Old 10-30-2011, 04:44 PM   #26
hayhauler71
hayhauler71's Avatar
Re: Overflow tank?
Originally Posted by Lippyp View Post
I was wondering if anyone had put theres the front side of the core support as I was thinking about mounting mine there, Looks like a goer, mines a black Summit 1 quart job so won't be too obvious from the grille.
Here you go
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-30-2011, 07:21 PM   #27
100%Chevy
Re: Overflow tank?
Here are mine on my 68-
Mike.
100%Chevy is offline   Reply With Quote
Old 10-30-2011, 10:12 PM   #28
into69z
"brand new second-hand"
into69z's Avatar
Re: Overflow tank?
71 Super-very nice truck, an example for anyone wanting a stock truck,IMO, love the engine detail and all the accessories too! Well done.
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 11-09-2011, 10:35 PM   #29
67L30WGN
67L30WGN's Avatar
Re: Overflow tank?
I got tired of leaking all over peoples driveways after shutting off the engine and installed a 3" x 16" stainless steel tank today in my '72. Since its a driver, I'm not worried about bug meat which will be easy to clean off anyway. In this location, by proximity, it is obviously part of the radiator coolant system and makes running the overflow hose easy.
Overflow hose runs from radiator, down through hose hole in inner fender and around to bottom of overflow bottle (can see hose at bottom), but is still hidden by bumper.
Make sure to set the height below the hood's inner framework.
1972 Cheyenne Super 10 LWB
1965 Nova SS Evening Orchid
1967 Nova Wagon Factory Disc (1 of 565), 327/PG
1964 Ford Fairlane 500 HT
1962 Nash Metropolitan Convertible (Wife's car)
67L30WGN is offline   Reply With Quote
Old 11-09-2011, 10:38 PM   #30
jondancer
Re: Overflow tank?
Do you have a front view of that? Can you see that chrome through the grille?
jondancer is offline   Reply With Quote
Old 11-09-2011, 10:56 PM   #31
67L30WGN
67L30WGN's Avatar
Re: Overflow tank?
This is a subjective thing, so although I like the bit of flash it provides, I wouldn't say one's eye is drawn to it through the grill. You can see it more during the day than at night. If it bothers you, you could certainly black out the forward surface of the bottle. If you look at the lower picture (above) you can see the bottle through the grill. It is less noticable at night as it basically reflects black as seen in this flash photo I just took for you.
Old 11-10-2011, 12:02 AM   #32
doctrouble
doctrouble's Avatar
Re: Overflow tank?
here's mine.. a litte dusty though. Just realized it's not clamped down to anything..
"Feel it's not a bonfire unless they can see it from space?" ~ Capt. Morgan
1970 Cst - 20 402
1984 Chevy C30 6.2L Diesel crew cab Dualie
doctrouble is offline   Reply With Quote
Old 11-10-2011, 05:27 AM   #33
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Overflow tank?
Originally Posted by hayhauler71 View Post
Here you go
Thanks for the picture. All my garage stuff is currently boxed up due to an impending house move but when we get settled in I'll be back on it.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 10-18-2012, 10:23 AM   #34
67-SStLouisJak
Re: Overflow tank?
Oldgold70c10 I like where you installed your tank.
Did you have to use a different pressure cap for your radiator?
It seems I read somewhere that the tank needed to be 4 inches below the radiator cap. Is that true?
My old girl dont have an overflow tank but does have a washer fluid tank that isn't being used.
I'd thought about leaving it where its at and running a hose between the two, but like it better where yours is located.
Thanks !
67-SStLouisJak is offline   Reply With Quote
Old 08-05-2014, 01:07 AM   #35
SierraMtns
SierraMtns's Avatar
Re: Overflow tank?
I am in need of a overflow tank. I am glad I saw this thread.
Anyone else have any pics of a overflow tank with an LS motor?
