#26 |
Re: Edlebrock 1405 Carb
I am hoping to rebuild the carb soon. After the first of the year (or sooner), I am thinking about getting an E-Thunder 650. But, I guess that depends on how salvageable the current carb is.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381 |
#27 |
Can I run the distributor and the tranny kick-down off the same vacuum port on the carb? I want to see if there is any difference in running the distributor off the non-timed vacuum port. I read somewhere that if someone has a radical engine setup, that they may need to run off the non-timed port to get better engine idle and start.
Also, the brake booster is running off the PVC port. Is there any harm in doing this? Thanks.
