Old 06-08-2012, 01:35 PM   #26
Chvygreen63
Chvygreen63's Avatar
Re: 1965 Factory C-10 A/C Question
Rbar thank you for that reply.
Apparently I have jump the gun again. I was thinking all I needed to do was buy the a/c vents and the ducts would hook up throught the ash tray. But clearly that's not the way it's gonna work. I take it you have an a/c ready dash. Do you think I could trouble you for the dimensions of the opening please.
Chvygreen63 is offline   Reply With Quote
Old 06-08-2012, 03:50 PM   #27
rbar
rbar's Avatar
I didnt have an ac dash, but I do now. Someone was very helpful and posted a print of the opening. I'm not at home now, but I will hopefully post it this evening.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 06-08-2012, 04:38 PM   #28
Slow Build
Slow Build's Avatar
Here is a picture of the dash opening and the additional openings in the firewall to accomidate all the needed air flow and draining. The drawing that rbar wrote about.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 06-09-2012, 10:22 AM   #29
Chvygreen63
Thanks guys I'll post some more pics when it's closer to completion
Old 07-12-2013, 07:17 PM   #30
Todd W. White
I found the actual screw-on knobs for the pull cables. They are the same as the ones used on the 63-64 Corvette. I bought 3 from YearOne, who had the best price I found at the time, and just got them in. I checked them against the only original I had, and I screwed one onto the pull cable, and they are IDENTICAL in fit, function, and looks! Here's where you can get them:
https://www.yearone.com/Product/1953-82-Corvette/FP273
Todd W. White is offline   Reply With Quote
Old 01-11-2014, 08:12 PM   #31
Budman56
Budman56's Avatar
I have a question for you guys, I am looking at having a the air conditioning vent reproduced, this is what I got back from a designer what do you guys think I have not done this before and don't know if this is good or not. Hi Bud,
Ok, cool.
Ah! I see why they don't make them. Not too many '65 chevy pickups came w/ AC.
Are you interested in fully dimensioned 2D drafting for use to quote at different prototypers? Or you just need a 3D solid file?
Since it's just plastic you might be able to have it rapid prototyped, but it would need some polishing.
For a good accurate CAD model (3D only) of the base and middle vent you'd be looking at about $400-600. Add $50-$150 for 2D drafting depending on level of detail needed.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
