Old 12-07-2011, 12:02 AM   #1
dliving69
dliving69's Avatar
Gear drives
What is the pros and cons of gear drives?
dliving69 is offline   Reply With Quote
Old 12-07-2011, 03:49 AM   #2
1970ChevyChamp
1970ChevyChamp's Avatar
Re: Gear drives
I'm definitely interested to hear what people have to say on this topic.
1970ChevyChamp is offline   Reply With Quote
Old 12-07-2011, 04:11 AM   #3
70-Shorty
Re: Gear drives
pro: NOISE con: NOISE
they kinda ran their course...IMO
+there are more efficient ways to drive cams.
Ontario CA•70 Chevy Shortbed Fleetside C-10
71 Chevy Longbed Fleetside C-20 (sold )
63 Chevy II Nova SS
02 Ford F-150 Harley-Davidson supercharged 5.4
2000 Harley Roadking Hot Bike Baggers Mag Shoot
http://s263.photobucket.com/albums/i...oot/?start=all
some truck lettering & flame jobs
http://www.flickr.com/photos/4950319...7602894916215/
70-Shorty is offline   Reply With Quote
Old 12-07-2011, 10:37 AM   #4
dliving69
dliving69's Avatar
Re: Gear drives
Well what Ive heard and seen that jegs has quiter ones..but who knows how much quiter. I heard one the other day. sounded like a turbo whinding up. Any better way instead of gear drive where I can just put it on my engine and go.
Old 12-07-2011, 11:26 AM   #5
1970ChevyChamp
Re: Gear drives
That's what I hear to. Some people love the noise it makes, while others think it is just annoying. Personally I like it.
Old 12-07-2011, 11:36 AM   #6
dliving69
dliving69's Avatar
Re: Gear drives
so other then the noise. Do these add any power to an engine or what?
Old 12-07-2011, 01:19 PM   #7
hugger6933
Re: Gear drives
It elinates or reduces the cam timing flucuation. The camwill stay timied where it is put .They are loud the quieter ones have the angle of the teeth cut a little different to lessen the noise. The loud ones that are advertised are that . The beifits of a cam geardrive are minimal at best imo. Unless you were building a all out race motor, but then I would say belt drive and they are $$$. IMO the regular timing set from a reputable maker would more than suffice in all but the most extreme cases.
hugger6933 is offline   Reply With Quote
Old 12-07-2011, 03:20 PM   #8
dliving69
dliving69's Avatar
Re: Gear drives
any good ideas of anything i should put in my 78 305 then? if gear drives arnt the way to go
Old 12-07-2011, 03:28 PM   #9
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Gear drives
Cloyes or comp cams both make very nice double roller sets
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 12-07-2011, 03:42 PM   #10
70-Shorty
Re: Gear drives
They are great for driving around the fairgrounds making people wonder if you have a supercharger under the hood. For a daily driver the noise is annoying long term after the newness wears off. You want to hear your tunes or the whine of your gears? As the previous poster suggested for most applications a standard double roller gear and chain sets. If you are doing major mods a Jesel belt drive is killer but a ton of money.
IMO your better off NOT.
63 Chevy II Nova SS
Old 12-07-2011, 03:46 PM   #11
69sixpackbee
Re: Gear drives
Belt drive setups with indexable cam sprocket.
How much $$ do you want to spend???
69sixpackbee is offline   Reply With Quote
Old 12-07-2011, 03:52 PM   #12
dliving69
dliving69's Avatar
Re: Gear drives
Can these be direct replacement from stock or do I need to change anything to make a double roller set fit? Thanks for the help everyone!
Old 12-07-2011, 03:57 PM   #13
57larry
Re: Gear drives
I have one on my street rod with a SBC. I had it about 8yrs now, it's the quiet one, has a small whine which I like and it really stays in time. There are 3 and 4 gear type. I bought mine for $99 from a machine shop
57larry is offline   Reply With Quote
Old 12-07-2011, 04:06 PM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Gear drives
Meh... a lot of cats used 'em in the 70's and 80's to reproduce the "blower whine".
