Old 08-02-2011, 05:36 PM   #1
1972RedNeck
1972RedNeck's Avatar
Drum Vs. Disc
It seems to be very common for people to swap drum brakes to disc brakes. Why?
What is the advantage of disc brakes? I would swap from disc to drum before I swapped drum to disc (although all of my vehicles are 4 wheel drive).
IMHO, drum brakes take WAY less pressure to stop. The only time I would rather have discs, is when the time comes for a brake job.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-02-2011, 05:40 PM   #2
69sixpackbee
Re: Drum Vs. Disc
Wait 'till you get 'em wet...then you'll know why
69sixpackbee is offline   Reply With Quote
Old 08-02-2011, 05:49 PM   #3
long69
Re: Drum Vs. Disc
i won't be swapping to disc's until i need performance brakes. my drums a plenty good enough- i don't drive canyons, steep grades , in down-pours or heavy duty stop and go driving and those are the conditions where disc would be nice to have. as they are my power drums will stop on a dime with change to boot, just don't try to break a dollar. meaning that you only get so many crisp stops before they fade.
long69 is offline   Reply With Quote
Old 08-02-2011, 06:00 PM   #4
1972RedNeck
Re: Drum Vs. Disc
When ever I cross a creek (pronounced crick), I just ride 'em for a few feet.
If your booster ever goes bad, drums are way easier to stop with (from my observations on similar vehicles, drums always take less pedal pressure).
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 08-02-2011, 06:01 PM   #5
treveiger
treveiger's Avatar
Re: Drum Vs. Disc
I know a guy with a 71 nova with a healthy 454 with a pro charger bolted to it an as of right now he has around 450whp he "thinks" an once tuned he's hoping to have 700 an he has all drum breaks so must not be to hard to stop
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 08-02-2011, 06:12 PM   #6
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: Drum Vs. Disc
Less heat, more reliability. Stops faster. Less parts to fail.
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 08-02-2011, 06:23 PM   #7
ed2552
ed2552's Avatar
Re: Drum Vs. Disc
Discs have better clamping power and less fade under hard stopping, plus they're much easier to work on.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 08-02-2011, 06:24 PM   #8
69sixpackbee
Re: Drum Vs. Disc
Yeah, Novas weigh what? about a hundred-pounds too.
Old 08-02-2011, 06:32 PM   #9
trkfrk
trkfrk's Avatar
Re: Drum Vs. Disc
Before you can appreciate the difference between drum and disc brakes, you have to understand the common principles that both systems use when stopping a car: friction and heat. By applying resistance, or friction, to a turning wheel, a vehicle's brakes cause the wheel to slow down and eventually stop, creating heat as a byproduct. The rate at which a wheel can be slowed depends on several factors including vehicle weight, braking force and total braking surface area. It also depends heavily on how well a brake system converts wheel movement into heat (by way of friction) and, subsequently, how quickly this heat is removed from the brake components. This is where the difference between drum brakes and disc brakes becomes pronounced.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 08-02-2011, 06:41 PM   #10
406 Q-ship
406 Q-ship's Avatar
Re: Drum Vs. Disc
Drum brake fade...bad. I went through an intersection in a 69 GTO cause all the pedal pressure in the world was not gonna stop that thing in the distance. How often does a vacuum booster fail, brakes get hot alot more than booster failure. Disc brakes is the first modification on any drum brake vehicle, car or truck. Once you have been in a bad place with drums fading, you'll dump them soooooooo fast.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 08-02-2011, 06:49 PM   #11
Monty
Re: Drum Vs. Disc
i friggin' HATE front drums. seems like they always dive left or right on a hard stop.
i'm ok with rear drums. my suburban build is getting front disc (GM dana 60) rear drums (13"x 3.5", 14 bolt) pumped up by a Hydroboost.
Monty is offline   Reply With Quote
Old 08-02-2011, 07:00 PM   #12
Jeffs70
Jeffs70's Avatar
Re: Drum Vs. Disc
every time I Have had drum breaks on these trucks and going down a steep inclined road and then have to stop at a stop sign well guess what a few weeks later the drums are shot and have to get them turned again. this even happens when trying to stop even at slow speeds. even the pads get a slick coat on them that causes it harder to stop after time.
while with disc brakes i have never had this problem. seems the heat is just a bit different from one to the other. disc brakes are just way better all around IMO.