SierraMtns is offline   Reply With Quote
Old 08-05-2014, 06:00 PM   #36
SierraMtns
SierraMtns's Avatar
Re: Overflow tank?
Has anyone used a factory GM overflow tank from a newer car/truck on a 67-72 C10?
Old 08-05-2014, 08:00 PM   #37
haysonj
haysonj's Avatar
Re: Overflow tank?
This one came from summit and I bent the bracket
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-05-2014, 09:55 PM   #38
JonnyC10
Re: Overflow tank?
I just installed one from a 1980 El Camino. Fits perfectly.
JonnyC10 is offline   Reply With Quote
Old 08-05-2014, 10:56 PM   #39
SierraMtns
SierraMtns's Avatar
Re: Overflow tank?
Can you post up a picture? I have my washer bottle on the diver side and battery on the passenger side.
Old 08-05-2014, 11:44 PM   #40
JonnyC10
Re: Overflow tank?
I'll get one tomorrow. Its a fender well mounted one. Bolts on passenger side. Had to drill two holes, install hose, and the two bolts. Done.
Old 08-06-2014, 08:18 AM   #41
Steve Hafner
Steve Hafner's Avatar
Re: Overflow tank ?
I have this one that I bought on eBay that was for a Monte Carlo ( I THINK !!! )
I can't use it now since I installed the washer bottle for my auxiliary battery.
It fits on top of the passenger side wheel well as seen in the second picture.
( that's one similar to it, installed in someone else's truck )
Steve Hafner is offline   Reply With Quote
Old 08-06-2014, 11:23 AM   #42
JonnyC10
Re: Overflow tank?
That's the same one I have.
Old 08-06-2014, 01:02 PM   #43
SierraMtns
SierraMtns's Avatar
Re: Overflow tank?
Here is a couple pictures showing the mount of room I am working with.
Passenger side.
Driver side.
Looking for an Chevy OEM tank to make it a closed system.
Do you guys have any idea what year Monte Carlo it is from?
I have a couple Chevy pick-pull yards close by but they don't let you walk around and pull parts. They pull them for you.
Thanks again for the help.
Old 08-06-2014, 05:55 PM   #44
GMC Canuck
Re: Overflow tank?
stylish and functional
GMC Canuck is offline   Reply With Quote
Old 10-01-2015, 08:36 PM   #45
nuke82
nuke82's Avatar
Re: Overflow tank?
I just installed an overflow tank out of a 95 Astro van, I love it.
72 Chevy C-10 w/ 67 front clip
355 ci Vortec
79 Lincoln Versailles 9" rear end, 390 gears
700R4 tranny
McGaughy's 2.5" Front Drop
Fatbar 4-Link
nuke82 is offline   Reply With Quote
Old 10-01-2015, 11:04 PM   #46
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Overflow tank?
I can only speak for the 71-72......LH side of the radiator on the core support. The hose runs underneath the shroud held by a clip/bracket. These are difficult to find. You can get cheap from lots of places, which will work. If you go cheap, may as well use plumbers tape. Wes sells a nice one that sits on the RH fender. Bet he has one for yours as well.
Real clean Nuke.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-02-2015, 11:14 AM   #47
elf w/capital T
Re: Overflow tank?
Nuke, that astro van tank is sliick!!
elf w/capital T is offline   Reply With Quote
Old 10-02-2015, 11:22 AM   #48
nuke82
nuke82's Avatar
Re: Overflow tank?
I have to admit I copied another persons idea on this site but they posted in an unpopular thread. This thred is the first hit on Google so I thought I'd post a pic.
355 ci Vortec
700R4 tranny
Fatbar 4-Link
Old 03-26-2016, 11:15 PM   #49
C1ph3r
Re: Overflow tank?
I know old thread. I'm looking to add one to my '70 and thinking of doing something non-traditional. Any recommendations on what size the container should be?
1970 C-10 LWB Build Thread
C1ph3r is offline   Reply With Quote
