07-10-2011, 01:31 PM | #26 | |
I have a radical idea!
Re: Mexican made Crate Motors?
I can have all the machine work done (bore/hone, install cam bearings/freeze plugs, turn the crank, and have a valve job done for around $600. You can buy a Northern engine kit for $180 have build a engine comparable to the basic crate engines for around $800 - $850. You can step up, and buy a Summit engine kit with hypereutectic pistons, Fel Pro gaskets, brass freeze plugs, high volume oil pump, etc. for $250, and get the cam I want and everything else for around a $1000 total, and have a much better engine than the basic GM crate engines. I have built dozens of them, and have made pretty decent money doing them. The GM crate engines are great drop in option, and there's nothing wrong with them, but since have the tools, mics, gauges and knowledge to build engines, they aren't the best engine I can get for my money.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
07-10-2011, 01:40 PM | #27 | |
Restoring it $200 at a time...
In 1994-5, I was working at Ford's Claycomo (KCMo) plant as they were starting up production on the Contour/Mystique. There were rumors of problems with the Mexican blocks, I think on the Ecotech 2L motors. I spent a solid week putting 50 miles each on cars. The powers that be figured that if the motor didn't lock up in that distance, things were fine and the car could go on the trailer. I was never stranded, but stayed the hell away from those cars ever after.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
07-10-2011, 03:12 PM | #28 |
I am extremely happy with my Made in Mexico GM Crate engine It has held up real good, and loves burnouts
I guess its a gamble some people are not willing to take because its "made in Mexico" Personally I dont care because GM warranties it for whatever amount of time 12 months, 24 months I dont remember. You can probably get similar deals through a local engine builder as mentioned. I went with a crate because I ordered through the local GMC dealer and had it the next day ready to go.... Anyhow Good luck
72 C20 Longbed 05 1500 Z71 |
07-10-2011, 04:19 PM | #29 | |
07-10-2011, 04:53 PM | #30 |
WOW! That's crazy! About a month and a half ago I had a 327 block bored .030", honed, cam bearings and freeze plugs installed for $260. They charge$120 to turn a crank and he gets $150 for a valve job w/ seals, unless it needs guides, valves, etc. I have been using the same place for nearly 20 years and they do great. I worked as a machinist (not a motor machinist) for over and I check everything after I get it home, and nothing has ever been wrong. The only mistake I've ever had them make was they pushed one of the alignment dowel pins down flush with the deck of the block, and I had to drill and tap it and use a snatch hammer to get it out. I mentioned the next time I took him a block and he tried to knock some money off doing the next one and i told him not to worry about it. It was a simple mistake, and no big deal.
07-10-2011, 06:32 PM | #31 |
I had a guy around the corner (who has an excellent reputation) rebuild my large journal 327 for $1,300. That's full machining,10:1 flat top pistons,he swapped the truck heads for 64cc,milled,ported,& rebuilt them,roller rockers,hardened push rods,lumpy cam/lifters,oil pump,ARP bolts,air gap intake...a ready to go 325hp motor ready to go.
I've known about Goodwrench engines being built in Mexico for a long time. I never knew about any GMPPs. That said,I have never heard any complaints about Goodwrench replacement engines other than they are made in Mexico. They are cheap,available,and reliable...what most people want.
07-10-2011, 06:44 PM | #32 |
I think the GM crate engines have a great reputation and that should be what is most important...but it does bother me that they are built in Mexico,I am just being honest.I thought they were all built in Mexico,if the GMPP aren't then that would be great!
07-10-2011, 07:17 PM | #33 | |
I had zero problems and LOVED that motor!
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
07-11-2011, 12:05 AM | #34 |
If your that concerned about it being made in mexico then why dont you rebuild an old core sourced from a junkyard. Like its been said before the experience will be invaluable, you might even save some money and you'll have your peace of mind...for what its worth my friend installed a mexican crate engine in his truck and so far he's gotten 2 years of trouble free service...
07-11-2011, 10:31 AM | #35 |
Add 383HT to the list of meximotors.
