Old 01-25-2012, 02:51 PM   #26
Kerlijah
Kerlijah's Avatar
Re: Project Weed Wacker
Originally Posted by ghettoluxury View Post
Ok, today I ground all the rivits off of the rear hangers and then cut them in half. I then flipped the bottom part upside down, welded them back together and added gussets. The crew doesn't have the cali lean going on any more, but I think it needs to go a little higher.
Lookin good! I definitely agree though, the higher the better
~Wooden Indian~
1979 C10 SWB, shaved bed rails, drip rails, tailgate handle. 350 w/ Comp cam, hydraulic lifters, Edelbrock Performer intake, Edelbrock 650 carb, Flowtech headers, Flowmaster 40s, turbo 350 w/stage 2 shift kit...so much fun!
Kerlijah is offline   Reply With Quote
Old 02-13-2012, 01:06 AM   #27
Wrecked1982
Wrecked1982's Avatar
i really love thoses round light front clip but im too scared tu ruine my almost perfect 85 cab. if you ever dissasemble the front clip i would like to see detailed pictured of whats involve.
Wrecked1982 is offline   Reply With Quote
Old 02-13-2012, 01:21 AM   #28
ghettoluxury
ghettoluxury's Avatar
You don't have to ruin your cab the hood hinges bolt to the fenders on the older clip, so all you will have are holes in the cowl from the 80's hinges. Come spring I will get pics for you. It is currently sitting in the drive with an 8 foot plow mounted to it.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-13-2012, 09:45 AM   #29
Wrecked1982
ok ill wait for those
Old 02-13-2012, 10:17 AM   #30
cochino12
It followed me home?
cochino12's Avatar
What kind of plow are you using? Did you Fab up some mounts to work with the lift?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-13-2012, 09:33 PM   #31
ghettoluxury
I am using a western and yes i fabbed up a mount to make up for the 4" lift. I took two 12" peices of 3x6 1/4 wall tubing and layed it up agianst the bottom of the frame, then drilled two 1/2" holes in each one and bolted them up. After that I took the C channel that the blade mounts to and welded it to the bottom of the tubing. I then took the upper pump support bracket and welded it to the top of the tubing. Once i had everything where I wanted it i used 6" wide 3/8" platefor the side supports using the factory bumper / tow hook bolt holes for the bolts on the frame and 2 more in the tubing. I then welded the side support to the tubing making it one unit. In all there are 16 1/2-13 grade 8 bolts and a lot of weld holding it on.
If you need any more pics I can get them my next day off.
Old 03-01-2012, 11:33 PM   #32
ghettoluxury
Ok, today I found a deal on craigslist I could not pass up. All New Genuine GM loaded calipers/ brackets and e-brakes off an '05 2500hd for $150. I am going to try and retrofit them to the Dana 60 / 14 bolt that are in the truck now. Since I already have the '04 rear axle sitting in the garage, I figured worse case I would have spares.
Old 03-01-2012, 11:49 PM   #33
nekkidhillbilly
honestly man your better off with the oem brakes. i have a 04 hd the brakes are junk.
nekkidhillbilly is offline   Reply With Quote