Jeffs70 is offline   Reply With Quote
Old 08-02-2011, 07:32 PM   #13
Daddy Brim
Daddy Brim's Avatar
Re: Drum Vs. Disc
My 68 Nova had drum brakes and a very healthy 396. You could not stop it if you had to, disk are the only way to go.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 08-02-2011, 07:43 PM   #14
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Drum Vs. Disc
i like working on drums brakes myself, slapping pads on the front disc even a cave man do that
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-02-2011, 08:07 PM   #15
ProStreet68SB
Re: Drum Vs. Disc
Drums arent exactly rocket science, so dont pat yourself on the back to much.
Old 08-02-2011, 09:24 PM   #16
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Drum Vs. Disc
if thats what you like then it's fine by me, my dads 67 is still running all drums/they drove them for years that way
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 08-02-2011, 09:50 PM   #17
fastwillie 696969
~Rest In Peace~
Re: Drum Vs. Disc
i been certified by gm and ford rocket program for over 20 yrs LOL
Old 08-02-2011, 10:15 PM   #18
truckster
truckster's Avatar
Re: Drum Vs. Disc
In mountain country brake fade is a big deal. It doesn't take long for drum brakes to get hot enough that stopping with them gets scary. My 70 had drums and my 72 has disks. There's a world of difference between them.
truckster is offline   Reply With Quote
Old 08-02-2011, 10:19 PM   #19
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Drum Vs. Disc
drums have advantages, but they are far and few between.
I'm getting ready to convert my one ton to disks in the front.
Old 08-02-2011, 10:24 PM   #20
mrein3
mrein3's Avatar
Re: Drum Vs. Disc
I look at it this way. In this world of lawyers and sue happy public, what are ALL the car manufacturers putting on the front and in lots of cases the back of new cars?
If drums were that great, wouldn't they still be putting them on new cars?
My 72 Chevelle was factory manual drums when I bought it. You get one hard stop then you're done for the day. I swapped in a set of disk brakes out of a Monte and now can stop when I want/need to.
If I drove in an area with hills and bought an old truck with drums, the first thing I'd do is put in disk brakes. If I pulled anything and ended up with a truck or car with front drums I'd make it disk brakes quick. If not for you and your loved ones in your cab with you, think of the poor sap in the Volkswagon that stopped short in front of you.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-02-2011, 10:41 PM   #21
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Drum Vs. Disc
I knew a guy before I joined the USAF, back in '66-7. He bought a '63 Dodge Dart 2-dr sedan from the guy who had built it...with a Chrysler 383. Still had the stock rear end and brakes all the way around. Rear ends lasted a couple of weeks. Brakes were usually gone in three weeks. 8-inch drum brakes with that kind of horsepower is dumb thing to do. But, what a ride!
I hate adjusting drum brakes. When you build a set, and you have access to some tools in a shop, it may be easier to get the arced, and then after measuring the ID of the drum, adjusting the shoes to fit. When the drum is on the vehicle and has been for a while, the adjusters get funky with brake dust and rust, and don't want to turn very easily. If you have it on a rack, that's one thing. But, if you're on a creeper and it is on a set of stands, it's not much fun. I don't recall ever having to adjust my disc brakes.
Member Nr. 2770
Old 08-02-2011, 10:42 PM   #22
jtp67-72
jtp67-72's Avatar
Re: Drum Vs. Disc
^^^^^ x2
jtp67-72 is offline   Reply With Quote
Old 08-02-2011, 10:50 PM   #23
69heavychevy
69heavychevy's Avatar
Re: Drum Vs. Disc
thats like saying carbs are better than fuel injection...
theres a reason why engineers started designing vehicles with disk brakes, if your happy with all drums and really believe they're that much better then bless your heart
69heavychevy is offline   Reply With Quote
Old 08-02-2011, 11:43 PM   #24
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Drum Vs. Disc
What I want to know is why we have to have threads like this every so often. Seriously, does the advantage of modern technology need to be explained?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-02-2011, 11:45 PM   #25
leddzepp
Moderator
leddzepp's Avatar
Re: Drum Vs. Disc
I couldn't agree more.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
