re: suspension and brakes
I have a mix, CPP upper and Performance Online lower arms. no reason really. Also 2in drop spindils and Disc brakes all 4 corners.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 05-31-2011, 11:31 AM   #3
Super73
Super73's Avatar
Just wondering if anyone has actually weighed the stock arms against a tubular upper / lower arm. I honestly think the majority of our front suspension weight is in the spindle/disk/caliper.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-31-2011, 12:53 PM   #4
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
well once i get my cpp upper tubular a arms this week ,i let you know how much they weigh compared to stock a arms ,im sure there's a difference since tubular is less material
im sure with the lower a arms alot of weight is lost there alone,
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-31-2011, 01:44 PM   #5
bigboybodry
I was thinking a set of drop spindles, aluminum calipers,tubular upper and lower control arms, and ss brake lines for the front. My brother has a 2000 trans am that is wrecked I was going to get the rear brakes off of if they will work.
Old 05-31-2011, 06:12 PM   #6
ripdog28
ripdog28's Avatar
Weight may only be a few pounds possibly 10-15 each. But the biggest gain is the geometry the new ones have compared to the old ones.
69 c-10 BBC
Old 05-31-2011, 06:43 PM   #7
Super73
Super73's Avatar
I'm not soo sure.. The factory front arms are stamped steel.
Uppers with out ball joint and cross shaft = 5lbs each.
Lower control arm with out cross shaft and ball joint = 17lbs each
I had a water jet place cut me some backing plates for 4th gen rear calipers I had laying around. I drew it up with measurements and they cut them from .25" flat stock. I am using a caprice rotor which is 5x5 bolt pattern.
For what I do, I'm not sure the geometry is going to do much for me If memory serves we were able to get like 6-7* of caster out of my truck on the factory arms. It drives straight as an arrow even at 128mph. For me there would have to be a big weight savings for me to go with them. The reason I am holding out for eiher a mustang 2 front or the front end that a board member is developing. I though about C5 stuff too..
Old 05-31-2011, 10:12 PM   #8
Magnimike1
I've looked at the tubular stuff alot and I have found in reading that they actually weigh a few more pounds than stock.
I would consider a Mustang II type suspension to save a little weight because of being able to go rack n pinion and coil overs.
Magnimike1 is offline   Reply With Quote
Old 06-01-2011, 07:54 AM   #9
bigboybodry
so I'm going to have a caliper/backing plate made to make the 4th gen camaro brakes to work? the stock cannot be modified to work?
Old 06-01-2011, 07:59 AM   #10
bigboybodry
All the mustang II front ends I have seen the wheel and tires look a lot futher
in closer to the frame. Is it just me or does it take the spindle futher in?
Old 06-01-2011, 01:21 PM   #11
Super73
Super73's Avatar
I did not have the backing plates, but I do believe others on this page may have tried it. That is why another member here was making backing plates at one time for both the Camaro and Caprice calipers using Caprice rotors. If you have them, put them on and take some measurements. Can't hurt to look them over on the rear. But make sure they line up.
Old 06-01-2011, 11:12 PM   #12
Captainfab
60-66 Nut
Member glockisp35 was the one that originally was selling the Camaro caliper brackets. Then after he decided to quit selling them, I took over. The Camaro caliper brackets that I sell use the '93-'97 F-body calipers with the '94-'96 Impala SS/Caprice rotors for the 5x5 wheel pattern. I have naother bracket for those with the 6x5.5 wheel pattern. I currently have 4 different rear disc brake conversion brackets, but none that work with the 4th Gen F-body.
Old 06-02-2011, 03:53 AM   #13
Super73
Super73's Avatar
I'm assuming you mean you don't sell brackets for LS1 F-body since you mention having a bracket for 93-97 F-body? I was honestly tempted to have the water jetting place make 10 sets, but I didn't want to get in on somone elses business. Come to think of it, there are probably 4-5 items I could have made that I have already done on my truck.. Maybe someday.
Old 06-02-2011, 05:43 PM   #14
bigboybodry
Smile Re: suspension and brakes
Well I just ordered the cpp drop spindles,tubular upper and lower a arms also picked up a front wilwood brakes with slotted/drilled rotors.
Old 06-02-2011, 06:45 PM   #15
Super73
Super73's Avatar
Right on.. What calipers did you order? Any chance you feel like weighing it all when you get it in? Thanks in advance.
Old 06-02-2011, 11:56 PM   #16
Captainfab
60-66 Nut
That is correct.
Old 06-04-2011, 09:06 AM   #17
bigboybodry
Man I don't think this is going to drop much weight off the truck but it sure looks better.
Old 06-04-2011, 12:20 PM   #18
softballnrd27
Always a work in progress
softballnrd27's Avatar
Would you mind throwing it all on a scale before you install it?(just 1 side)
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 06-04-2011, 01:36 PM   #19
taank
What are your 1/4 mile times?
taank is offline   Reply With Quote
Old 06-04-2011, 01:44 PM   #20
fastwillie 696969
~Rest In Peace~
cpp makes all the tubular a arm for everyone except for hotckis set up
Old 06-04-2011, 01:47 PM   #21
fastwillie 696969
~Rest In Peace~
how long did it take you to get your order from cpp ,im still waiting on my upper arms .they said it was backorder had to make them ,i called about 3 times now they said send them out today or monday .i heard that before twice .
Old 06-04-2011, 02:20 PM   #22
bigboybodry
My mother lives in ca. so she just picked them up and next day aired them to me.I think it was the second when I called and bought them and they didn't say anything about them being on backorder. They did however backorder the heavy duty c-notch kit and rear ss brake lines at that time. I have recieved a email this morning that those items sound be here by thursday the 9th.
Old 06-04-2011, 02:21 PM   #23
bigboybodry
never run the 1/4 but she'll get down in 4 country light poles.
Old 06-04-2011, 02:26 PM   #24
taank
Isn't the YouTube link in your sig at the track?
Old 06-04-2011, 02:34 PM   #25
bigboybodry
That was an old 468 with cast heads in the 1/8 it ran 6.9 all day long driving it there and driving it home for 6 years +/-. I haven't ran this new setup yet still trying to get the bugs worked out.
