Old 10-13-2011, 12:18 PM   #26
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: All about heaters.
first 2 shots show the different switches used 60-63,snap in, and 64-66 bolt in.
the next 2 show the size difference of the (smaller) 60-63 and 64-66 defrost hose:
Old 10-13-2011, 12:21 PM   #27
jonzcustomshop
1961 crewcab
60-63 chev and gmc deluxe heater controls
64-66 chev and gmc deluxe heater controls
Old 10-13-2011, 12:23 PM   #28
jonzcustomshop
1961 crewcab
Originally Posted by ljackson View Post
Hi, my son's 64 has a deluxe heater. Does anyone know if there is a blower that can be used that blows hard like the one's in current models ?
I wonder if we can find the cfm output of a 73-87 motor compared to our earlier ones?
Old 10-13-2011, 04:19 PM   #29
tkeduk8r
tkeduk8r's Avatar
IF you want a neat cheap upgrade that will flow alot more air, you can take a blower out of an 73-87 pickup with air conditioning (flange bolt pattern is identical to 63-66 trucks). Now the squirrel cage of the air con plastic squirrel cage will be about 3/4 of an inch taller than the metal cages in the 60-66 trucks, BUT if your careful you can trim the top of the plastic cage down to the metal cage INSTALLED height, reinstall on the newer blower motor and reinstall in your heater box. It moves ALOT more air than the standard blower motor and will heat your cab in no time... I have done this a few times since I live up here in the frozen tundra and it woked everytime... You could install a slightly higher amp fuse too, but I have found that the stock fuse is sufficient.....
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 10-13-2011, 04:47 PM   #30
A.T. RockDriller
A.T. RockDriller's Avatar
I've got a pair of '63's sitting side by side....
My 4X4 service body and the short-step 2X4 project.
I did replace the motor in my driver with a new motor....I destroyed the plastic fan when removing the backing plate....it was different from my factory one....so I had to re-use the metal fan.
I can take pic's of the cheap heat model....if any-one needs to see that one...
The one in my green truck looks as it should.
After disassembling and re-furb'ing my deluxe model last week, I was left wishing I could've figured out how to replace the felt wiper/gasket thingy for the heat/defrost flapper...
I left it as it was....with a pretty good internal leak....which doesn't really seem to affect the way it performs.
True Confessions....
Now you all know.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 10-13-2011, 09:33 PM   #31
jonzcustomshop
1961 crewcab
we do need some pics of the 60-63 recirculating heater from the inside, and the dash control.
Old 10-14-2011, 06:33 AM   #32
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
1964 GMC
1963 Chevrolet
Old 10-14-2011, 06:46 AM   #33
Rich 5150 69
Rich 5150 69's Avatar
Does any vendors sell the defrost element...?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 10-14-2011, 08:06 AM   #34
ljackson
ljackson's Avatar
Thanks tkeduk8r, I give it a try.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 10-14-2011, 11:09 PM   #35
Captainfab
60-66 Nut
Defrost element? I don't understand what you are asking about.
Old 10-14-2011, 11:50 PM   #36
Rich 5150 69
Is this so called switch also a heated element for quick defrost during icey weather...? or is is something I dreamed up..
Old 10-15-2011, 12:38 AM   #37
padresag
they didn't have a heated element for defrost
ron
padresag is offline   Reply With Quote
Old 10-15-2011, 07:27 AM   #38
jonzcustomshop
1961 crewcab
in the lmc truck catalog it is called a heater resistor, sells for $10.00
Old 10-15-2011, 05:29 PM   #39
rustyrodknocker
Thanks for the info.I never would have guessed there was two heater Choices. I thought my panel was converted from a heater delete or something. Its the thriftair. What about auxillary heaters for panels and burbs. Did they have one?
rustyrodknocker is offline   Reply With Quote
Old 10-15-2011, 05:35 PM   #40
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed. Good info.
y5mgisi is offline   Reply With Quote
Old 10-15-2011, 06:31 PM   #41
dthela
dthela's Avatar
good luck finding that wiper motor! my gear was shot and finally found somdeone with a good motor. the 62' bolt right to the firewall, no welded on spacer on the firewall, I restored wiper motors I had and then went to install them when paint was done, what a surprise!
dthela is offline   Reply With Quote
Old 10-16-2011, 07:16 AM   #42
aerotruk63
aerotruk63's Avatar
1964 GMC
Old 10-16-2011, 08:27 AM   #43
jonzcustomshop
1961 crewcab
wow! wonder how rare that sub aux. heater is??
Old 10-16-2011, 09:24 AM   #44
Indian113
Indian113's Avatar
A lot of good information in this thread. I have a Arizona truck with the economy heater,it's a good thing I don't drive it in Iowa in the winter unless it's a nice day.
Indian113 is offline   Reply With Quote
Old 10-16-2011, 11:19 AM   #45
aerotruk63
aerotruk63's Avatar
I had one of these 6 1/2" fans on my 64 GMC 960. On full it really moved the air around the cab, winter and summer. It has a small rheostat to adjust the speed. If you have a contact for school buses these are virtually a standard option. The company who supplied GM still exists and there prices are out of this world. They wanted close to a hundred dollars for a replacement switch.
The description of the fan states that it's a quiet operation, not when it is on full!
Old 10-16-2011, 10:32 PM   #46
rustyrodknocker
1964 GMC
I thought they may have had one but I have never seen one. I've been saying I'll make one for years. Probably never will but it would be nice. i would like to find a complete one out of a school bus and put it in the very rear.
Old 10-16-2011, 10:39 PM   #47
rustyrodknocker
Totally of subject but twenty minutes ago I was wondering if the power assist trucks had the same steering box as nonpower. I took a picture of one today to compare to mine, which looks the same to me . judging from that picture they must have been the same with a different pitman arm. this is good news. I may need to swap one.
Old 01-09-2012, 11:24 PM   #48
XtremeBowtie
XtremeBowtie's Avatar
Here are some quick pictures of my 63 I'm building with recirculating heater and controls (missing a button).
I will try to get some better pics and post them.
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ!
My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342
XtremeBowtie is offline   Reply With Quote
Old 01-10-2012, 02:03 AM   #49
markeb01
Senior Enthusiast
markeb01's Avatar
To keep all the heater stuff in one place, here are the heater related pages from the 1960 Accessory Installation Manual for anyone that may have interest. Pages 186-193 cover the Deluxe Heater:
Old 01-10-2012, 02:04 AM   #50
markeb01
Senior Enthusiast
markeb01's Avatar
And here are pages 194-200 that cover the Economy Heater:
