Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-04-2011, 08:44 AM   #1
1971ls1longbed
1971ls1longbed's Avatar
My powerplant is here!!!!
well after saving all my extra money i finally got my engine delivered. Its a 454 .030 over, forged bottom end, flat top pistons, 9.25:1 compression, revalved ported and polished 781 heads, and studed. i know the studs are overkill but thats the way it was assembled by the previous owner.
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted
1997 C3500 DRW Ext cab. 454, 4L80E daily driver
1971ls1longbed is offline   Reply With Quote
Old 06-04-2011, 09:00 AM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: My powerplant is here!!!!
was this just at a machine shop ?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-04-2011, 09:29 AM   #3
bigboybodry
bigboybodry's Avatar
sweet!!!! that thing sould get down
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 06-04-2011, 09:51 AM   #4
weaintscared
weaintscared's Avatar
I'm doing the same thing but in a 69swb 454 .040 over T56 6speed transmission
Man doesn't it cost a ton to build them BBC
weaintscared is offline   Reply With Quote
Old 06-04-2011, 09:54 AM   #5
weaintscared
Thumbs up Re: My powerplant is here!!!!
Originally Posted by bigboybodry View Post
sweet!!!! That thing sould get down
now that's a bad ass truck!!!!!
Old 06-04-2011, 12:22 PM   #6
1971ls1longbed
Actually with the shipping from Foley MN it was $2000 and i got a balancer and a really good timing set. I am super amped to get this thing fired up. next week i am sending out the money for the carb and roller rockers from the same guy.
Old 06-04-2011, 01:21 PM   #7
weaintscared
I bought almost everything for mine new forged dome pistons,all ARP Bolts,inside & outside the motor 554 cam roller rockers 850 proform carb & intake,new balancer,3/8 pushrod from Comp,all new alum pulleys and timing cover
Old 06-04-2011, 02:42 PM   #8
bigboybodry
keep us posted I would like to see what they run. take some time in choosing a cam for what you are going to be doing with the (street/strip etc...) truck that's were the power is. I hate not being able to drive mine back and forth to work/weekends slaying mustangs and camaros.
Old 06-04-2011, 03:13 PM   #9
Super73
Super73's Avatar
Good luck with the new build!! Hope it runs like you want it too..
I remember when you were selling off your LS parts.. You going to do a name change?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-05-2011, 01:00 AM   #10
1971ls1longbed
I will definitely take your advice about the cam and keep everyone posted on whats up with the engine. First I want to get the heads flowed so I get the right cam for a hot street/strip truck
Old 06-05-2011, 01:39 AM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
Gotta love oval port big blocks! Also, if you're gonna go though the trouble to get the heads flowed and pick a cam, are you getting a custom cam? If so, I will recommend Chris Straub (www.straubtechnologies.com). You can check his work out over on www.chevelles.com in the 'performance' section. He cut me a roller cam for my 468, and really knows his stuff, especially when it comes to street/strip BBC's.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-05-2011, 11:56 AM   #12
1971ls1longbed
I absolutely am going to get a custom cam. i want to maximize hp and tq and i do feel that an off the shelf cam wont do that. And thanks for the link i will definitely check out his website
Old 06-07-2011, 11:05 PM   #13
djracer
djracer's Avatar
Good luck with the build! I have a similar motor for my son's truck. Personally I wouldn't flow the heads or get a custom cam. I think your money could be spent better elsewhere.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-10-2011, 01:06 PM   #14
weaintscared
here's my builb if you wanna take a look
http://67-72chevytrucks.com/vboard/s...d.php?t=468622
Old 06-18-2011, 11:04 AM   #15
1971ls1longbed
So does anyone want to take a guess at my torque and hp numbers?
Here are the goodies:
9.25:1 compression
Ported and polished 781 heads
Hyd roller cam @ .050; 236/242 dur, 521/540 lift
1.7 roller rockers
Msd pro billet dist
750 cfm carb
edlebrock air gap intake
hooker super comp headers 1 7/8 primaries
Old 06-18-2011, 01:50 PM   #16
dougminton
dougminton's Avatar
I say 522 hp @ 5900 and 540 ft lbs @ 5300
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 06-18-2011, 02:26 PM   #17
1971ls1longbed
That's a good start anyone else have any other guesses
Old 06-21-2011, 09:58 AM   #18
m6z
m6z's Avatar
sounds like a solid 500+ combo.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 06-30-2011, 05:30 PM   #19
1971ls1longbed
I just got my Hooker Super Comp headers from 70shortwide. These things are awesome. I also got my fuel system and ill post pics tomorrow
Old 06-30-2011, 06:07 PM   #20
1971ls1longbed
If anyone can help im also looking for a tall deck 427 block
Old 06-30-2011, 07:13 PM   #21
BossHogg69
motor exploder
BossHogg69's Avatar
Who ended up doing your cam for you? Specs above look like a Comp Cams grind.
As for a hp guess, I'll say 530hp @ 5500 and 550tq @ 4300
Adam
Old 06-30-2011, 08:48 PM   #22
1971ls1longbed
you are spot on it is a Comp Cam
Old 07-08-2011, 11:10 PM   #23
70shortwide
those things look familiar lol
70shortwide is offline   Reply With Quote
Old 07-09-2011, 12:24 PM   #24
1971ls1longbed
Lol you don't say
Old 07-09-2011, 12:47 PM   #25
Marv D
Registered Truck Offender
Marv D's Avatar
Is this motor going on a reputable Superflow dyno,, or are we just 'guessing' ?
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
