Project Weed Wacker
Well the name of this comes from my buddy Jeff. I stoped by his house after getting my custom plates and he said, I see you finally got the weed wacker going.
![]() I bought this truck off my brother-in-law sight un-seen for $900. On the trip home the tired old 350 threw a rod through the oil pan. So after a ride home on the rollback here is what i had sitting at home, a 1988 3+3 Silverado with an ugly flat bed on it. ![]() ![]()
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Re: Project Weed Wacker
After selling the extremely over built flat bed, I removed the front clip. This was done so that I could work on it in my garage, 23ft of truck in a 25ft deep garage makes for a fun time on an engine swap.
After pulling the motor I purchased a freshly rebuilt TBI 350 out of my buddys rolled 94. I also picked up stainless headers for an 88-94 pickup.
I had to mod the drivers side header and the frame just a little for needed clearance. On the header I moved the O2 sensor to the bottom side and pluged the original hole.
My brother was getting ready to scrap this so I gave him $75 for it. It is not the best but it's better than frame rails.
Man that thing looks rough. What are your plans for the truck? You converting it to a SRW or going to keep it a dually?
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
Cool truck!
I second all of Mattman's questions... Posted via Mobile Device
Around here that is a decent square body. I am convertind it to srw and lifting it for 35's at a min. The license plate is a hint for the rest of my conversion.
I wish I could find a 4x4 Crew cab dually for $900, pretty much cant even buy the front axle for that price around here. I think you did pretty good on it. Cant wait to see it. Im a sucker for 4x4 crew cabs.
Ok Matt, here she sits with a bed and front tins. I borrowed the front tire from my brother to get her out of the garage, while it was getting the motor swapped my buddy bought the dually rims that were on it.
Long bed, crew with 35's...Gonna be hella big! Cool!
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
Looking good man. Does it not take very much work to put a 73 front clip on an 88? I know it is a lot of work to do visa versa.
#13 |
![]() Join Date: Oct 2011
gonna be a cool truck!!! are you going to change hubs and rear axle ?
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
#14 | ||
#15 |
I got tired of the multi colored truck sitting in the drive, so she got a rattle can job for peace of mind.
I also put 08 Jeep Wrangler headlights in and ran them to relays. ![]() ![]() ![]()
#16 |
You work as fast as me! Looks good so far. My vote goes to more lift and more tire!
Posted via Mobile Device |
#17 |
Picked up a set of 4" lift springs for the front and 6 35x13.5x15 BFG Krawler TA's from my buddy for $800. I got the front springs installed and ground down the massive calipers to run a 15" rim on a Dana 60. Here is how she is sittin now, I'm going to do a shackle flip on the rear.
#18 |
That thing has come a long way from the first post. Looks awesome!
#19 |
![]() Awesome!! Posted via Mobile Device
#20 |
Thanks guys. It has been alot of work (for a 1 man build) but thinking outside of the box is the key.
#21 |
Ok, today I ground all the rivits off of the rear hangers and then cut them in half. I then flipped the bottom part upside down, welded them back together and added gussets. The crew doesn't have the cali lean going on any more, but I think it needs to go a little higher.
#22 |
It followed me home?
Looking good!
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#23 |
Very cool!!
Got pics of the shackle flip? Posted via Mobile Device
#24 |
VA72C10
![]() Join Date: Mar 2008
I think it looks good right at that height with that size rim/tire combo...looking good and nice progress!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#25 |
I just scored an AAM 10.5 out of my buddy's 04' 2500HD for $300 plus my Dana70. I love having friends that think everything should have old school solid axles and six tires under it.
