10-11-2011, 11:33 PM | #1 |
1961 crewcab
All about heaters.
I went through quite a rodeo yesterday putting a good heater in my wifes 63.
found out a bunch of stuff about interchange. I will list off what I found out, and try to get some pics up soon. please add info if you have it. If I have any of this wrong, let me know and I will edit it in. As far as I know there are 4 heater options 60-66 chev and gmc. 1) no heater: firewall delete plates- 60-66 (upper delete plate is the same all years, lower is 60-61, and then 62-66) 2) cheap heater: "recirculating", core and fan inside cab- 60-63 3) cheap heater: "thrift-air", same as deluxe, smaller core but only 1 knob for fan and air.-64-66 4) deluxe heater: "deluxe", core and fan in engine compartment.-60-66 All I can talk about now is the deluxe models, as I don't have any cheaper ones. 60-63 all have the same box on the firewall, it is shorter and more rectangular than the 64-66 which looks like gm modified so that a paper element air cleaner would fit with the V8. this one is longer (towards the front) and has an angle notch on the engine side. my 60 fan had a longer motor and an electrical connection that looked similar to a thumb tack. it also had a lower bracket that bolted through the fire wall. although different it did fit on the 63-66 boxes. the 63-66 fans all looked the same, with a regular plug in connection. all the ones I had have a metal squirrel cage, except 1 which was plastic. (66, or replacement?) the holes through the fire wall look to be the same 60-66, however my 60, and my 63 both had provisions for the heater fan bracket. I was able to install a 64-66 box on the firewall on my 63, but I had to drill a hole 1 inch closer the fender to mount it (64-66 boxes have a 1 inch wider mount than a 60-63.) I also had to drill a different hole for the "heat" control cable, those also come through the firewall in a different spot.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 10-13-2011 at 12:29 PM. Reason: eited info from capt fabs post. |
10-11-2011, 11:33 PM | #2 |
1961 crewcab
Re: All about heaters.
some stuff I found inside the cab:
"no heater" will come with a block out plate on the dash, 60-63 are the same, and 64-66 are the same, chev and gmc. The 60-63 recirculating heater uses 2 switches (1 fan,1 air), this is mounted in a 4 switch deluxe plate, however the two outer slots are not cut through in the plastic backing. the deluxe heater uses 4 controls on 60-63, and 3 on 64-66. 60-63 had a separate fan lever/switch, and 64-6 integrated the fan control and switch with the air lever. both my 64 chev, and gmc have a thrift-air heater, they use 1 knob that pulls out to control the air vent, and spins to turn the fan on.these heaters have a manual lever that you can switch under the dash (radio) to turn the defrost on and off. the thrift-air knob is mounted on a 64-66 heater block out plate. deluxe heater 60-66,and 64-66 thrift -air: under the dash is an air tube (square) which houses the electrical switch and air control flap, and an air box, which houses the defrost flap. these are 2 separate pieces, and will interchange. the air tube has a switch/electrical connection on the back side. 60-63 it is a snap in piece, 64-66 it bolts on. the electrical connector looks to be the same all years. the 64-66 air tube has a square hole cut in the front right in front of the air flap, the 60-63 does not. the air box 60-63: the defrost hoses are 2 inch od.,and 64-66 (all) are 2 1/2 inch od. 60-63 has a integral metal air outlet, 64-66 has a plastic bolt on air outlet. 64-66 thrift-air box has a manual defrost flap lever
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 10-13-2011 at 12:27 PM. |
10-12-2011, 01:45 AM | #3 |
60-66 Nut
It has been my understanding that the '60-'63 only were available with the recirculating heater. That is the core and fan inside the cab under the dash. The controls were just 2 verticle slide levers towards the drivers side. The '60-'63 also were available with the deluxe heater, Which is the core and fan in the engine compartment. This used 4 verticle sliding levers for the control. Then the '64-'66's had the Thriftair heater. This used the 2 push/pull and turn knob control on the drivers side of the ashtray. The core and fan in the engine compartment. I believe the heater core was slightly smaller than the deluxe core. Then the deluxe heater use the 3 verticle sliding control levers on the drivers side of the ashtray. Also the core and fan in the engine compartment. Someone correct me if I am wrong.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-12-2011 at 11:59 PM. |
10-12-2011, 09:34 AM | #4 |
...just another truck junkie..
You are correct CaptainFab.
Mike "Bear" Shea |
10-12-2011, 09:59 AM | #5 | |
Hollister, CA.
