Old 08-26-2011, 07:47 PM   #1
Mr. 250r
Mr. 250r's Avatar
14 bolt FF swap
After getting my D60 swap done which didn't go as i hoped but that's part of it, I decided to swap out my 14bolt semi-floater for a 2006 14bolt full floater with some help from my4by2's build thread i decided it was basically possible and i wanted disc brakes from the factory and the parking brake not a bolt on setup without a parking brake or even using the transfer case brake or anything along those lines. So far i've only messed with checking the gear ratio, brakes and seeing if my 16.5in wheels would fit and seeing if some free H2 wheels would fit as well even though they're ugly to me
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold
2003 1500 Silverado - Selling
2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LB SRW
Mr. 250r is offline   Reply With Quote
Old 10-15-2011, 09:52 AM   #2
67mater
67mater's Avatar
Re: 14 bolt FF swap
another IL guy! I put a full floater in my 67; watch the perch spacing as they may be different. I had to cut off the old perches and weld new ones on. great chance to correct pinion angle though!
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
Old 10-15-2011, 03:44 PM   #3
Doug_J
Doug_J's Avatar
Re: 14 bolt FF swap
I have a 84 3/4 ton I was thinken of doing the same swap for the disc brakes. what are you gonna have to do to make it fit?
Doug_J is offline   Reply With Quote
Old 10-15-2011, 11:19 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: 14 bolt FF swap
That is defiantly a good idea and a cool swap. I am curious to how it turns out. Good luck on it and keep us update
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-16-2011, 04:50 PM   #5
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
I had to stop the swap for awhile because I was paying stuff off and bought a camaro but sold my other mud truck so the swap is back on and the measurents put it a few inches wider as for what's needed to put under like a stock setup would really only be the emergency brake cable bracket which I found one so ill put some stuff up this week probably
Old 10-17-2011, 12:29 PM   #6
Doug_J
Doug_J's Avatar
Re: 14 bolt FF swap
So when you say wider is it both the shock and spring perches that need moved in or what?
Old 10-17-2011, 01:19 PM   #7
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: 14 bolt FF swap
Yeah, the GMT800 10.5 and 11.5 full floating rear axles are about 3” wider (hub to hub) than the old square body style 10.5 (14 bolt FF). In my opinion, the wider axles in the back of an older truck just doesn’t look right. The GMT800 spring perches are also in the wrong spot for a direct bolt in to an older truck.
A while back someone mentioned there as a fabricator that was making a kit where the rear disk brake setup of from a GMT800 truck could be retrofitted onto an older 10.5 axle but I forgot who that fabricator was. There is really no benefit of using a later full floater other than the disk brakes. If those could be bolted onto an older 14 bolt FF that would be a much better deal for many of us.
DirtyLarry is offline   Reply With Quote
Old 10-17-2011, 01:47 PM   #8
Doug_J
Doug_J's Avatar
Re: 14 bolt FF swap
Well running it wider wouldnt be bad because it would even it up with the front axle. I would think also that another good thing about it is alot more of the 3/4 and 1tons come with limited slip so maybe a plus on that but I was trying to figure cost, salvage yrd is gonna cost $300 to $400, disc brake kit is about $300 and up or get the brackets and pice it together.
