Old 08-02-2011, 11:49 PM   #26
1972RedNeck
1972RedNeck's Avatar
Re: Drum Vs. Disc
Originally Posted by mrein3 View Post
I look at it this way. In this world of lawyers and sue happy public, what are ALL the car manufacturers putting on the front and in lots of cases the back of new cars?
If drums were that great, wouldn't they still be putting them on new cars?
Very good point.
Originally Posted by 406 Q-ship View Post
Drum brake fade...bad. I went through an intersection in a 69 GTO cause all the pedal pressure in the world was not gonna stop that thing in the distance. How often does a vacuum booster fail, brakes get hot alot more than booster failure. Disc brakes is the first modification on any drum brake vehicle, car or truck. Once you have been in a bad place with drums fading, you'll dump them soooooooo fast.
Knock on would I have never had that happen. Maybe I'll go to disc brakes before it does happen to me.
Originally Posted by trkfrk View Post
Before you can appreciate the difference between drum and disc brakes, you have to understand the common principles that both systems use when stopping a car: friction and heat. By applying resistance, or friction, to a turning wheel, a vehicle's brakes cause the wheel to slow down and eventually stop, creating heat as a byproduct. The rate at which a wheel can be slowed depends on several factors including vehicle weight, braking force and total braking surface area. It also depends heavily on how well a brake system converts wheel movement into heat (by way of friction) and, subsequently, how quickly this heat is removed from the brake components. This is where the difference between drum brakes and disc brakes becomes pronounced.
It is all making sense to me now.
Thanks for being patient with me. Sometimes (all of the time) I am a little thick headed.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-02-2011, 11:52 PM   #27
1972RedNeck
Re: Drum Vs. Disc
Originally Posted by N2TRUX View Post
What I want to know is why we have to have threads like this every so often. Seriously, does the advantage of modern technology need to be explained?
Maybe I am not the sharpest tool in the shed, but what is the advantage of the very thin steel used in today's vehicles?
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 08-03-2011, 12:03 AM   #28
trkfrk
trkfrk's Avatar
Re: Drum Vs. Disc
Drums
* Pro - Less expensive since they're already stock on most of our trucks
* Pro - Drums work better then discs as emergency brakes
* Con - They stop poorly when wet and can get clogged with mud
* Con - Stopping power can fade with repeated hard braking
* Con - Larger tires
Discs
* Pro - More consistant, straight line stopping power
* Pro - Dissipate heat better to stay cooler
* Pro - Less affected by water or mud
* Pro - Easier to maintain and faster to replace pads then shoes
* Con - More expensive to install (but maintenance costs should be less)
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 08-03-2011, 07:35 AM   #29
mrein3
mrein3's Avatar
Re: Drum Vs. Disc
Weight.
When the government tells you your fleet miles per gallon average has to be X, and you can remove 10 pounds of steel from each vehicle by using thinner metal, you do it.
Besides, with air bags, crumple zones, and a ton of other safety features your 3600 pound 72 Chevelle is less safe than your 2850 Chevy Cruze. Yes your fender gets totally mashed in a small fender bender but what price do you put on safety? Ask an ambulance chasing lawyer that question.
Why does Ford spec 5W-20 oil for their engines? Same reason. Oils are better now and if you can shave .1 mpg off the fleet by specifying thinner oil, you do it. Those tenths of a mile per gallon add up.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-03-2011, 07:58 AM   #30
MARKDTN
Re: Drum Vs. Disc
Another thing is that drums can explode outward with no warning if overheated and they crack. Mostly on big trucks, but it can happen on smaller cars and trucks too. Disc rotors can be worn down to nothing, but you have warning over time.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-03-2011, 10:47 AM   #31
1972RedNeck
Re: Drum Vs. Disc
Weight.
Ok, I'm done arguing and being an inquisitive idiot.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 08-03-2011, 11:19 AM   #32
67chevemall
67chevemall's Avatar
Re: Drum Vs. Disc
Drums are better and so are carbs.....old school = less parts and better built.
computers are better on your desk. ABS and FI, no thanks...I like me and my steel parts doing the thinking.
$0.02
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 08-03-2011, 11:19 AM   #33
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Drum Vs. Disc
Originally Posted by 69heavychevy View Post
thats like saying carbs are better than fuel injection...
Carbs ARE better than FI... depends on who ya ask...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-03-2011, 11:27 AM   #34
Dano69c10
Dano69c10's Avatar
Re: Drum Vs. Disc
For those of us who were around "back in the day",
Remember disc brakes were implemented when the compression ratios of engines were decreased for emissions reasons.
I figure that unless you're running an old skool high compression engine, where your truck almost stops when you take your foot off the accelerator, discs would be the way to go.
Just my $0.02
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 08-03-2011, 12:44 PM   #35
69sixpackbee
Re: Drum Vs. Disc
They ARE! F**K injection Lets see a carb leave you stranded and with an empty wallet once you fix it.
69sixpackbee is offline   Reply With Quote
Old 08-03-2011, 01:23 PM   #36
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: Drum Vs. Disc
YES!!!!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 08-03-2011, 01:45 PM   #37
406 Q-ship
406 Q-ship's Avatar
Re: Drum Vs. Disc
Just my $0.02
Dano
Not in cars........GM put disc brakes on the option list when the 375 HP/396 Ci and the 425 HP/ 427 CI was king, the trucks may have not gotten them until 71 but then none of the other manufactures were putting disc brakes on a truck until after 1971. In fact on SS Chevelles after 1969 Disc Brakes were a required option, so GM knew that they were much better than drums.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 08-03-2011, 02:14 PM   #38
Dano69c10
Dano69c10's Avatar
Re: Drum Vs. Disc
1970 beginning of new smog regulations for car manufacturers.
'69 Fleet
Old 08-03-2011, 02:44 PM   #39
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: Drum Vs. Disc
Each has their own advantages.
Carb will make more peak power. But Fuel Injection will make more AVG power over the given RPM band.
What does smog have to do with brakes?
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 08-03-2011, 03:00 PM   #40
Dano69c10
Dano69c10's Avatar
Re: Drum Vs. Disc
Originally Posted by ProStreet68SB View Post
...What does smog have to do with brakes?
I guess nothing.
'69 Fleet
Old 08-03-2011, 03:18 PM   #41
406 Q-ship
406 Q-ship's Avatar
Re: Drum Vs. Disc
Not right either, there was emission equipment as early as 1967 (A.I.R and PCV). The compression didn't start to drop until 1971 (minor drop) and plumeted in 1972.
Old 08-03-2011, 04:16 PM   #42
VWBeamer
Re: Drum Vs. Disc
Drums are lighter.
VWBeamer is offline   Reply With Quote
Old 08-03-2011, 04:25 PM   #43
Tkmadone
Re: Drum Vs. Disc
What do the big semis use? Last I checked it was drum, and I'm pretty sure it's not because of cost.
Like has been said, there are advantages and disadvantages to both systems.
Tkmadone is offline   Reply With Quote
Old 08-03-2011, 04:27 PM   #44
ProStreet68SB
Re: Drum Vs. Disc
Big trucks are slowly switching to front discs.
Old 08-03-2011, 04:34 PM   #45
Dano69c10
Dano69c10's Avatar
Re: Drum Vs. Disc
The new regulations that were implemented for 1970, were what led to lower compression engines.
What I've researched is that when GM engineers were testing vehicles with lower compression engines they found that the drum brakes were inadequate, and stopping distances greatly increased. (Implementation of PVC and A.I.R. had no effect on stopping distances, on pre-disc brake vehicles.)
Disc brakes then became mandatory in order to stop the newer vehicles in an acceptable distance with respect to safety.
Obviously if drum brakes were not doing to do the job and disc brakes can do the job, then it logically follows that disc brakes are better.
If my research is wrong, then so be it. I'm man enough to admit when I'm wrong.
But either way, (research right or wrong) my conclusion is disc brakes stop better than drums.
'69 Fleet
Old 08-03-2011, 05:53 PM   #46
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Drum Vs. Disc
i'm not sure that discs were ever mandated... and if they were, it was much later than most think. The ford escore EXP in the early 80's still had drums up front.
Old 08-03-2011, 05:56 PM   #47
69sixpackbee
Re: Drum Vs. Disc
Originally Posted by Longhorn Man View Post
.The ford escore EXP in the early 80's still had drums up front.
That's because it was a roller-blade with two extra wheels
Old 08-04-2011, 11:10 AM   #48
406 Q-ship
406 Q-ship's Avatar
Re: Drum Vs. Disc
Disc brakes and emission equipment had nothing to do with each other, it is that both were coming into their own at approximatily the same era. It was that vehicles were getting bigger and heavier. Drum brake work great and are self energizing requiring less pedal pressure.......but only really work for one stop, that is when Disc brake become the clear cut winner.
Old 08-04-2011, 02:24 PM   #49
MARKDTN
Re: Drum Vs. Disc
Correct-this week actually is a major decrease in allowable stopping distance for road tractors. A lot are going to discs. There are some going with bigger drums and/or more aggressive shoe materials. The cost does increase some either way.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 08-04-2011, 03:57 PM   #50
stich626
Re: Drum Vs. Disc
Originally Posted by treveiger View Post
I know a guy with a 71 nova with a healthy 454 with a pro charger bolted to it an as of right now he has around 450whp he "thinks" an once tuned he's hoping to have 700 an he has all drum breaks so must not be to hard to stop
drag cars , drum brakes cause less drag, and can be worth a tenth or two.
stich626 is offline   Reply With Quote
