Old 09-09-2011, 03:40 PM   #1
jdheff1982
Edlebrock 1405 Carb
Howdy,
Truck has a 1405 carb on it and the fuel seems to be blowing by the nipple. The hose is good and so is the clamp. My guess is the gasket for the nipple is bad. Is this something I can get at Autozone? Or is there some other work around for it?
Thanks!
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381
jdheff1982 is offline   Reply With Quote
Old 09-09-2011, 04:18 PM   #2
jdheff1982
Re: Edlebrock 1405 Carb
I fixed it (I hope). I wrapped it in that white pvc tape used for plumbing. Stopped the leak so far.
Old 09-09-2011, 04:22 PM   #3
camshaftgsxr
camshaftgsxr's Avatar
make sure that pvc tape wont react with fuel, if it does you could get another leak or worse a fire while youre driving
camshaftgsxr is offline   Reply With Quote
Old 09-09-2011, 04:55 PM   #4
jdheff1982
Well, what is normally used to seal up the fuel nipple?
Old 09-09-2011, 05:04 PM   #5
camshaftgsxr
that i dont know, im sure someone else will be able to help though this is a big forum
an aluminum washer is what i found on google here http://www.chevelles.com/forums/showthread.php?t=174919
Old 09-09-2011, 06:09 PM   #6
jdheff1982
Sounds like a crush washer is needed.
Old 09-09-2011, 07:05 PM   #7
jdheff1982
Just curious, where would be a good starting point on the idle mixture screws? Thanks.
Old 09-09-2011, 08:34 PM   #8
camshaftgsxr
i start at 2.5 turns out on my holley then adjust till i reach max intake vacuum
this might help http://www.edelbrock.com/automotive_...ers_manual.pdf
Old 09-10-2011, 12:12 AM   #9
rayfinseats
EDELBROCK.COM !!! Red (and white) roll is for fuel. Blue (and white) is for water. It's 1 and 1/2 turns on an Edlebrock. I have a 1406.
rayfinseats is offline   Reply With Quote
Old 09-10-2011, 12:56 AM   #10
67_SS396
Start at 1.5 turns and go from there. If you have never tuned a carb, use a vacuum gauge and tune for highest vacuum. Use your nose too, to make sure it's not too fat at idle.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 09-10-2011, 10:06 AM   #11
jdheff1982
No, I have never tuned a carb before. Sadly, I don't have a vacuum gauge either. Last carb I attempted to tune was a Q-Jet on a 305.
Old 09-10-2011, 11:36 PM   #12
cr34t3d_by_d4rkd3n
pipe tape is ok. just make sure it dont get dragged off the threads and into the carb. tape it further back on fitting.
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 09-10-2011, 11:53 PM   #13
jdheff1982
I found an alternative. Found a plastic/rubbery washer to use. Holding so far.
Old 09-11-2011, 02:46 PM   #14
jdheff1982
Since I do have the 1405, I want to install a manual choke cable. Is there anything special I need to do to the carb for it accept the cable? If not, do I need to adjust the fast-idle settings for use with the manual choke?
Thanks.
Old 09-11-2011, 05:13 PM   #15
blgsguy
try going here,, u can get alot of info on how to tune and such.
http://www.edelbrock.com/automotive_...all/1000.shtml
blgsguy is offline   Reply With Quote
Old 09-11-2011, 07:34 PM   #16
jdheff1982
Believe it or not, I have that saved on my pc. It doesn't say a damn thing about manual choke setup.
Old 09-11-2011, 10:19 PM   #17
vtwinsport
vtwinsport's Avatar
Thanks.
Nope. Just set your cable in with minimal movement (use zap ties to keep it from moving around). I actually changed mine to make it shorter and more direct but here is a pic if that helps.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262
http://beerbreadbike.wordpress.com/
vtwinsport is offline   Reply With Quote
Old 09-11-2011, 10:44 PM   #18
jdheff1982
That's a good looking motor! Can't wait till mine is there.
Old 09-12-2011, 09:13 AM   #19
vtwinsport
vtwinsport's Avatar
Thanks, the $'s add up fast.
Old 09-12-2011, 10:22 AM   #20
jdheff1982
I know it does! I've spent at least a grand in repairs since I bought my truck.
Old 09-12-2011, 03:04 PM   #21
jdheff1982
Let's see who can point out the missing parts on my carb...
Have fun!
Old 09-12-2011, 08:32 PM   #22
jdheff1982
In case you all are stumped, its missing the choke cable clamp, a screw on the top front left, and the choke linkage for the fast idle cam.
Will I need the choke cable clamp in order to use the manual choke cable?
Old 09-12-2011, 11:18 PM   #23
67_SS396
You're also missing the linkage rod for the secondary weights. That's what it looks like in the pics any way.
RevLimit Offroad
Old 09-12-2011, 11:23 PM   #24
jdheff1982
Is that on the same side as the fast idle cam? If I bought http://www.jegs.com/i/Edelbrock/350/1473/10002/-1 , will that give me what I need? Thanks.
Old 09-12-2011, 11:37 PM   #25
67_SS396
That has everything you need.
RevLimit Offroad