Old 10-18-2011, 03:51 PM   #9
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
When i said wider i meant from the backing plate to backing plate as compared to my full floater and my semi floater the perches will be moved and the shock mounts as well i got the perches from http://www.ballisticfabrication.com/...ch_p_1485.html because they offered different widths and the little reinforcement piece which i liked, as for the width i can't remember the exact but it was slightly wider. I posted a link for someone who swapped the disc brakes off these newer axles onto an older second design full floater the ones with the finned case which was 88 and above if im correct all the full floaters including mine im pretty sure are finned now and mine is 4.10s, g80, disc's obviously and all the lines intact, i didn't want to run my old 1 ton full floater because i wanted disc brakes and the oem style e-brake which noone aftermarkets offers correctly but i haven't got around to grinding off the axle because i have to prepare for a weld test for a job
Old 10-22-2011, 09:15 PM   #10
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
I grinded one side flat and this shows you why not to try and save the original perches or mounts you may just cut into the housing a little like me lol nothing to bad or deep ill fill some in with mig and grind it back down still gotta get my truck to the shop though
Old 10-23-2011, 07:39 PM   #11
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
To be exact I think each perch needed to be moved in 3in a piece and the shock mounts need flipped to the other side and moved a little it has the shock mounts like an old full floater mounts opposite of my semi floater, the other things is my semi floater banjo bolt fits the new brake lines so you can re-use that. The parking brake SHOULD work by using a newer trucks adjustment bracket which I found at the shop as pictured. Still gotta get pinion angles and see if the u-joint fits from my old axle
That is probably a cheaper solution for everyone but I wanted the finned housing because mainly the look and the FF I have is rusted and slightly pitted and I just didn't want to deal with that but that's just me and as far as the look my4by2 has a newer housing and if I remember looks fine been awhile though
Update - I grinded off other side as well and started wire wheeling the housing because I'm just gonna paint it but still gotta mig in the cuts and get the truck fixed because its going out this weekend most likely with the semi floater
Old 10-26-2011, 10:32 PM   #12
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
Here's the picture of the bracket i was talking about from a newer trucks e-brake cable
Old 11-19-2011, 12:20 AM   #13
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
Finally got to work on it some more since yet again i could not take the truck out but got the old rear end out and the new one under it still got to center it tack weld the pads and then take it to school to fully weld them up
Old 11-20-2011, 01:53 PM   #14
old yelr
Re: 14 bolt FF swap
The brackets that DirtyLarry are talking about are made by a company called right gear. You can find them at www.rightgear.com. I'm planning on doing this swap in the spring and I was looking at using the brackets and swapping the late model disk setup onto my 10.5 FF rear end in my 1979 GMC. I called them and found out that they cost $90 each plus shipping and you still need to get the brake setup and cables etc. I got a complete disc brake rear end (GT5 G80) with cables and brake lines etc out af a 2004 2500HD truck for $200.00 from a local wrecker so why would you pay for the brackets when you can get the whole rear for the same price as the brackets.
I also measured the rear end from wheel mount surface to wheel mount surface and it measured 68.5" and my old one is 67.0" so it's only a 1.5" difference. No big deal IMO.
I'm going to be running the newer style 2500 alloy wheels (10 hole) so with the offset of the newer wheels it actually works in my favour that the rear is wider.
Hope this info is useful for someone
old yelr is offline   Reply With Quote
Old 11-20-2011, 02:08 PM   #15
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
Well had someone posted the link for said product I most likely would have found it lol although I couldn't find it on their website but if it works for anybody that's a plus but I still wanted a finned housing ;-p
Old 11-20-2011, 02:30 PM   #16
old yelr
Re: 14 bolt FF swap
Yeah, I looked it up on their site too and they don't show it but if you call they will know what you are talking about I found it on Four Wheeler magazine in the July 2011 issue under the Parts Rack-New Products section.
http://www.fourwheeler.com/departmen...#ixzz1OeVOKTYn
Maybe I got a smokin deal on this rear end and it would be more feasable for someone to use the brackets I'm not sure.
Anyway, I'm new on here and for the last few weeks I've been checking out some of the amazing builds and trying to absorb as much info as I can on all the tech and swaps that people are doing and I think this is an amazing resource and it has given me some much needed inspiration and motivation to finally get moving on my project!
Actually, the reason I stumbled onto this site in the first place is because I want to swap an NV4500 into my truck and I happened to find DirtyLarry's build thread and since then I've been addicted to this site
Keep up the great work!! It looks great and I'm definately hooked
Old 11-20-2011, 02:59 PM   #17
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
Really good find wish i still had the subscription to the magazine but got tired of the stuff in it would've helped me though lol but then again if it was july's issue i still would have missed it, still good find it will guaranteed help someone else ill hopefully get it done by thanksgiving got some stuff to do by then
Old 11-20-2011, 03:14 PM   #18
old yelr
Re: 14 bolt FF swap
Awesome! I will definately keep an eye on your swap
Hope all goes well.