Is the zz383 made here or south? P.S. There is another option we should research---this is GM powertrain's industrial and marine engines. Where are they made? Last edited by C-10 simplex; 07-11-2011 at 10:41 AM. |
07-11-2011, 10:45 AM | #36 |
If you are concerned about going with a motor built in Mexico and want something from the USA why not look into a remanufactured motor? This company in WA does them and offers a 70,000 mile/7 year warranty. Price also seems very reasonable. IMHO this is worth considering.
http://rebuiltautoengines.com/ |
07-11-2011, 12:11 PM | #37 |
i'm not at all against remanufactured or even rebuilt engines---i'm just worried about the reputation of companies.
i've heard Jasper is/was great. But now i'm also hearing there are problems with them. A company could warranty their engines for 10yrs/100,000 miles. The real question is will they honor it with no hassles? Just like this new hyundai/or is it kia's new 10yr/100,000 warranty. i don't think this will fly given the quality level of these cars so i think it's just a marketing ploy; Most people probably won't keep the car that long anyways. i'll research more about S+S. |
07-11-2011, 12:31 PM | #38 | |
Local Redneck Authority
Comparable prices here. I've built 4-5 engines in the last 10-12 years and have been very satisfied in the outcomes. I've done a couple water cooled vw engines and a few small blocks, so I guess my count is low but I always suggest local machinework and a mic. job to check for accuracy! I was a machinist for a while too, so all the tools are in the box. Northern Auto is a great kit and they have a pretty sweet cam kit from Elgin that I've used. If often considered the crate engines for ease and time savings but don't have any real experience with those. Good luck with your decision!
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
07-12-2011, 08:25 PM | #39 | |
07-12-2011, 08:25 PM | #40 | |
07-12-2011, 08:46 PM | #41 |
Fun Stuff
If you go to rebuild a crate engine from mexico, that is when you have problems. A friend of mine worked at a machine shop for a long time and he noticed that when the blocks were bored alot of pitting opened up. the castings are low quality. when the engines are new they seem to work fine.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
07-12-2011, 10:23 PM | #42 | |
Cruzin
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
07-12-2011, 10:37 PM | #43 |
~Rest In Peace~
is the 502 a henco de mexico motor ? does anyone know the specs on these 502 crate motors ,i purchase the truck with the motor already built ,from what the person knew about the motor the PO owned a autoshop and had this motor installed and added the blower
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-12-2011, 10:59 PM | #44 |
Just an FYI, LS1 and LS6 blocks (and I assume the newer gen IV engines) were made in mexico.
07-13-2011, 08:19 AM | #45 | |
07-13-2011, 08:22 AM | #46 |
Darn, you beat me to it Ackattack. I have made in Mexico stickers on mine and the wiring harness. No problems with it.
07-13-2011, 12:15 PM | #47 |
UPDATE:
1) Unfortunately: Industrial vortec 5.7 (350) is built in toluca, mex. The industrial vortec 4.3 (262 v-6) is, however, built in romulus, michigan Marine 3.0 (the old nova 4 cyl), 305, 350 all built in toluca mex. However, Marine 4.3 built in romulus, mi Marine LS L96 romulus Marine LS3 St. catharines, ontario Marine LSA supercharged=== silao, mex (?) Links: http://www.gmpowertrain.com/MarineEn...Portfolio.aspx 2. Chinese= the ultimate rednecks? They've out rednecked the rednecks at cutting corners and doing things the wrong way. Remember the tainted milk scandal? The people responsible were executed i believe? This is a little harsh, but could the same principles be applied to car parts? After all it may be safety related. Just something to think about and to possibly bring to the proper authorities. i think other products besides milk were exported to the u.s. that were defective (actually that's being redundant isn't it?) which resulted in the excecution of the persons responsible? http://en.wikipedia.org/wiki/2008_Chinese_milk_scandal Last edited by C-10 simplex; 07-13-2011 at 12:21 PM. |
07-13-2011, 01:54 PM | #48 | |
07-13-2011, 06:09 PM | #49 |
My 350/260 doesn't smoke at starup, so the valve seals should be fine. Pcv and intake gaskets are fine aswell. It seems to burn alot of oil, exhaust smells like it too. I'm not sure $1400 for an 8:1 compression weezer was a good idea. You can get a goodwrench (factory style) vortec 350 for a little more. More aggresive factory roller cam, one piece rear seal, better heads and compression. You'll need an electric fuel pump and a new flexplate, but it would be worth it. A 5.3 trumps all of these options for a mild motor though. So much more stock power
'72 cheyenne super step, '05 long bed gmc |
