#26 | |
Re: 14 bolt FF swap
Just re-read post #1 and realized your are using a complete axle setup from a late model (06) that has factory disc w/e-brake. As I understand ,it's 3 inches wider than my 87 14FF, but you were ok with that and wanted it anyway due to its finned housing. Then after re-reading post #7, i think it's starting to make sense. My current understanding is that a late model brake setup may or may NOT just bolt to my older 14FF (if the housing ends, distance from end to axle flange, etc are different). This is what I need someone to verify. If they do not bolt on this would be where the aftermarket brakets come into play. Am I making sense now? Last edited by SunSoaked; 04-19-2012 at 02:27 PM. |
#27 |
Re: 14 bolt FF swap
Yes im using the whole 2005 setup as far as if it'd work for your setup I don't see why not assuming the flanges are the same which the brackets should make them that way only difference is your cables might end up farther up the frame no big deal but what exactly is your axle width flange to flange ill re measure mine
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
#28 |
Re: 14 bolt FF swap
Do you have contact info to the Right Gear Co. for the rear disc brake brackets you were speaking of?
#29 |
Re: 14 bolt FF swap
On this page http://rightgear.com/ I think in the bottom right corner
#30 | |
Re: 14 bolt FF swap
#31 |
Re: 14 bolt FF swap
The flanges are different from the old 14FF to the new ones, that's why the brackets are necessary in order to bolt the late model set up onto the older rear ends. If you get the brackets from rightgear you will still need to find the late model disc brake setup.
