Just a Member
Restored Auto Tilt Column
This thing is SUPER SWEET!!! Do not want to get rid of it but I will building more in the near future...
For future reference...I will shoot whatever color need be you just buy the paint... ![]() $325-$350 Shipped CONUS dependent on cancelling cam, parts, and horn kits Just acquired a TRUE TRUCK tilt. It will include a brand new OEM turn signal switch with red, chrome, or black flasher and new bearings... Completely blasted, rebuilt, and painted for $450 shipped CONUS it will be of as good of quality as all these featured in this thread Also have another true truck tilt coming Buyer to pay fees Pics below of a 68 no tilt column I just did for member henry3rd
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog Last edited by HeavyMetalChevy; 04-02-2012 at 02:30 AM. |
Just a Member
Re: Restored Auto Tilt Column
more pics
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
If this is from a 67-72 chevy truck I will take it. Thanks
Just a Member
van tilt but steering shaft is correct for truck..
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog Last edited by HeavyMetalChevy; 01-03-2012 at 09:33 PM. |
I think ill pass, i have a locoal guy with one out of a truck, thanks.
change of heart, I will take it.
#7 | |
Just a Member
Happy New Year, Duane
Just a Member
sold to freakshow108... Here it comes!!
Excuse my ignorance. What is the difference between the van and truck tilt. Is it obvious? I put a tilt in my truck and think it was from a van and the only thing I had to change to make it work was the wiring in the column. The van one kept shorting out my lights as the configuration must have been different. Thanks
#10 | |
Just a Member
![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=147927 lot of info here but everyone has their own way of going about things... The short could be a number of problems. I am not an electrician by any means... ![]()
Thanks, I am going to have to study this for a while. I agree, forum is the best tool for my restoration.
#12 | |
Just a Member
#13 |
![]() Join Date: Oct 2009
not trying to be "short"... with electrical... that's a good one!!!
#14 |
Just a Member
Hah.. .wondering if any one would catch that... Good luck!
#15 |
Just a Member
70BigBlock's pics
#16 |
Just a Member
more
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog Last edited by HeavyMetalChevy; 02-19-2012 at 11:06 PM. Reason: pics |
#17 |
![]() [size=1]Posted via Mobile Device[/size just got that five years later. Is this the truck tilt u are restoring? Posted via Mobile Device |
#18 | |
Just a Member
![]() ![]() ![]() The first pic group is one, the second pics are another, with a third coming. I also posted the tilt I just got in it's own thread
#19 |
So is the second one a true truck tilt? Still can't tell the difference yet.
#20 |
Just a Member
The only difference between a truck tilt and van is the steering shaft length and the neutral safety switch placement on the outer steering collar itself. Som people are real anal when it come to it and others realize the only person that will ever know is themselves. I doubt anyone is going to get under a dash and be like "hey...that's not a true truck tilt. I modify them to bolt right in to trucks so they are in essence identical to a truck tilt besides the switch position. The vans are located about half way down the column and the trucks are a few inches from the floor.
#21 |
The fact that van tilts were used many years later than '72 and had become more common makes truck columns worth much more than van tilts. So,price is one way to tell.There are those who demand true truck tilts and will pay the difference and there are those who are wiling to use van tilts,mostly because they are an economic alternative that appears the same from inside the truck. One way to tell,as with that second one,is by the flasher button and tilt knob being a later design,as well as the shorter shifter. But,a truck tilt could be rebuilt using these later pieces,so you have to go by the shaft end and neutral safety switch location. Your best bet is never assuming and ask the seller which it is.
#22 | |
Just a Member
#23 |
What are you asking for the truck tilt column?
#24 |
Just a Member
These are all restored and modified van and/or rv columns. My other tilt is here... Not restored but very nice shape. And has correct red hazard knob...The intermediate shaft has been collapsed for shaft difference and will bolt right in to our trucks. It is all in excellent working order with nice chrome levers.
http://67-72chevytrucks.com/vboard/s...d.php?t=509991
#25 |
Just a Member
ttt
