07-09-2011, 01:31 PM | #26 | |
Re: My powerplant is here!!!!
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted 1997 C3500 DRW Ext cab. 454, 4L80E daily driver |
07-09-2011, 03:26 PM | #27 |
Registered Truck Offender
OK then,, I'm going to be the spoiler that makes all you bbc guys
If this were a sbc,, with a set of home ported factory heads (assuming or they would have a flow sheet I would think) with a pretty mild roller for the cubic inches, only 9.25:1 compression,,,,,, I'd not expect it to break 1HP per cube. My guess is ya all are being a bit optimistic. I'm officially logging in at 430HP at around 6400.... and I HOPE you prove me wrong!!!
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
07-09-2011, 03:40 PM | #28 |
And now that ya all are forming a lynch mob... I also think it's going to make 480+ pounds of torque is a DRIVABLE rpm range that is going to make it an ANIMAL on the street.
I just think it's going to be a bit air hungry up high to make the big HP numbers some of you are thinking. But again,, I hope i'm wrong.
07-09-2011, 05:48 PM | #29 | |
07-09-2011, 07:01 PM | #30 |
When you headed to the dyno? I'm really interested to see what she does. I don't know squat about big blocks other than to know they always surprise me.
07-09-2011, 07:33 PM | #31 |
520 HP an 540 TQ @ 5600
07-09-2011, 08:21 PM | #32 | |
07-10-2011, 04:35 PM | #33 |
Here is the link my engine is loosly based on as a reference point
http://www.wheelerpowerproducts.com/...eet-crate.aspx
07-10-2011, 05:24 PM | #34 |
Ok, here is what I have come up with...
454 .030" over with a lower friction piston design Ported 049 heads since I don't have flow numbers for you ported 781's Hyd 236/242 .521/.540 (I am using a 108 intake center line and 108 lobe sepperation. If you give me the actual ICL and LSA I can tell you more accurately) 1.7 rockers 750 non-vacum carb RPM Air Gap 1 7/8 headers (guessed length to be 30", again if you measure them, I will give you more accurate info) Low windage oil pan design 562ftlbs @ 4500 and 557hp@5750.. This is using an electric fan, electric waterpump and no accessories. Now with a flex fan, mechanical water pump and powersteering it moves to 546ftls @ 4500 and 534hp @ 5750 Same fan, water pump and power steering, but production windage and a standard friction piston design, 531ftlbs @ 4500 and 513hp @ 5,750.. Does that help?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
07-10-2011, 06:07 PM | #35 | |
07-10-2011, 06:14 PM | #36 |
i will be using a mechanical water pump, electric fans, standard friction pistons, and powersteering
07-10-2011, 07:40 PM | #37 |
Unfortunately I can not sellect a mechanical water pump with electric fan. So Here is the set up..
454 .030" over Standard friction pistons and factory type windage The ported 049 heads Hyd 236/242 .521/.540 106icl 110lsa 1.7 rockers 750 non-vacum carb RPM Air Gap 2" headers at 35" length 91 octane Mechanical fan, mechanical water pump, powersteering TQ 535ftlbs @ 4250-4,500 and 513hp @ 5500 (511hp @ 5750) Same combo above but with electric fan, electric water pump and no accessories: 550ftlbs @ 4500 and 534hp from 5500-5750
07-11-2011, 09:52 PM | #38 |
looks like I should have loaded it in EApro before opening my mouth and demonstrating my small(block) thinking . That OK, it ain't over till the fat lady songs her song on that dyno
07-12-2011, 08:44 PM | #39 |
i used to be a small block guy but once the BBC bug bit it was all over for me
07-12-2011, 10:09 PM | #40 |
I'm not taking anything away from the guys running big blocks, and expecially ones that move. But, small blocks are nothing to look down upon either. I don't want to get in to ricer math, but my SBC's sure have competed well for their size against the bigger cubed motors.
Pump gas 347ci running 11.47 @ 118mph is nothing to sneeze at in one of these trucks. Heck, the majority of the big blocks on this sight don't run that with 100+ more cubic inches. Not saying they can't, DJ, Regan, BigJim and others are prime examples of what big blocks can do. Yes I know my 347 was more of a radical build, but I would expect that a somewhat tame big block should run that all day long. Now as far as longevity.. My old motor ran strong for 5 years, had 75+ passes at the track, countless dyno pulls, 15,000 miles on it (and some of them were not easy miles). Today that motor is being run in a sand drag truck with a 200 hit. With no changes to it (except a carburated intake) he has placed 1st and 2nd in the two events he has run along side with some radical big blocks and small blocks. I expect that motor to go for a long time with little to no maintainence. The new motor, for what it is (pump gas hyd roller), I think it will again be a competitor.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 07-12-2011 at 10:14 PM. |
07-12-2011, 10:15 PM | #41 |
oh believe me im not knocking SBC's at all im a huge fan of big inch sb's and a bigger fan of the LS but for me its the raw torque of a BBC that i love. and i have a lot of respect for the combo you have
07-12-2011, 10:19 PM | #42 |
The Ls stuff is worlds ahead of the older Small Blocks. I wouldn't be scared to build a nice motor on the Ls platform. If my son decides to make his truck into his daily driver It will probably get a warmed over 6.0 truck motor.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
07-13-2011, 04:22 PM | #43 |
your absolutely right they make great power on the cheap
