Closed Thread
Old 03-08-2012, 12:58 AM   #26
HeavyMetalChevy
Just a Member
HeavyMetalChevy's Avatar
Re: Restored Auto Tilt Column
ttt
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st)
69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd)
70 C-20 88 350 long block rebuild .040 bore. forged crank
GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum
TH400(3rd)
71 SWB frame off with 68 body. POSI
PayPal: remimartin257@aol.com
Business Inquires: 812 801 5111
"Help me, help you" that's my motto
Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog
HeavyMetalChevy is offline
Old 03-08-2012, 01:29 AM   #27
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Originally Posted by HeavyMetalChevy View Post
The only difference between a truck tilt and van is the steering shaft length and the neutral safety switch placement on the outer steering collar itself. Som people are real anal when it come to it and others realize the only person that will ever know is themselves. I doubt anyone is going to get under a dash and be like "hey...that's not a true truck tilt. I modify them to bolt right in to trucks so they are in essence identical to a truck tilt besides the switch position. The vans are located about half way down the column and the trucks are a few inches from the floor.
There is a tilt column in my 72 and it was there when I bought the truck and I know my truck was not built with a tilt wheel. To simplify for me a 67/72 tilt has the neutral safety switch half way down the column and the van tilt has it at the bottom of the column or vise versa?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Already Gone is offline
Old 03-08-2012, 01:34 AM   #28
HeavyMetalChevy
Just a Member
van tilts are halfway down . Truck tilts are closer to floor seal.
TH400(3rd)
Old 03-08-2012, 01:49 AM   #29
Already Gone
10-4 now I got it. I'll check mine and see what I have.
Old 03-08-2012, 03:32 PM   #30
vanislejimmy
Still have one for sale? I'm looking for an automatic shift not the floor shift. Thanks
vanislejimmy is offline
Old 03-08-2012, 05:08 PM   #31
HeavyMetalChevy
Just a Member
Yes I have many I am restoring.. I will have to adjust shipping accordingly for Canada. Should not be much more and we can keep the customs value down. PM me sir.
Thanks,
Duane
TH400(3rd)
Old 03-08-2012, 06:06 PM   #32
cjohnson6772
cjohnson6772's Avatar
I'm interested in a column shift column if you have a true truck column. I know the vans are quite similar, but the i would orefer a genuine truck column. Let me know what you have
cjohnson6772 is offline
Old 03-08-2012, 06:13 PM   #33
HeavyMetalChevy
Just a Member
A completely restored true truck column will run $425-$450 depending on parts and shipping.
TH400(3rd)
Old 03-09-2012, 06:32 AM   #34
kriswvu1202
kriswvu1202's Avatar
I would be interested in one of these in the near future if you're going to be doing more of them.
"And when you discover what you will be in your life, set out to do it as if God Almighty called you at this particular moment in history to do it. Don't just set out to do a good job. Set out to do such a good job that the living, the dead or the unborn couldn't do it any better." -MLK
kriswvu1202 is offline
Old 03-11-2012, 02:34 AM   #35
HeavyMetalChevy
Just a Member
everyone seems to like um'
TH400(3rd)
Old 03-15-2012, 12:27 AM   #36
HeavyMetalChevy
Just a Member
TTT for restored TRUE TRUCK TILTS featuring new OEM turn signal switches...
TH400(3rd)
Old 03-15-2012, 05:08 PM   #37
Already Gone
A bump for your thread and a question. I checked my 72 this morning and the switch is right down near the firewall , so do I have an original? I ask because my 4 way flasher button is black and not like the two on the columns in this thread.
Old 03-15-2012, 05:34 PM   #38
HeavyMetalChevy
Just a Member
yes it would be an original. I have seen some NOS flashers on site that are black and original and some red. So I am not sure... Most people prefer red. But I am guessing your turn signal switch was replaced at some time. replaced with a black knob
TH400(3rd)
Old 03-15-2012, 05:43 PM   #39
Already Gone
Thank you for the info. My flasher knob is black.
Old 03-15-2012, 06:23 PM   #40
ls1nova71
ls1nova71's Avatar
Just an FYI, the red hazzard knob is only correct for a non tilt column, all tilts originally came with a screw on hazzard knob, most 70-71's had the chrome one like in your second column pic and the 72's had the black, kind of 'horn' shaped plastic knob.
Also, you can't put a van tilt in a truck with the neutral safety switch in the van position, it hits the bracket that the column and brake pedal bolts to.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline
Old 03-15-2012, 09:06 PM   #41
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
X2 That is 100% correct.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline
Old 03-16-2012, 03:11 PM   #42
HeavyMetalChevy
Just a Member
The flasher information was very informative and well needed.
On the not being able to install the van columns with the neutral safety switch position I must disagree. I have removed van tilts from trucks, I have also taken dimensions and measurements to compensate, and I also have pictures to verify such as true. Also that is not 100% correct any way you look at it because you can always collapse the intermediate shaft to compensate as well.
TH400(3rd)
Old 03-21-2012, 05:43 PM   #43
HeavyMetalChevy
Just a Member
68 non tilt column I just did for member henry3rd was not a total restore but dang near. He just wanted blasted and painted black. I still tested the switch...blasted lithium grease and got er' wet.. polished up all levers and even blasted the clamp/retainers and fasteners for the lower end bearing..
TH400(3rd)
Old 03-21-2012, 05:45 PM   #44
HeavyMetalChevy
Just a Member
few more 68 column pics
TH400(3rd)
Old 03-21-2012, 06:17 PM   #45
HotRod C/10
HotRod C/10's Avatar
nice job!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline
Old 03-21-2012, 06:36 PM   #46
HeavyMetalChevy
Just a Member
I have another 67-68 complete column disassembled and ready to go if anyone interested. As well as many non tilt columns. Going price around $200 completely overhauled, blasted, painted, etc. I can paint ANY COLOR AS WELL!
TH400(3rd)
Old 03-21-2012, 08:30 PM   #47
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
It looks like you are doing real nice work. I have been modifying van columns for trucks for years. I have made patterns to move the NSS down to the truck position. That insures there is no interference with dash components...they do hit. I then cut the column opening for the truck NSS and weld a tab on the inside tube. This allows the use of the truck NSS in place of the van...the truck harness then plugs right in and works correctly (the van NSS does not have the same terminals as the truck. Just thought you might be interested and feel free to use any of this info. It makes a true economy plug-n-play tilt.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline
Old 03-21-2012, 09:15 PM   #48
HeavyMetalChevy
Just a Member
I do appreciate it and I can tell you are definitely a man of wisdom for sure.
I used this link a few months back http://67-72chevytrucks.com/vboard/s...=147927:metal:
TH400(3rd)
Old 03-21-2012, 09:22 PM   #49
DesertCat
DesertCat's Avatar
the 67-68 is a tilt? Prices of tilt and non-tilt 67-68 to 85249 please amigo
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline
Old 03-21-2012, 09:28 PM   #50
HotRod C/10
How much for a red auto tilt 68 circa?.....actually it can be any color since Im painting my interior all red.
LS SWAPPED
-1976 SILVERADO
Closed Thread
