Old 12-07-2011, 07:19 PM   #26
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Gear drives
Man...that didn't sound like a PJ. Mine is a PJ noisey. I know that recording volume quality isn't the greatest on the little cameras. Pete Jackson is by far the best for producing a "whine" as apposed to some of these others that sound like bad bearings.
prostreetC-10 is offline   Reply With Quote
Old 12-07-2011, 07:28 PM   #27
doubleb's69
doubleb's69's Avatar
Re: Gear drives
I had a Pete Jackson in my 71 and loved it. My engine builder won't touch one though. He used to call my 71 " Corn Sheller" and wouldn't mess with it if it was running because he hates the sound that much. I didn't have a radio, just a delete plate. All I needed was that whine and the 3 inch exhaust note. I about went deaf in the left ear driving in the fast lane on the interstate up against the concrete dividers.
Bud
doubleb's69 is offline   Reply With Quote
Old 12-07-2011, 10:06 PM   #28
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Gear drives
"Pro's--none Con's-- very bad harmonics on the cam transfered from the crank at High RPM Hence the reason for belt drive for us racers. Use a cloyes Chain and you will be happy along with your motor."
Beating a dead horse here---
Not True - I challenge you to find hard evidence of this from any reliable source in writing.
The switch to belts was done for several reasons - ease of maintenance - light weight - ease of tuning - and greater HP due to reduced rotating mass.
Gear drives are actually better at high RPM than a double roller - if you have ever watched a chain going around a pair of gears you know what chain slap looks like - it sucks power and affects timing.
For a street motor a gear drive is only about choice - it will not make any difference one way or another for no more than the average street motor really does.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 12-07-2011, 10:57 PM   #29
prostreetC-10
My Carbon Footprint
Re: Gear drives
Originally Posted by 1968SWBBigBlock View Post
you know what chain slap looks like .
Hmmm....and I thougt that was what my Grandma said would make me go bline. I can see just fine today!!!!!
Old 12-07-2011, 11:51 PM   #30
bluex
bluex's Avatar
Re: Gear drives
I thought this too but after listening to it on a computer with much better speakers than my laptop, its pretty true to life. Could it be the difference between a big and small block? I saw in the other thread with your video yours is a big block right?
I dont remember the part number right off hand, but it is a PJ, I checked it out before I bought it to make sure it wasnt off name junk. He also had the box it came in and the picture on summit matched FWIW. The engine has been together almost 9 yrs now and I had the gear drive about 1 yr before install and he had it probably a year before that. I'm planning on taking it out, but will probably hold on to it since you can get them anymore....
bluex is offline   Reply With Quote
