#26 |
Re: how low do you guys think my truck is?
I understand the concept but is it cause by time? Or do people actually do it intentionally? And if so how? Im beginning to agree with stepper the po went through alot of trouble to avoid buying parts
#27 |
BAD BOW-Silverado XST
Solution = measurements
Stock height with stock wheels, measure to the center portion of the wheel well. Front = 32" Rear = 34" Measure from the ground up, the difference is your drop. So what is your drop? |
#28 | |
Believe it or not I had posted threads requesting those measurements about a year ago and they died postless, Posted via Mobile Device
#29 |
Oh wait what is the stock wheel height? I can do the math just give me the total height OR tire size xxx/xxrxx
#30 |
There is a difference between knowledge and wisdom!! You are welcome.
Ya should have posted on my other frequent site. ![]() Check the door jam. I think 235/75R15. |
#31 |
Haha... Door jam... The only sticker left there is the made in Canada sticker lol, thanks for the tire size I'll double check with google and tire rack tomorrow before I measure
#32 | |
John 82 Chevy Silverado 350ci/TH350 ![]() |
#33 |
I put shackles and hangers on my truck originally because I use it for what it is, a truck. I tow a 26' pontoon boat from storage to the water and back, haul boards, dirt, and everything else a truck does. I'm getting ready to flip the rearend only because I want a new look. I doubt I can pull the boat after I do this(maybe) but my point is everyone wants a little different look or has different uses for their truck. It doesn't make them a retard or stupid.
#34 |
6.0 powered square
de arched springs are usually done intentionally with heat not the best choice, its been a method used since the beginning of automobiles, there's nothing wrong with your drop method
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#35 |
As low as I can without bags, or spending ridiculous amounts of money. But I'll settle for almost as statically low as possible if I can do it easily enough
#36 | |
For the rear get the flip kit with shock extenders. Doing it this way you dont have to spend extra money on drop shocks for front or rear. The only issue is your current leaf spring condition. If your leafs springs have been dearched you may not have enough room between the top of your leafs to fit the axle with out a c-notch. Same thing if you have a drop shackle. If you dont know just buy a set of junkyard leaf springs and you should be good to go.
#37 |
take a look at the front rear leaf spring hanger and see if its bolted on or rivoted. It might have drop hangers, few leafs removed and cut coils up front or lowering coils.
Looks like 2/3 or 2/4 to me
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
#38 |
The rear spring looks to be dearched quite a bit, I'm doing the math right now on my iPod so gimme a minute and I'll tell you what it is winner gets a gold star
#39 |
Ok here's what I got
It has been Lowered 2.3 inches in the front and 3.8 inches in the rear Posted via Mobile Device And thanks for all the responses and help guys it's good to finally have a solid number to work with
#40 |
It looks partialy low.
I'm thinking it's not nearly low enough, you're half way there. |
#41 | |
