#26 |
Resistance is Futile
Re: pros and cons 5 lug and 6
The only thing I have noticed is that the 5-lug Ralley wheels tuck in a little more than the 6-luggers on my other truck. I dont know if the spacing is a little different or if it's the suspensions on the trucks, which are different. The 5-lug is a 73+ setup and the 6-lug is a conversion spindle using all stock B/J's and tie rods. Both are dropped spindles with stock components otherwise.
I love those slotted wheels but have never seen any with any backspacing deeper than about 3.75''. Need another .5'' IMO.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#27 | |
Senior Enthusiast
http://67-72chevytrucks.com/vboard/s...c+brake+wheels If the back of your wheel has the conical or tapered shape shown on the Rader mag in post 4 of this thread, it probably won’t clear the caliper: http://67-72chevytrucks.com/vboard/s...c+brake+wheels The truth is the only way to know for sure is to try mounting the wheel on an assembled disc brake & caliper. Some drum brake wheels fit while others do not. I’ve mounted both early 1960’s Dragmaster mags and factory Buick wheels designed for drum brakes on my front disc brakes. Both fit fine, although the mags needed a very tiny amount of clearance grinding on the calipers. Whether any particular wheel will clear the caliper depends on the shape of the wheel center, offset, and shape of the wheel rim on the back side. |
#28 |
I went 4 wheel disc 6 lugs and new axles. I wish I had gone 5 lug. My reasoning at the time was that I had already bought new 6 lugs wheels before my plans changed and I decided to drop it and narrow the rear end. I didn't want to buy wheels again. But now I have two trucks, have moved the "new" wheels to the other truck and looking for wheels again and wish I had the selections available for 5 lug.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
#29 | |
C/10 junkie
![]() Posted via Mobile Device
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#30 |
Heres the 1974 blazer 4x4 rims w/1961-63 chevy hubcap. Shown w/hubcap, front and back. Notice the 4 bumps in the center pic & the 4 holes are slightly different then the 3 bump wheels.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#31 | |
C/10 junkie
#32 |
Senior Enthusiast
If you go forward with the conversion, please let us know if these fit the 6 lug disc brakes. Then we'll finally have confirmation one way or the other. Thanks for posting the photo.
#33 | |
#34 |
C/10 junkie
This is the closest I have at the moment, and the caps are on I will take some better pics tonight and post tomorrow. Thanks for the help guys.
#35 |
I found an 88 c1500 hd 2x4 with 6 lug disks. I wonder if they would have the same spindle diameter as my 60 drop spindles?
Posted via Mobile Device |
#36 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Nope, not gonna work. Those don't work correctly on the '73-'87 spindles either. You have to use the '88-'98 spindles with those rotors.
#37 |
So about the rims...i swapped 72 disc front and the rear axle from same truck into my 62. Did GM make 16 inch rims for the 5 lug?? I like stock rims if i can help it,just like the taller wheels.