If ya want blower whine... use a blower.
I'm sure they are good at keeping timing. But I can't stand the noise they make. Even the "quiet" ones. You can't beat a good quality double roller timing chain set. Way cheaper too.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-07-2011, 04:09 PM   #15
bluex
bluex's Avatar
Re: Gear drives
I bought mine used for $30 from a friend while I was building my engine. I figured why not since I needed a timing set anyways. I HATE IT!!! Its a pete jackson, not sure on the noisy or quiet version but I dont think it matters much. It was cool for about 2 days....
Here is a video I made the other day. I was trying to get more exhaust sound for someone wondering about the summit turbo mufflers but you cant hear much during the drive but the gear drive whine. Other people think its cool, but its honestly annoying going anywhere further than 10 mins away....
bluex is offline   Reply With Quote
Old 12-07-2011, 04:09 PM   #16
dliving69
dliving69's Avatar
Re: Gear drives
so you have had a gear drive..and its not too loud? but I do want to hear my tunes. So im lookin at any options right now
Old 12-07-2011, 04:13 PM   #17
dliving69
dliving69's Avatar
Re: Gear drives
Well thanks everyone now that Ive seen that video..I will stick with getting a double roller. now question is..is it easy to take the stock out and add the double roller..what needs to be done.. and also suggestion on some good ones to look at. FYI i have a 78 305
Old 12-07-2011, 04:25 PM   #18
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Gear drives
......and here's what a quality drive sounds like. Not for everyone and certainly not what you do for performance reasons but they do have there place. I wouldn't want one in my Camaro or my fastback but it does work in my truck. Sorry for the squeeky clutch arm. I realize I keep posting this video but people keep asking about gear drives!!!!! It's also a nice little display of going sideways on a very narrow road (that's why I had to back out of it).
It's also a nice display of how those always pesky, out of tune Holleys can work beautifully in pairs!!!! YOU NEED TO CRANK YOUR PC'S VOLUME TO GET THE FULLY EFFECT. SOUND LEVEL IS A LITTLE DOWN.[IMG][/IMG]
prostreetC-10 is offline   Reply With Quote
Old 12-07-2011, 04:51 PM   #19
hjewell2
hjewell2's Avatar
Re: Gear drives
Pro's--none Con's-- very bad harmonics on the cam transfered from the crank at High RPM Hence the reason for belt drive for us racers. Use a cloyes Chain and you will be happy along with your motor.
hjewell2 is offline   Reply With Quote
Old 12-07-2011, 04:53 PM   #20
dliving69
dliving69's Avatar
Re: Gear drives
When adding a double roller can it be done direct fit?
Old 12-07-2011, 04:59 PM   #21
webfoot
Re: Gear drives
Double roller timing set will fit with no mods.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 12-07-2011, 05:02 PM   #22
dliving69
dliving69's Avatar
Re: Gear drives
Thank you. Now is this a difficult thing to do? can it all be done at home..or do I need to pull the engine for that kind of thing. im new to all of this..just bought my first chevy not too many monthes ago
Old 12-07-2011, 05:38 PM   #23
webfoot
Re: Gear drives
If your motor is tired enough that you want to replace the timing set, probably not a bad idea to pull the motor and take care of a few other things now too.
-me
Old 12-07-2011, 05:46 PM   #24
Bert W
Bert W's Avatar
Re: Gear drives
To answer your last question. Yes, you can do it at home and you do not have to pull the engine. As others have said, if the timing set is worn out it may be time for a cam and rings etc.
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline   Reply With Quote
Old 12-07-2011, 06:20 PM   #25
bluex
bluex's Avatar
Re: Gear drives
Mine is a pete jackson, didnt think they got much better than that.
I probably should have mentioned I took that video with my phone, and my truck has absolutely no insulation or sound deading at all which Im sure dosent help.