My black '63 had the two lever, 'cheap' heater with inside fan, two levers and delete plates. Only the heater core nipples protruded thru the firewall. My current truck has the deluxe heater.....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 10-12-2011 at 10:08 AM. |
10-12-2011, 10:27 AM | #6 |
I did pull an 87 apart earlier this year and the heater motor with cage looks identical to the 64-6 except that the fan cage is plastic
ron |
10-12-2011, 10:45 AM | #7 |
Hollister, CA.
Good to know.....
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
10-12-2011, 11:49 AM | #8 | |
1961 crewcab
do you know if 64-66 was available with a recirculating heater?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 10-12-2011 at 12:32 PM. |
10-12-2011, 11:53 AM | #9 | |
1961 crewcab
I did try to use the heater motor out of my 88 suburban, and the bolt pattern is the same, however the squirrel cage was about 2 inches taller than the 64.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
10-12-2011, 12:23 PM | #10 |
Old and crusty
10-12-2011, 12:37 PM | #11 | |
1961 crewcab
10-12-2011, 01:05 PM | #12 |
here is a 64-66 deluxe heater motor and one out of a 87 gmc p/u. There may be about 1/16" variance between the 2 in depth
perhaps the one out of the 88 suburban is for a higher capacity, due to the larger space and the demand for better heating in newer vehicles then there was then. then it was all for one and one for all(almost) ron By rondavid at 2011-10-12 |
10-12-2011, 01:08 PM | #13 |
UCA63
I have a '61 GMC and a'63 GMC sitting side by side,One the things I hadn't notice before
is the Hole through the firewall is bigger on the '61(came heater delete)than the '63(deluxe heater). I also will have pics soon(on comp at home) PS wiper motor mounting is also quite different> T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) Last edited by 63sbssbbw; 10-12-2011 at 01:10 PM. Reason: sp |
10-12-2011, 01:31 PM | #14 | |
1961 crewcab
[quote=padresag;4949305]here is a 64-66 deluxe heater motor and one out of a 87 gmc p/u. There may be about 1/16" variance between the 2 in depth
perhaps the one out of the 88 suburban is for a higher capacity, due to the larger space and the demand for better heating in newer vehicles then there was then. then it was all for one and one for all(almost) ron great shot, that would probably make sense with the larger suburban one, also it had air too, that could have made a difference as well... good to see another source for the fan... out of the 6 units I had off only 1 had a good fan!! Quote:
will try to get a pic of that too.
10-12-2011, 01:39 PM | #15 |
Old and crusty
10-12-2011, 03:22 PM | #16 |
UCA63
Thanx Jon
that would be better than the cut and swap i was going to do T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
10-12-2011, 04:12 PM | #17 | |
My 66's control is on the drivers side of the ashtray in that removable panel... |
10-12-2011, 05:17 PM | #18 |
1961 crewcab
my 64 chev has one on the drivers side, and my 64 gmc has one on the passenger side, will have to look it over, maybe he is thinking air conditioning controls which is 3 knobs on the passenger side?
10-12-2011, 05:23 PM | #19 |
Hi, my son's 64 has a deluxe heater. Does anyone know if there is a blower that can be used that blows hard like the one's in current models ?
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
10-12-2011, 11:57 PM | #20 | |
60-66 Nut
Yes I believe you are right
Yes Jon I was thinking of my '66 C30 which has AC I will go back and edit my post so as to not be misleading.
10-13-2011, 05:31 AM | #21 |
UCA63
The '61 is green
the '63 is Tan
10-13-2011, 11:50 AM | #22 |
1961 crewcab
It looks like only 60-61 have the big cut out, my 62 gmc is small like your 63 that is pictured
here is my 60 with the reducer for the deluxe heater:
10-13-2011, 12:00 PM | #23 |
1961 crewcab
60-63 (lh side of pic), and 64-66 deluxe heater boxes:
notice in the rear shot, (60-63 is the lower one in the pic) the difference in the rh bolt location, also notice the mount for the "heat" cable is in a different spot. 3rd pic: I noticed that the "heat" cable comes through the back of the 63 box, and through the front of the 60 box, there is also a lower cable guide on the fan box of the 60. 60-63 the "heat" cable mounts inside the box.
10-13-2011, 12:07 PM | #24 |
1961 crewcab
64 chevy and gmc thrift-air dash knobs.
64 chevy and gmc thrift air heater tube and box: notice the knob/lever on the left to activate the defrost vent.
10-13-2011, 12:12 PM | #25 |
1961 crewcab
64-66 deluxe and thrift-air heater boxes: firewall side.
notice that the thrift air box does not have a provision for the "heat" cable to bolt to the side, also no inner air flap.