Old 11-30-2011, 06:37 AM   #19
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: 14 bolt FF swap
I also had the same idea... First I bought the 11.5" AAM rear and it was just overkill... plus it only had 3.73 gears.... Then I found a 10.5" AAM rear with the gears I needed, cheap but from a wrecked truck and has issues. (cant remove one of the axle shafts) I also went this route to have a factory discs with drum in hat parking brake.... I am also in the middle of designing a front Dana 60 brake bracket to run late modle dual piston calipers and 14" rotors...
How long did it take for you to get the perches? ... and what size did you order?
The tube on the AAM seems a littel larger then the old school 14BFF....
Rich
1972 K5 Blazer CST Click HERE
Old 11-30-2011, 10:57 AM   #20
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
I didn't want the AAM 11.5 but the 10.5 I don't really consider it an AAM I think its just an updated FF lol but as for the ballistic perches I think it took about a week and size was the same as the old ones, which I think is 3in wide but has 3 holes and I had to drill the middle out to fit my lift block pin which was weird but as for the axle tubes I think the OD is the same because I'm pretty sure the new perch fit perfectly on the one
After this I have an old FF I couldnt sell which i got with my d60 so I'm gonna keep it and look into making it a front axle
Old 11-30-2011, 08:46 PM   #21
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
FINALLY got it all done but i kind of had to throw the brake lines together and did not get the e-brake hooked up or bled the brakes 100% correctly, but other than all that its done and in, here's some pics of the welds which kind of look like 6010's but they are all mig and i suggest taking off the brake assembly etc makes it much easier i welded it underneath my truck and should've had a light but it worked out fine. And the lincoln mig welder was 32 years old lol nearly twice as old as me and works better than the 10,000$ millers we use at school and is the only good lincoln i have used
You can also tell the driveshaft sticks out about 1/2in farther than it used so ill need to get a new one and it will need a "jump joint" u-joint as well, and as for the pinion angle i did NOT tilt it all kinds of up, just a little and it is perfect as i only have a 4in suspension maybe 6in later but i doubt it, don't like jumping into it now
Still gotta take the shock bracket to school and make another and cut it down some as the new ones are about 8in long as compared to the 5in old one so its drive able into the parking lot and that's as for as it goes for about another.... month
Old 04-18-2012, 10:50 PM   #22
old yelr
Re: 14 bolt FF swap
Any updates?
Old 04-19-2012, 10:05 AM   #23
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
There is no updates on the axle except I might put a pinion guard on other than that its been done for a long time as far as the truck updates those I will post in the build thread and I kinda lost interest in the truck so I stopped working on it but now I'm going to try and get it finished
Old 04-19-2012, 12:53 PM   #24
SunSoaked
SunSoaked's Avatar
Re: 14 bolt FF swap
Mr. 250r
So what did you end up with as far as the rear brakes? I'm confused because you talked about late model disc's, the brackets from Right Gear but kept mentioning wanting a "finned something". When I think finned, I think drums.
I really want to convert my 87 14FF to disc but it has to have some sort of e-brake other than the cadillac caliper I've heard about.
Some pics of the final setup would be awesome
SunSoaked is offline   Reply With Quote
Old 04-19-2012, 01:13 PM   #25
Mr. 250r
Mr. 250r's Avatar
Re: 14 bolt FF swap
Ah ill explain the confusion the finned housing was brought around in I think 1988 when the new body styles came out, I have a 2005HD FF if you look at the pictures on the yoke side oppsite of the cover starting at the top there's metal fins going down the housing I'm pretty sure made to cool it down while moving
As far as the e-brakes I haven't hooked them up as its a matter of finding a correct late model e-brake line which I'm too lazy to do
Now the right gear company sells brackets to use 2002 and later brake setup and I can only assume the OEM e-brake setup, but I found that out too late though
What pictures do you need ill get them this weekend
